Old 10-10-2026, 05:39 AM   #4
GustavoPR
Drives: Yaris 2014
Originally Posted by Neinris View Post
If you don't do the reflash, would cold starts have high rev similar to changing the throttle body with one from the 1ZZ?
A reflash won't change your cold-start idle speed; you need to adjust the Allen-head screw on the throttle body—the one with the locking compound on it—to fix that. I adjusted mine with the A/C on so that when the compressor kicks in, the RPMs don't drop too low and cause the engine to stall or start shaking. Before the adjustment, it would rev to 3,000 RPM or higher on a cold start; after adjusting it, it goes up to between 1,900 and 2,100 RPM, depending on the ambient temperature. I’ve tested this with both the 1ZZ and 2ZR throttle bodies.
GustavoPR is offline   Reply With Quote
Whiteline Control Arm Bushing install and Review tmontague Performance Modifications 3 06-08-2019 02:42 AM
Aftermarket bolt ons vs OEM dispute tmontague Off-topic / Other Cars / Everything else Discussions 17 04-02-2017 11:37 PM
Broken Control Arm Bolt Sirius-XM DIY / Maintenance / Service 4 02-29-2016 08:27 PM
Lower alternator bolt won't go back in, help! Tmblackflag DIY / Maintenance / Service 3 01-21-2013 03:18 PM
