View Poll Results: Do you think the wind plays with your Yaris
Cops think I'm drunk when driving vs. wind 49 54.44%
My Yaris drives straight like an arrow 19 21.11%
Who cares, cause I don't 22 24.44%
Voters: 90. You may not vote on this poll
Old 05-20-2007, 07:20 PM   #1
gm830
gm830's Avatar
Drives: 2008 Yaris LB
Originally Posted by Mead View Post
"has me scared to drive on the interstate now"
"60-80mph the car is ALL OVER the road. almost uncontrollable"
"barely made it home from the dealer"
"the interstate driving is killing me"
C'mon, if the Yaris is such a liability, the DOT would never legalize it, hwy fatalities would be all over the news, Toyota stock would plummet on the bad press...
There is nothing wrong with this car and NO you don't have to TRD it to make it track straight. Did you guys come from a Lexus LS or Bentley? making the Yaris so hard to get used to? Sure the Yaris is buzzy but it's damn smooth for a sub 2300lb car. Short wheel base? same as the Fit.
I also have a Jeep wrangler with 93" wheelbase and high CG, I've passed semis doing 85mph in Texas crosswinds Quite frankly y'all don't know how good you have it.
ON a serious note, if you're really scared to drive the Yaris on the hwy you need a new car. Dont' mess with tire pressure or feel you have to lower it 2" to feel stable. Get a 3300 lb Camry with 110 in wheel base
I'm really hoping you're right about all of this because after reading all these posts I'm scared to buy my yaris liftback lol
Old 05-20-2007, 08:29 PM   #2
blacksan
blacksan's Avatar
Drives: 07 Bayou Blue Liftback
You will find it enjoyable after getting use to the car. I only notice heavy cross winds, but they are even worse in truck which has a lot more metal and a higher center of gravity.
blacksan is offline   Reply With Quote
Old 05-21-2007, 09:31 AM   #3
Mead
Drives: BSP Yaris LB 2007
my only complaint about high speed driving in the Yaris is it gets a little noisy, mainly due to the lack of insulation but it keeps the car light. Other than that the car handles great on the hwy, it's very peppy. I'm confident next to semis.
Sure, the steering is probably a little light but it's not a danger to society. IMO if anyone thinks the Yaris is uncontrollable at speed, then they either don't have enough expereince with other cars or just don't know how to drive. (assuming there's no mechanical issues and the tire pressure is correct)
Mead is offline   Reply With Quote
Old 05-29-2007, 12:35 AM   #4
Pars
Drives: 07 Yaris Liftback
Did I miss something? I don't recall anyone saying that the liftback was more susceptible to cross-wind then the Yaris sedan. btw, the original post was a sedan owner, not a liftback.
I drive a 5dr liftback and the only time my trance-like stupor is interrupted by cross-wind is when half of the other cars on the road are also getting tossed around in their lane. Usually when I'm wakened from the cross-wind, I'll jack up the speed since the car seems to cut through the wind better at higher speeds (but not too high, like above 90mph).
I recently changed my tires from the stock potenza to Toyo Spectrum. The new Spectrum are more quiet (but old tires tend to get noisy), seem to be a bit more stable at extreme speeds (above 90mph) and does a better job at handling the g-force. Hopefully it's just as good as the Potenza in the braking department. If so, win-win.
Anyways, the tires are going to play a significant factor in the cross-wind. My old car (which was also a hatchback and weighted as much as the Yaris) were running on Toyo Proxies FZ4 (I hope to get these tires when I finally move up in wheel size) and the Proxies have an amazing centred feel and I suspect would be significantly better against the cross-wind. The only problem, is that they're directional tires and tend to need frequent rotating (to keep them from getting noisy).
Pars is offline   Reply With Quote
The Official Having A Bad Day Thread. *MAD DOG* Off-topic / Other Cars / Everything else Discussions 7 11-15-2008 09:38 AM
Official bitch about gas price thread flint_mica_manual General Yaris / Vitz Discussion 61 05-24-2007 10:53 PM
