![]() ![]() ![]() Drives: 07' Yaris Liftback - silver Join Date: May 2006
If it does it again, I will have it checked.. hope it doesnt though.
![]() ![]() Drives: 2007 Yaris Liftback Join Date: Sep 2006
A friend of mine has a Mustang. When he gets near the rev limiter, the engine light flashes. If you are too close for too long, at will stay on and if you hit the rev limiter, engine light stays on.
His Dad has got some type of diagnostic head made by snapon. It didn't show the code (rev limiter) even with the engine light still on. When he took it in, he was warned about abusing the engine and further abuse, may void the warranty. It seems that those type of codes that may report abuse are secret and you must have the right diagnostic head to read them. I can not confirm or deny.. This is just what I was told. |
![]() ![]() ![]() ![]() ![]() Drives: Yaris Sedan Join Date: Sep 2006
You should chek that out cause I really rev mine hard everyday and no check engine light comes on.
I Drive a 129whp Yaris ;) |
![]() ![]() Drives: 2007 silver yaris sedan Join Date: May 2007
#5 | |
![]() ![]() Drives: 07 YARIS Automatic/LiftBac/Red Join Date: Jan 2007
#7 | |
07 Yaris LB 5spd AE86 Corolla GTS 5spd http://microimage.ning.com/ http://www.microimageonline.com/store.html |
#8 | |
GIGA...DRILL...BREAKER!!!
Drives: Lagann. ;P Join Date: Feb 2006
![]() That would make sense though. I can understand voiding the warranty from "abuse". Economy cars weren't designed for racing, thus treating it like a race car could naturally result in some problems that wouldn't have arisen if it was used under normal circumstances. Better slow down there, Speedy! ~YR
Be polite. Be professional. But have a plan to kill everyone you meet.
11b1p
I noticed in the owners manual that the car has an EDR system. That system would record information before an "event".
Patient: Doctor, it hurts when I do this...
Doctor: Then stop doing it... |
![]() ![]() ![]() Drives: 3-door liftback blazing blue Join Date: Oct 2006
that would kill me to do something like that to my car. my car will never see 6000rpm. I did have it 70mph in 3thd gear once didn't notice the rpm
07 yaris LB 5-speed blazing Blue 07 yaris LB Auto Bayou Blue rostra cruise control oem style foglights 96tacoma 4x4 xcab I4auto Weathertech vent visors Scan GaugeII |
CAMRY FTW!
Drives: Camry LE V-6 (225,000+ miles) Join Date: Jul 2006
VW Jetta's have a safety feature (well for the manufacturer anyway) When the car hits its rev-limiter multiple times it would log a engine warranty void code within the computer. It would never show up as a check engine light. So be warned if anything happens it is all on you.
I drive a Camry. I have no imagination.
Then whats the point of a rev-limiter? You might as well just let it run willy-nilly. Kind of lame.
BTW, does it say anywhere in the warrenty about a warrenty void, due to hitting the rev-limiter? |
rev-limitier does what its name describes it limits rev during acceleration. however. if you dump the trans into 1st while driving at 4000 rpm in 4th theres not much that can stop that force from blowing up your motor. most people blow-up thier motor (non-turbo) when they misshift into a lower gear. not during regular up-shifting
#15 | |
Mr Attitude
Drives: Blazing Blue 5 Spd Join Date: Jun 2007
![]() Way to go Corky...
It's scary to think that half the people surrounding you are below average...
#16 | |
I'm saying, why have a rev limiter where its at, when running into it will void warrenty? Why dosen't Toyota just set the rev limit low, so when you hit it nothing will happen? Or why have it at all? If there is a recorder that'll void your warrenty, that'll have the same effect if your engine blows up. You'll be left shit out of luck. The air bag anology isn't the same as the rev limiter. Hitting the rev limiter dosen't require a wall. Why the hell would an engine create all of its power so close to the rev-limiter? How would you gain all of the 8.whater (or whatever the 0-60 speed is) by not reving to where the power is? Everyone should create big bore, big stroke engines, so going near the rev-limiter would be worthless. Not to mention the non s models do not have a tach, so figureing out where you're at isn't easy for the new driver.. My X-Runner dosen't have much top end power. Well, it does, but I've got oodles of torque in the low end, so I wouldn't really have to rev so high. Wouldn't that be the solution to a rev-limit warrenty void? If you think that hitting a simple rev limiter is SUCH a risk, to be compared to condoms, and air bags, then you really need to get some of your values straight. ... and that picture wasn't called for. |
#17 | |
Mr Attitude
drop-off-point in power as the revs top out, so shift there. There is never a reason to be buzzing the rev-limiter for extended periods. Like I said, it's a rev-limiter, not a stupidity limiter... The engine develops all of it's power at high revs because that is how it is designed. Again, when you feel the drop in power, shift. The max shift point does not change from day to day, try to remember about what it feels like, and SHIFT! If the Yaris made it's power low in the revs, it wouldn't get close to the same gas mileage, which is the basic point of the car. What the hell is the "8.whater"? If a manufacturer warranty's your product against defects, shouldn't they be able to monitor it for defects. That is what this "rev-limiter recorder" does, it monitors defects in the DRIVER. Why should the manufacturer be responsible for your abuse? As for my values, I'm thinking mine sound pretty good. I don't do stupid stuff just because I have safety equipment... ...and the picture was funny ![]() ...and this will be locked soon, that's what happens when I get more than 1 post in a thread
hahahaha
| Check Engine "Injector failure Code" | YarisPR | DIY / Maintenance / Service | 14 | 03-04-2007 09:13 PM |
| higher octane fuel | KSIbucky | DIY / Maintenance / Service | 37 | 01-14-2007 08:17 PM |
| service engine light @ 9000 mi? | dandj | DIY / Maintenance / Service | 21 | 01-03-2007 01:30 AM |
| High compression engine | flow-vitz | General Yaris / Vitz Discussion | 1 | 11-15-2006 02:03 PM |
| Check out my new light ( SEDAN )) | mariosuper | Cosmetic Modifications (Exterior/Interior) | 5 | 09-22-2006 10:06 AM |
