#127 |
#128 |
Clean and (dis)Functional
Drives: Yaris 2dr--Black Betty Join Date: Mar 2007
I welded a rod onto the side (towards the top) of a cheap socket and it worked fine. Just gotta have a cheap welder!
____________ Old School Cobble Jockey
#129 |
I mean I could use one but I got my springs installed so I am good.
#130 |
THANK YOU for the diy, it was really (really, really) helpful.
Took two of us about 3.5 hours, but we messed with the plastic and metal under the hood for a while. I had to remove the metal shroud there completely to get to the top of the front strut bolt. Just went super slow and careful, I"m always afraid I'm going to break or lose something. I would say air tools are a big plus. We used an air tool on the top front strut bolt, so we didn't need the allens wrench in there. I couldn't get a box end on there solid enough to loosen that one. Didn't need to compress the rear springs at all (the rears as SO EASY). Anyway, thanks again for the DIY, and the DF210's are a PERFECT drop for this car. Pictures forthcoming (it got dark while we were working...) woo hoo, gonna go drive it around now!! |
#131 |
![]() ![]() ![]() ![]() ![]() Drives: LB-Auto-PWR-ABS-Cruise-Springs Join Date: Aug 2006
Hey Chris07LB, you should put in your required tool the Spring Compressor. If someone (complete noob) tries to do it without one, they will get one hell of a suprise and maybe a trip to the hospital. Just my 2 cents.
Other car is a 2005 Mustang Convertible 4.0L V6 Manual - Legend Lime Get YarAss in gear! RIP - Casey Tatum |
#132 |
You should read the DIY again.. its not only shown in the pics, but also mentioned a few times.
This is only a "guide" to help with the install/removel process. |
#133 |
Lonesome Cowboy
Drives: 2007 WHITE HATCHBACK Join Date: Feb 2007
I think he's trying to call you a NOOB KILLER, Chris.
SPONSORED BY
#134 |
#135 |
Holy Shit! These Megan springs are excellent. I just got finished installing them tonight (pics tromorrow) and I went to fix a friends computer. Coming home I went down a road that has been torn to crap, like a 2 foot wide ditch was dug in the middle and patched really crappy. With my regular OEM springs I could only take a few seconds of my right tires riding over that crappy patch job, but with these new ones, it was like budduh. I swear I could hardly feel them. The patch job goes on for like half a mile and I paid very close attention to the feel of the road and it was incredibly smooth feeling compare to the OEM springs.
It dropped from 26.5" (measured from ground to fender) to a little under 25". 1.5" drop like they claimed. Looks real gooooood! BTW - I went to sears and got one of these Craftsman 17 x 19mm Wrench, Deep Offset Box End for the top strut bolt. It works like a champ! http://www.sears.com/sr/javasr/produ...seBVCookie=Yes
#136 | |
Lonesome Cowboy
anyway your measurements add up, cool
SPONSORED BY
#137 |
These springs don't feel that stiff. I have not had them on the highway yet though. Going to work tomorrow on the crappy Cary St. in Richmond should reveal a lot about these. I am also getting an alignment ASAP! Like tomorrow if possible. I'm just amazed at how they soaked up that bumpy crappy road. I'm still in disbelief. I looked at the patches, and it was night time, but I don't think a crew has smoothed them out yet. I think the springs did! I recommend these to anyone who wants a smooth ride that looks cool too. Not necessarily Megan but anything besides OEM!
#138 |
Glad to here somone else finally put them on! I think they're great but have nothing to compare to besides stock....I think they're quite a bit stiffer than stock but softer than an RX7 I have, and have never bottomed out.
#139 |
Hmm.., mine feel supple. Takes bumps better, a lot better! Very Nice! High Five!
#140 |
Shiny Chromey Coolness
Drives: 2007 Toyota Yaris Liftback Join Date: Feb 2007
Where would one locate a 'spring compressor'? Im thinking of doing this mod. You've finally talked me into it. Can I rent one from AutoZone as a loaner tool?
And no, i'm not buying one as I will never use the freaking thing again!
Bringin the Bling to Yarisworld |
#141 | |
BTW - The only drawback to lowering I've seen is some rubbing on the inside of the wheel wells when hitting big bumps. But then again, what did I expect??
#142 |
I wonder if my bumpstops may be farting. Apparently you are supposed to line up the grooves to the holes... I may remove my struts and glue my bumpstops back together with Gorilla glue. Then make sure I line up the bumpstops correctly.
#143 | |
![]() ![]() Drives: Yaris 3 Door, 04 WRX, 69 Lotus Join Date: Apr 2007
The correct sizes are 14mm, 17mm, and 19mm. The Strut to spindle bolts and nuts are 19mm The end links are 17mm The brake bracket are 14mm The top nuts are both 17mm The cowl is held down with 10mm's Figured I'd add that today so someone can edit the first post to make it right. Using the SAE sizes WILL lead to rounded over bolts, especially once the car gets some age and rust... |
#144 |
I will update the original post later.
| Tanabe Strut Tower Bar Install & Review [pics!] | Chris07LB | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 57 | 04-07-2022 07:46 AM |
| Springs - Tanabe DF210 or Tein S Tech | andylai2k | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 9 | 06-10-2007 09:22 PM |
| Tanabe DF & Strutbar install | mcdaddy | DIY / Maintenance / Service | 18 | 05-03-2007 09:57 PM |
| TANABE DF210 SPRINGS AVAILABLE!!! | C2AUTOSPL | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 20 | 08-05-2006 12:28 AM |
| Spring Install Price | redglare45 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 1 | 06-30-2006 08:32 PM |
