Old 09-21-2006, 04:50 PM   #1
nick1983
nick1983's Avatar
Drives: 2007 Toyota Yaris sedan
Originally Posted by Ran Kizama
Nice post. If anyone wants to just get rid of their foglights, let me know. I'll buy them and send you the OEM filler thingies.
Same here....
nick1983 is offline   Reply With Quote
Old 09-26-2006, 08:26 PM   #2
KSIbucky
KSIbucky's Avatar
Drives: 2007 Yaris manual dark silver
Send a message via AIM to KSIbucky Send a message via MSN to KSIbucky
the think didnt come out how do you get it out witch way do you pull
a picture with arrow would help
7 Color Tach
Fujita Intake
Momo pedals Shift knob and boot. Full TRD SSK.
Blitz exhaust
Megan Lowering Springs
(Next is DC Header)
KSIbucky is offline   Reply With Quote
Old 09-27-2006, 01:22 PM   #3
Chris07LB
Chris07LB's Avatar
Drives: Yaris Liftback
Dissconnect the plug, and pull the DRL box out. Simple.
Old 09-27-2006, 01:42 PM   #4
ChinoCharles
Drives: LB
There is a slot on the side of the relay where a bracket slides in. First, push the relay in the direction opposite to the base of this bracket. This will remove the relay, and then it is just a matter of disconnecting the wires. When I did this I tried to disconnect the wires first, but unless you're 3 and have the hands of Tinkerbell this won't work, or it will work and you'll have busted knuckles. Either way, remove the box first.
Old 07-10-2006, 11:24 AM   #5
JDMVitz
Obsessive Detailer
Drives: JDM
One question. The DRL light on the dash won't come on, right?
JDMVitz is offline   Reply With Quote
Old 07-10-2006, 12:29 PM   #6
Chris07LB
Chris07LB's Avatar
Nope, there is no DRL light on the dash... not mine anyway.
Going to take the promised pic's and resize in a bit.
Old 07-10-2006, 02:57 PM   #7
Chris07LB
Chris07LB's Avatar
PIC'S ARE POSTED UP ABOVE!
Old 08-06-2007, 11:30 PM   #8
jeremyshay
jeremyshay's Avatar
Drives: 07 Meteorite Metalic Liftback
Send a message via AIM to jeremyshay
THANKS!!!!!
any weird side effects of this?!
cause if not im totally on it the second i wake up tomorrow.....
jeremyshay is offline   Reply With Quote
Old 08-07-2007, 08:20 AM   #9
Chris07LB
Chris07LB's Avatar
Morning.
See, everything's fine.
Old 08-07-2007, 10:31 PM   #10
GabL
I want JDM bumpers!
GabL's Avatar
Drives: 5 Dr Yaris RS in Blazing Blue
Originally Posted by jeremyshay View Post
THANKS!!!!!
The side effect will be you will lose your fog light if you have the factory equipped ones.
GabL is offline   Reply With Quote
Old 08-07-2007, 07:02 PM   #11
Christopher
Cobra
Drives: '07 3-door
DRL
Thanks for the info! I assume the headlights still go on and off by using the switch on the stalk? Chris
Christopher is offline   Reply With Quote
Old 08-07-2007, 07:05 PM   #12
Chris07LB
Chris07LB's Avatar
Everything is exactly the same.
Only difference is when you start the car, you dont have ugly DRLs on.
Old 07-10-2006, 03:13 PM   #13
rstb88
rstb88's Avatar
Drives: Silver Hatchback
these HIDs that ya'll are putting in. are they just a bulb conversion or is there a projector in the equation, cause I want HID but not w/o projectors.
rstb88 is offline   Reply With Quote
Old 07-10-2006, 03:18 PM   #14
Chris07LB
Chris07LB's Avatar
No projector's here. The cut-off is still VERY good with just the HIDs, thanks in part to how the Yaris headlights are designed. (I could explain, but I have posted this already before)
Old 07-11-2006, 01:50 PM   #15
JDMVitz
Obsessive Detailer
Drives: JDM
^ nice cut-off. Which HID kit are you using?
Old 07-12-2006, 09:33 AM   #16
Chris07LB
Chris07LB's Avatar
Is anyone having trouble viewing the pictures???
Old 07-12-2006, 09:55 AM   #17
JDMVitz
Obsessive Detailer
Drives: JDM
I can see it now, thanks!
Old 07-12-2006, 11:17 AM   #18
Henshin
a go-go!
Henshin's Avatar
Drives: Silver 07 HB - 5spd
thanks for adding the photos!
Henshin is offline   Reply With Quote
Toyota unveils 2007 Yaris T-Sport Concept VitzBoy General Yaris / Vitz Discussion 63 01-21-2007 03:12 PM
