Lonesome Cowboy
Drives: 2007 WHITE HATCHBACK Join Date: Feb 2007
Tein was a very easy install and the instruction were quite clear. Also the guys at Tein are very helpful. I'm just sayin'.
but hey, the megans have adjustable dampening ![]() hope you get it worked out though, too bad colinT isn't around, he installed his own
SPONSORED BY
Small cars are a big deal
Drives: 2007 Yaris Liftback Join Date: Feb 2006
I could've picked them up for $850 locally, but I didn't want the Tein Basics. Actually, it's not that I didn't want them, but for $875, I picked up the Megans which, again, are adjustable and stiffer. The quality seems very good, too. The only "bad" thing about them is the lack of good instructions thus far.
Subcompact Culture: The Small car blog |
Right. I'm by no means trying to knock the Teins. I had S-techs on my xB, and they were great. I know Tein makes a good product. But unfortunately, they don't offer a set of adjustables in the U.S.
Hopefully, I'll be able to get this all figured out tonight and help those who do decide to go the Megan route so they don't have to figure it out on their own.
#4 | |
Lonesome Cowboy
SPONSORED BY
If you get a chance to call Megan again, ask for Steve or Cyrus. Let me know if you need me to call them for you.
Pictures would also be very helpfull, I'm sure some of us that have done a few suspensions on this car before can help out if we saw some pics. I've done the suspension on my car three times now (Tanabe DF's, Cuscos, and now SK's) but never done or seen the Megans yet unfortunately. |
BTW, look what I just found on the Megan site:
http://www.meganracing.com/products/....asp?catid=107 Those are the adjusters I was trying to describe |
#7 | |
Argentina Presente!
Drives: 07 White LB Join Date: May 2007
Nice! Once mine settle.. I will probably buy on set of those.
About the installation.. I want to explain what we did, but Im really bad with the terms, and I dont want to say it like "the little thing in metal goes with the plastic round thing"... so.. I will probably do a sketch about my installation. {my english sucks} Quote:
Check your PM
I actually talked to Steve today over my lunch break. I'll e-mail him about the flexible adjusters.
Anyway, I've gotten one of the sides done, and lowered down, the top of the strut looks like this. Can anyone confirm that this is correct? They're up 3/4" from the base of the shock tower (I did measure this). ![]() (BTW, this is without the black shroud that houses the adjuster knobs which don't have much clearance usually)
track or die
Drives: Yaris LB CE CDM Join Date: Jun 2007
can a Tein owner take a pic of his head shock like the pic posted up here ?
i don,t know if it is the coilover or the guy's knowledge, but this sound like an horrible experience with the megan coilover..... |
Well, it can't be right. Something is definitely not correct. Once I got both sides "done" and we lowered it down, the right side went up even further to the point that the metal shroud with the wiper motor hardly clears at all.
Here's something to think about: pre load. The person at Megan said I needed to "pre load" the suspension. However, how can I do that if there's nothing to attach the tops to (because it doesn't use the OEM spring mount w/a nut)? ![]() Notice the picture of the front strut. It's got the anodized red top with a nut on it. There's nothing to tighten that nut to like the OEM "hat" or support.
I'm trying to upload the picture from the repair manual right now.
You must have the strut bearing and the nut tightened onto the strut before installing the upper rubber portion and before installing the strut into the car. There needs to be some preload on the spring (or at least the ability to preload it). From the picture it looks like the stock strut bearing may press right into the red anodized spring seat? If so, then you should be able to tighten the nut up to the bearing before installing into the car. |
#13 | |
#14 | |
#15 | |
Correct. However, the first time I attempted to install this, I actually used both the stock and the Megan tops bolted together with the bearing and everything, and the pistons still came way out from the tops of the strut towers. After calling Megan, they said I am only supposed to use the red tops that they supplied. There was no mention of the strurt bearing, though.
Argentina Presente!
Okay; I'll pop that bearing off. I e-mailed Megan jsut now about my issue, too.
dsc_pat: Did your Megan coilovers come with an installation manual?
track or die
nope, but i don't own these coilover actually, sorry for the misunderstanding.
i am looking for some Ksport since i know Koni won't make shocks for a few months/years for the yaris.... |
| Megan Springs? | churp | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 26 | 06-06-2007 03:11 PM |
| Megan or Tein suspension | elmercurrie | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 43 | 05-31-2007 09:41 PM |
| Comp S Coilovers for a discount and installed | BulletProofAuto | California | 1 | 05-12-2007 01:04 AM |
| cusco coilovers installed | badhabitz | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 29 | 02-03-2007 04:43 PM |
| Tanabe NF210's installed...got a question though | Terrorize | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 32 | 09-29-2006 07:45 AM |
