Old 07-12-2016, 08:45 AM   #1
Rigaud
Drives: 2009 Yaris
2009 3door HB 121000km.............Front brakes when I bought in at 78000km in Jan. 2014. Other the tuning and moding I haven't had a single issue or part to remove, even the battery is the original. Car doesn't come out winters so this year it's getting TLC over the winter months. Front wheel bearings, water pump, replace the battery...
Old 07-12-2016, 11:19 AM   #2
Kalispel
Kalispel's Avatar
Drives: '15 Yaris SE 5MT
2015 Manual 5-spd SE, manufactured late 2014 France, purchased late July 2015 Colorado, USA. Currently has a bit over 11k miles on it. Only problem(s) thus far:
- Little plastic fins under front bumper, in front of each wheel installed incorrectly @ factory - dealership corrected under warranty.
- Annoying rattle/buzz in drivers-side side air vent on choppy roads or bumps - dealership corrected under warranty.
So far, that's it. Fingers crossed.
Kalispel is offline   Reply With Quote
Old 07-19-2016, 01:31 PM   #3
contraband831
El Huevo
contraband831's Avatar
Drives: 2007 Liftback
'07 LB
315K miles
-lots of TIRES! :)
-alternator at about 260k
-Spark plugs (3 sets)
-brake and transmission fluid 240k
-Radiator fan 230k
-battery (2)
currently needs new brake pads and fuel system needs to be cleaned.
Overall this car is great, looking to get a newer model to replace this bad boy.
Old 07-20-2016, 06:13 AM   #4
PlainAndrew
Drives: Yaris 1.5 S-Limited
Yaris 2010 AT
60k
The current problem I'm facing is if it idles in drive and AC on the rpm drops to 500 some times below end up causing a vibration (twice the engine shutdown)
Overall this car is awesome. But can any body help with this problem?
PlainAndrew is offline   Reply With Quote
Old 07-20-2016, 10:07 AM   #5
ern-diz
ern-diz's Avatar
A little over 66k miles in my '07 lift-back and I just had to replace the alternator. Mechanic said it was barely making enough power to run the car. Nine years old and all I've had to replace is the water pump, driver's side axle seal and now the alternator.
Best $12,500 I've ever spent lol!
excessive sulfur odor on 2007 model year Yaris tomjasz General Yaris / Vitz Discussion 121 03-13-2010 06:49 PM
TSB's WD-40 General Yaris / Vitz Discussion 27 06-06-2007 01:11 AM
