Old 07-26-2011, 06:17 PM   #1
toy_toronto
always toyin'
toy_toronto's Avatar
Drives: 2010 5-Dr
I am betting yes, but I haven't found an EWD for the auto wipers yet.
Thanks for all the info Scott. I should've verified the p/n with the seller first instead just relying on make/description (i.e. rx330)
I think I'm going to start toying around the idea of adding a toggle switch to my rear wiper delay module to control the fronts as well and see how that works out.
p.s. I'll hold on to the rx330 stalk in case you happen to find the ewd for it. thanks again =)
-toy
Old 07-26-2011, 07:51 PM   #2
-toy
I still haven't tracked down the EWD, but I definitely will. One thing I did find out is that with the stalk connected to the Wiper ECU, if you disconnect the rain sensor then the AUTO mode acts like normal intermittent.
Old 07-30-2011, 01:30 PM   #3
sickpuppy1
Drives: 2010 Yaris Sedan
Has anyone figured a part number for the sedan? (since I dont need the rear wiper) I have a 2010 I'd love to do this to.
Old 09-02-2011, 10:31 PM   #4
siray06
2006 Silver Yaris LS
Drives: 2006 Yaris hatch
My beef from the day I bought it (Nov 2005) is the rear wiper washer switchology. Why on earth would it be wired to spray only when turning the tip of the stalk in one direction and spray with wiper whne turned against the spring in the other direction and then spring back to continuous wiper. One must then manually turn the wiper off once the window is clear.
I would like to be able to push/turn a switch to spray, then after releasing it, the wiper would run for 3 or 4 sweeps and stop (like almost any front windshield wiper washer switch).
Has anyone come up with a mod to accomplish this?
siray06 is offline   Reply With Quote
Old 09-17-2011, 03:39 PM   #5
Kluak
Drives: 2007 Yaris sedan charcoal
Would a wiper stalk from an 05/06 camry work on the 07 yaris sedan?
Kluak is offline   Reply With Quote
Old 09-17-2011, 09:07 PM   #6
No
Old 01-08-2012, 03:15 AM   #7
N2scouting
Drives: 2009 3DHB manual Black
I just got my stalk and followed your instructions to the letter. Took me about 20 minutes. Awesome DIY.
N2scouting is offline   Reply With Quote
Old 02-02-2012, 09:21 PM   #8
caineroad
caineroad's Avatar
Drives: 06 Yaris HB CE
i just want to ask what does it mean intermittent? it looks like many of u guys don't get the different speed of wipes?? my yaris came stock there's about 4 speed of wipes i can select for different raining suitations. can anyone give me an insight? thanks
caineroad is offline   Reply With Quote
Old 02-02-2012, 09:45 PM   #9
The intermittent stalk has a ring that you rotate to select the delay between wipes when in intermittent mode. It allows much greater variation than with the stock stalk, which only has one delay period in intermittent mode.
Old 02-02-2012, 09:54 PM   #10
caineroad
caineroad's Avatar
oh i guess it must be be different in the canadian model.. cuz mine has 4 delay periods. 1 up for one wipe, 1 down for slow wipe, 2 down for faster, 4 down for fastest...
Old 02-02-2012, 10:00 PM   #11
That's the same as the US one.
The intermittent stalk turns the slow wipe into about 6 different choices of slow.
Old 02-02-2012, 11:10 PM   #12
Spidermandud
Spidermandud's Avatar
Drives: Black '08 Yaris Hatch S
Suuuuuure, I'll slide into this couple-year-old thread. This is handy as hell. Thanks much CTScott
-Will-
Spidermandud is offline   Reply With Quote
Old 02-03-2012, 02:32 AM   #13
BIGTAZ351
147K-Blue / 24K-Yellow
BIGTAZ351's Avatar
Drives: 2010 Ylw 3dr. AT(Blue-Wife's)
Is it just my car or does everyone's rear sprayer just "run" fluid down the middle of the window?, it looks like you are pouring it out of a 1/8" hole out of a 20oz pop bottle. No spray pattern like the front washers. This is my first car w/rear wiper/washer.
I keep asking silly questions, but I learn new stuff every day, like stability control gets pissed (and beeps) if you pull the e-brake to make a 180* turn on ice/snow, it will actually apply the brakes on the car to stop you! so my 180 only winds up to be about 110. I have not tried it with the traction control off yet!
All Weather Package, Power Package, Cruise, WeatherTech Floor Mats. Altimax Arctic Winter Tires.
Repair List:
1 new blower motor, making funny noise. @ 91K (Water pump @ 120K)
Mod List:
1. Black tape on most of the annoying blue high beam light behind the lens. (thank you CTScott)
BIGTAZ351 is offline   Reply With Quote
Old 02-03-2012, 10:13 PM   #14
Spidermandud
Only way to learn is by asking; Have you checked to see if there's blockage on where it shoots out? Mine doesn't do that; and it didn't when I had an '02 Blazer either. If not that then. . perhaps a small leak in the line somewhere?
-Will-
Old 02-09-2012, 12:41 AM   #15
caineroad
caineroad's Avatar
does the wiper stops or go slower when you stop the car e.g. red light?
Old 02-09-2012, 06:41 AM   #16
No - The wiper is completely independent of the rest of the car.
Old 05-14-2013, 09:54 PM   #17
bairjo
Better late than never...just installed a Prius wiper stalk on my 2010. For shits and giggles I threw together a video of my install. I know full well that CTSotts directions and photos are outstanding in explaing this but I like making videos to show how easy his instructions are to follow. Sometimes photos alone don't show that. I am looking forward to ordering his rear wiper module in the next few months. Thanks CTSott for all your efforts. Also I almost forgot, I have an extra Prius wiper stalk if anyone is interested in it.
http://www.youtube.com/watch?v=jicAgDNE4Is
bairjo is offline   Reply With Quote
Old 05-15-2013, 10:58 AM   #18
steelvulture
Drives: 2012 Yaris
Do the parts listed in the main post also work for 2012+? If not, are there any parts that would work for 2012+?
steelvulture is offline   Reply With Quote
variable intermittent wipers thebarber Cosmetic Modifications (Exterior/Interior) 27 10-18-2022 03:26 PM
DIY Variable Speed wiper stalk install DanQ DIY / Maintenance / Service 27 08-03-2017 07:22 PM
Florida Yaris Roll Call: Part 3- Post Hacking! Sabretooth Southeast 81 05-22-2009 10:39 AM
Making Intermittent Rear Wipers ttufrosty Cosmetic Modifications (Exterior/Interior) 1 08-12-2007 10:57 PM
