Is now a Corolla S Owner
Got 37.78 this time. Overall average up to 37.07 now.
Tom |
![]() Drives: 2009 3 Door Join Date: May 2009
Hey guys, new to the forum and to getting good mileage! That's why I bought the Yaris! I bought mine a week ago and half of the tank was spent without a scanguage and included some speeding on the highway, the other half was around town in 40mph areas with a few number of lights spread around. That first tank netted me 40mpg assuming that the dealership filled it 100%. (409 miles and 10.025 gallons).
Currently I've had some trips in the 50's and today I managed a trip back home at 61.1mpg! A large part of this is due to timing the lights properly and being able to use the DFCO while coasting to red lights that I needed to take a turn at. Congrats to the OP on a solid first tank! I strongly suggest the SCANGUAGE II because it has honestly made a difference in my driving habits and I hope to continue with some nice numbers. Once I have to do some highway driving, however, I'm sure my average will drop, but I'm hoping to get this second tank of gas into the 50's if at all possible. I deliver pizzas on the weekend and sometimes during the week as well, so if time becomes an issue at work it is unlikely that I will be able to P&G my way to a customer's house. |
Steals terrorist's lunch
Drives: 2007 Yaris Liftback Join Date: Mar 2007
You're off to a great start, perfecto.
It sounds like you researched some of the FE techniques before you purchased.As for pizza delivery, I know time is a factor but no shop gives a timing guarantee anymore, and hypermiling adds so little time to most routes that I bet you could still rock the MPG.
- Brian Share the Road I often carry 2 carpool passengers and mountain bikes or snowboards/skis over a 4,500 foot elevation difference. Click the graphic above to see my detailed mileage logs. |
OK, my gas mileage has leveled off and has been very consistent over the last four tanks. I'm still hoping for higher numbers after break-in, but right now it looks like my normal driving is going to yield between 37 and 38 MPG. The range for the last four tanks has been 37.0 to 37.8, with an overall average of 37.3.
I'm still very happy with this little car, and it is a joy to drive. Tom |
![]() ![]() Drives: Yaris 5 door Liftback Join Date: Oct 2008
In tried to relax my driving with my last fill up and yet I am still getting 29 mpg. It's 90% city driving, but I thought I may have been able to do better with all you guys hitting such lofty numbers.
#6 | |
Tom |
#7 | |
![]() I wish I had a commute like that. I spend about 120 seconds on the highway each weekday and then it's all local from there. I probably do even more than 90% city driving. But it's never really bumper to bumper, just a lot of lights, which makes me a little disappointed in my numbers. |
#8 | |
Nothing beats a Toyota!
Drives: 2013 Yaris 5 dr liftback Join Date: Jan 2009
Big Dave Indianapolis, IN Synthetic Oil....its in my car.....for at least 10,000 miles! ![]()
![]() ![]() Drives: S sedan Join Date: May 2009
29 mpg in the city seems pretty darn good to me... especially in NYC! :)
Well, DC, I hope you will learn to be satisfied with that 29 MPG or that you will figure out some way to improve it. That really is not a bad figure for city MPG at all.
I hope you get a chance to get out of town and see what that puppy will do on the highway. Keep us posted. Tom |
![]() Drives: '08 Yaris LB 5M Join Date: Nov 2008
Voodoo22,
How many miles between cold-start cycles are you running? I live in the exurbs and commute into the outer suburbs via 2 lane county roads. I'm close to tank averages of 47 MPG but wonder if it can really get much higher with basically a cold-start cycle every 23 miles. As others have noted, the cold-starts are a big MPG killer. |
#12 | |
![]() ![]() ![]() ![]() Drives: Yaris Sedan (auto) Join Date: Jun 2007
averaging 47mpg is fantastic. With numbers like that you don't have much margin of error to gain more, but I'd wager you could get it over 50 at least some times. If you aren't already, try accelerating slower and keeping your speed under 55mph if possible. Supposedly 45mph is the sweet spot. I generally go between 50-55mph on the hwy I travel. My commute is 52kms or about 32miles each way. The cold start is definitely a killer. I've really put a lot of effort into combining short trips udner 20 kms together or not driving all together when possible. When I recently got my best tank ever of just over 55mpg, I had virtually no short trips that tank, like the 2 km drive to pick my wife up at work. From what I've read written by people with scan gauges, it takes about 23 kms or 14 miles for our cars to warm up into the optimum operating temperature range. |
![]() ![]() Drives: 2008 Yaris LB 5M Join Date: Oct 2008
Voodoo is correct again! Except part of “If you have a MT you can go faster and use more elaborate techniques” We can use more techniques but we can not drive as fast, the manual transmission has higher rpm’s for any given speed.
45 to 50 mph is the sweet spot I found, depending on terrain. If it is flat, 45 all the way! At 40 mph you have nothing to accelerate with and need to downshift. If there are rolling hills you will need to press 55 mph at times, bleeding to 45 or 50, to make sure you have momentum to make it over them. 50 is a good all around cruising speed, you can accelerate if needed without flooring it. I have to do 55 on the highway because of traffic and the speed limit is 65 mph. It took me 23 tanks to break 47 mpg, you are doing great! How have you accomplished that, what are your driving techniques? A big gainer for me is in the first part of my 30 mile daily commute the back country roads are free of traffic most of the time. I can shift and let the car ‘idle’ along at the high idle 1,500 rpm’s in 5th gear. Within a mile I can be up to 55 mpg but, there are small rolling hills and in 1.5 miles I am around 35 mpg. Accelerating as slow as you can stand is also a big gainer. There is no need to shift to a higher gear and lug it, the SG actually reports lower mpg’s doing that. I can ‘feel’ when it is time to shift, you will notice no more acceleration in that gear without pressing much harder on the gas than you did to get to where you are (the speed you are currently at). Not sure of the rpm’s at each shift, I just go be feel. But, using the SG2 I rarely go over 3,000 rpm’s on any commute. Sorry to hijack from Tomsters original post. Give it a couple tanks Tom, my first one was way low as the dealer did not fill completely. |
#14 | |
Thanks for posting such definitive information, it's stuff like that which helps out everyone interested in better FE. |
#15 | |
![]() ![]() ![]() ![]() Drives: 2014 yaris 5 speed Join Date: Aug 2006
rarer than JDM -1 of 1!
If this is true, and most of my driving is under 14 miles per leg, then i must say that i'm getting pretty good results. One could only imagine how i'd do on longer trips, and with less traffic and crazy drivers. There are 597 square miles on this island, only about the size of houston, tx. But our population is close to a million! Traffic, congestion, ahh it sucks.
I have an 08 sedan with the TRD 18's and I get between 36 and 39 mpg, depending on how much highway traveling. Other than taking the snorkel off of the stock intake, there are no other performance mods.
Half a Bubble Off Plumb
I got a striking demonstration of how much the air conditioning sucks mileage down yesterday. It was a 90° afternoon, and I had the AC turned on full blast when I left the office, something I've seldom done. There's a little stretch of 55 MPH highway before I come into town, and the speed limit drops to 45 near the bottom of a hill just before starting up again. I normally come off the gas before the advance signs that the speed limit's about to drop, and it goes into DFCO, but the hill keeps it coasting near 55 until it starts back up the slope, and the car goes way up the slope before getting down to 45. With the AC compressor maxed out, it slowed to 45 by the bottom of the hill before starting back up. Huge difference! I've heard people complain about the Yaris' AC being marginal, and it is when the car's been baking in direct sunshine in hot weather. But it draws a lot of power off and you really notice that a lot more in a little car with a ~100 HP engine than you do in a big sedan with an American V8 or turbo. I've said before that I'd be happy with the 1000cc engine, but I think it wouldn't be able to run the AC and maintain decent normal driving performance.
| Yaris Curb Weight, difference LB vs Sedan | CASTREX | General Yaris / Vitz Discussion | 14 | 12-12-2006 10:50 AM |
