#1 | |
![]() Drives: Charcoal '08 sedan Join Date: Sep 2011
The yaris has cable-pull locks so you need special brackets to hold the cable sheath stationary while the actuator moves the cable (see the first post). That's what all the parts are for. Good luck. |
![]() ![]() ![]() Drives: Flint Mica Sedan Join Date: Oct 2008
Bought this kit and it came today. Took me four hours to do the first door, lol. Do the doors not lock or unlock after you have the kit completely assembled and tightened down? I only have the rear left door done, and the lock doesn't move when trying to do it manually.
Well I got all my actuators, etc working. My question is. Where did you connect the red power wire to? The battery or is there somewhere under the dash I can connect it?
Basically I can't figure out which open spot in the fuse box, under the dash to use to get the constant 12v of power.....???
Check out my remote start DIY for a good location for a high current constant +12:
http://www.yarisworld.com/forums/showthread.php?t=24860
hell might as well fatmat that door for a quieter ride ;P
Well I finally finished installing the power locks and keyless entry. So far so good. Just hoping the lock cable doesn't snap anytime soon.
![]() ![]() ![]() Drives: 2007 Toyota Yaris Hatchback Join Date: Sep 2012
How much more difficult is it to install the security system if I ordered the package from A1electric with it?
http://www.a1electric.com/Merchant2/...Code=W01F-740T |
#9 | |
#10 | |
At the same time, am I biting off more than I can chew?
#11 | |
![]() Drives: 2009 Yaris hatchback Join Date: Nov 2017
Did anyone try to use original switches with this after market kit? Where can I get wiring schematic for the master switch?
Thanks Sent from my iPhone using Tapatalk |
| Questions and advice required about power upgrading(windows & locks) | W.A.S.P | DIY / Maintenance / Service | 10 | 07-22-2009 02:59 AM |
| Need Help - Electrical (finding Power) | Ayka | DIY / Maintenance / Service | 7 | 10-12-2006 11:51 AM |
| The power upgrade thread | ChinoCharles | DIY / Maintenance / Service | 19 | 09-27-2006 03:14 PM |
| Custom Sub Enclosure (inc sub, power cap, amp) | wado | Items for Sale by private party | 3 | 09-18-2006 11:53 AM |
