^ correct, and thanks mrbond for the correction, rain keeps things clean
pretty sure these will require larger rotors, so your 15's are going to be iffy.
#3 | |
Not really here...
Drives: 2008 Blazing Blue S hatchback Join Date: Oct 2008
+1! 15's and BBK's do not go together.
Liberate Tutemet Ex Infernis. |
![]() ![]() ![]() Drives: Polar White Yaris HB Join Date: Dec 2008
Oh well, I guess I will have to keep on looking. Perhaps some nice strong Camry calipers!
![]() ![]() ![]() ![]() Drives: 2008 meteorite hatchback Join Date: Nov 2008
Unless it's the mini or micro bbk by Project Mu :P Then you can run 13 and 14" wheels
- HOOOEY! That's one tahny little cawr! What the heck kinda toy is that? - A Toyota Yaris - A whut Yaris? |
#6 | |
![]() ![]() Drives: 07' HB Black Join Date: Nov 2008
thanks in advanced
When life passes you by ... dowshift
Beast
ok unless i didnt read thoroughly... excuse me, alright wilwood does have a 4pot brake kit for the yaris, so does endless.. unless you guys are talking about someone else?
![]() One you've taken a yaris for a spin, there's no turning back. Its a Chao!!! |
^ this is true, however you're going to be paying big big bucks for something you can piece together yourself for less.
Beast
ah kk
For braking power, which means to me resistance to fade and stopping distance:
pads + lines + fluid
#11 | |
Apexing Egg!!
Do you guys know the purpose of a big brake kit? no big brake kit will make you stop FASTER. The brakes are limited by the grip of the tire. What is the best brake upgrade then? TIRES!!! if you can lock up your tires while braking, the brakes are at FULL stopping capacity!! Does this make sense? So why do people do big brake kits? well, i know i did it bc i thought it would make me stop faster, but i learned better. What a big brake kit really does is allows you to absorb more heat!! brakes are heat sinks! If you are tracking and using up all your brakes, and they cant cool quickly enough, you need to increase the air to them, or increase their heat capacity. So you can use more metal, or ducting. So big brake kits have a significant advantage in heat capacity, and that is ALL. that is their only advantage. They typically weight more (unsprung none the less), which slows you down if you are not overheating your stock brakes (doubtful.) They also cost alot. That money would be better spent at a track school and autoxes where you learn to drive what you have FASTER and then you are quicker no matter the car or equipment you own. The list garm just posted will satisfy 99% of the braking needs for guys on this forum. I have tracked my car, autox'd it, and have had no brake issues (with stock pads and fluid with 60k miles on them!!) The car is so light, they are gentle on the brakes. This car is very easy on its brakes. In fact, i would almost worry that some of the high end temp pads that carbo tech offers through micro image could be tough to keep heat in! I may test this at the next event, do brake temps during a 20 min session and see what they peak at. Now a rear disc upgrade, i would do that. Drums suck.
HighTach Motorsports 2007 Toyota Yaris-ARGH!! Mods: Tokico HTS, 6.6 kg F, 6.1 kg R custom springs, 23 mm RSB, 2-way TRD LSD, 15x7 +25 Team Dynamic wheels, 195/55/15 Dunlop Star Specs, Cobra Suzuka S |
#12 | |
Apexing Egg!!
good! glad to help!
![]() ![]() ![]() ![]() ![]() Drives: red bare bone yaris hb 3dr Join Date: May 2009
+2 ,
bbk for me is for the look purpose, since I'll be using 19" very very soon. |
meanwhile, back to this idea. These calipers are way too thin for the Yaris rotor. I have now matched a 4-pot Wilwood caliper to the stock Yaris rotor and ordered a set. Did I mention I'm a Wilwood dealer now? heh. next is the brackets (one for stock + one for oversized rotors), then lines, and we are good to go.
Garm,
which wilwood 4 pot are you using ? put me on the list for the oversize setup .... Tan |
This is going to be exciting to see on some 15" rims
| DIY (sorta) - RunStop Rear disc brake conversion | eTiMaGo | DIY / Maintenance / Service | 17 | 07-02-2019 08:24 AM |
| Rear disc from xD or new xB | kngrsll | Performance Modifications | 20 | 04-01-2009 06:17 PM |
| Rear disc brake conversion installed | Brian | Performance Modifications | 49 | 03-04-2009 11:45 PM |
| Catback exhausts and rear disc brake conversions | eTiMaGo | Performance Modifications | 59 | 01-04-2009 06:13 PM |
