Old 08-10-2009, 09:11 PM   #1
Qmobile
that's right I went there
Qmobile's Avatar
Drives: '08 Blazin' Blue,'10 Dark Red
from what I've seen pretty darn
Mods: 15" SSC rims, TRD Exhaust, TRD Sway bar, TRD oil filler, TRD rad. cap, TYC tails, Debadged, Painted engine cover, Stock spoiler, Stock mud gaurds, OBX pedals.
suggestions always welcome
Qmobile is offline   Reply With Quote
Old 08-10-2009, 09:25 PM   #2
R2D2
Crazy Oil Sniffer
R2D2's Avatar
Mine has always been within .2-.7 mpg. Today after fillup it was within .3 mpg of the "pump method" calculation.
Plenty accurate, user friendly and fun little tool to save fuel! If something happened to mine I'd have another by the end of the week!
R2
-The Fitful One
Old 08-11-2009, 08:50 AM   #3
DevilGirl
Drives: 09 3dr LB MT
Can anyone who has one of these tell me if, when viewing it in the "rpm" mode, if the "analog" style meter shows the rpm's as well, or if it is only the mpg's it will do that with (saw the you tube vid of someone from mpg-o-matic doing a test drive of a charger/challenger, can't remember which). I'm really looking at one of these so I can have a tach but also the mpg readout. I like the old school analog tachs better than the digital ones.
Old 08-11-2009, 10:05 AM   #4
Revsson
I agree with you DevilGirl.
It would be nice if you could set the outer LED ring to act like an analog tach while
having the digital readout show mpg.
I gathered, from that same video you saw, that it wouldn't work like we
wanted it to.
Maybe CTScott could mod it?
Old 08-11-2009, 10:18 AM   #5
DevilGirl
That would be a nice mod for it.
But I was referring to when you are viewing it showing rpm's (like it says you can on the website, even though all the pics only show mpg's), if it is only the digital readout or if it is also the LED ring. If it's both while in that "mode", I'd get it. I can always press a button and find out the mpg's. I'm more concerned with the rpm's right now until I get more used to driving stick every day (this is my first stick shift car). Though I must say, I am getting better. Only two days of my commute put on the car, and stalled once yesterday mornin, once yesterday afternoon, and not at all this morning.
Old 08-11-2009, 11:55 AM   #6
Qmobile
Qmobile's Avatar
yeah in RPM mode it shows you by light/numbers what your doing also I've found that in speedo mode/mph it's a lil SLOWER than the stock speedo is'nt that nutty?
Old 08-11-2009, 05:00 PM   #7
Sodium Duck
╚══════════RN
Sodium Duck's Avatar
Drives: 2008 Liftback
I'd bank that the Ecometer is more accurate than the speedometer. When viewing the speedometer, you should actually add 2 or so MPH, because we are looking at it from an angle since it is in the middle. If you were to look at it straight on fromt he center of the vehicle, it would be accurate. For example, from the drivers seat when I think I am doing 30MPH and the needle is dead on it, if I lean over to the middle and look, I'm actually doing about 28MPH.
However, at "10MPH" on the speedometer, the Ecometer reads about 14MPH. I trust the Ecometer better. Above 20MPH, they seem to be the same. (at my work the speed limit is 15MPH and they are really anal about it)
Old 08-11-2009, 06:31 PM   #8
daf62757
Nothing beats a Toyota!
daf62757's Avatar
Drives: 2013 Yaris 5 dr liftback
I use my Tom Tom for a speedometer.
Big Dave
Indianapolis, IN
Synthetic Oil....its in my car.....for at least 10,000 miles!
daf62757 is offline   Reply With Quote
Old 08-12-2009, 01:34 PM   #9
DevilGirl
Yet another question in the search for a tach for my 09... I like the idea that the Scan Gauge gives you a lot more output for the car (mostly standard stuff that I'm used to seeing on a gauge cluster), but I'm concerned about the size of the readout. 5" wide by only 1 1/2" tall? That seems small to me. Is there possibly a similar model that has a larger readout?
Old 08-12-2009, 02:01 PM   #10
Woody_Woodchuck
Drives: 2008 Yaris LB 5M
I thought the same thing, especially with having 4 gauges displayed at the same time. It is easy to read at a glance and I have not had troubles looking at one gauge and reading it.
The problem is it only updates every… 2 seconds I believe, in fast mode so you are not getting all the readings. Best bet for a functional tachometer is to buy a dial one. The SG suffices to check the rpm’s while crusing.
Lifetime log
Woody_Woodchuck is offline   Reply With Quote
Old 08-12-2009, 02:06 PM   #11
DevilGirl
A dial tach would be a better bet for me, but then I'd have to drill holes. Not something I want to do at the moment. Plus I like the option of having the other information (MPG usage and all others available)... I'm at such a loss for what I want. I don't want to spend the money on something I won't like after a short period of time. And I doubt I can find a dial tach that won't require making extra holes...
Old 08-15-2009, 11:57 AM   #12
wingdood
Drives: 2009 Yaris 2 Dr HB
does anyone know if the Ecometer's tach updates slower or faster than the Scangauge's?
wingdood is offline   Reply With Quote
Old 08-18-2009, 04:37 PM   #13
Henry G.
Drives: 2008 Yaris HB
Scangauge updates every 1/2 second in fast mode, pretty darn good. Its way more product for the money IMO.
Henry G. is offline   Reply With Quote
Old 08-19-2009, 03:13 PM   #14
ezhacker1
ezhacker1's Avatar
Drives: Decepticon - Ravage
therefore, it is the same refresh rate as the Ecometer, both are 2x a sec.
Check out my Build thread:
Old 08-23-2009, 10:24 AM   #15
Henry G.
Cool. Does it monitor everything else too and clear trouble codes? If so its a bargain....
Old 08-12-2009, 04:22 PM   #16
R2D2
Crazy Oil Sniffer
R2D2's Avatar
DevilGirl,
I'd recommend the Ecometer if you want an easy to install tach-it's easy to see, easy to install, non permanent and fairly inexpensive. I think it works very well. The major reason I bought mine was for the tach but I'm so hooked on the instantaneous mpg that's all I usually use! You still can see the ecograph with the tach though. If it's not to your liking I bet you can find someone to buy it!
R2
-The Fitful One
Old 08-12-2009, 07:23 PM   #17
gammaray
gammaray's Avatar
Drives: 09 3D Liftback
I still find this gauge very amusing, and so does everyone that gets in the vehicle with me. Unless it fails to work at all anytime soon...its the best purchase Ive made in a very long time. Well, besides the Yaris that is.
gammaray is offline   Reply With Quote
Old 08-12-2009, 09:46 PM   #18
Qmobile
Qmobile's Avatar
me 2 when I was on my way home from Jegs I was like chewing people out b/c I was get 50mpg AND still going th speed limit........that was a fun drive kinda long but fun
