Old 07-21-2010, 03:59 AM   #1
just a heads up, the Ecometer is $59.95 in my store with free shipping.
Old 07-22-2010, 12:22 PM   #2
KrazyDawg
KrazyDawg's Avatar
Drives: 08 3dr LB AT
I'm looking into getting this cup holder mount so I can easily remove the Ecometer.
I found it for $11.84 on Walmart. http://www.walmart.com/ip/Bracketron...Mount/14248250
The other alternative was getting a flat mat. http://www.newegg.com/Product/Produc...82E16858999148
KrazyDawg is offline   Reply With Quote
Old 07-23-2010, 03:08 AM   #3
caineroad
caineroad's Avatar
Drives: 06 Yaris HB CE
can someone tell me where is the odc II port located? thanks
Old 07-23-2010, 09:04 AM   #4
STC
"LibertyRides!"
STC's Avatar
It is on the left side under the dash in front of the fusebox.... Next to the interior hood pop-up latch.
Cheers!
~ Mark ~
Old 07-27-2010, 01:38 PM   #5
KrazyDawg
KrazyDawg's Avatar
Office Depot sells the clear 3M Dual Lock strips if you need more for under $3. My initial install wore off the adhesive since I didn't apply it long enough and I remove the Ecometer from the dash on a regular basis. In my opinion, the included 3M Dual Lock works better than velcro. It "snaps" into place and looks more durable.
Old 01-10-2013, 10:07 PM   #6
nookandcrannycar
^^^^^ This. They are fantastic. I have been using them for at least 10 years. When you do apply enough pressure for a long enough period of time, the mount is rock solid for years on end. I currently have one strip on each side (driver and passenger) not too far from the lower corner of each side of the windshield. These were two previous locations for the little square antennae head for my XM radio (when I had that hooked up). I left the 'dash side of the lock' in place on each side to occasionally use with other accessories. I've found it is best to make sure any aftermarket protectant has been removed from the mounting location prior to mounting. I've always purchased these at Radio Shack for less than the amount you stated, but now I can't find them on the Radio Shack website. Good to know that Office Depot has them.
Old 09-13-2010, 05:12 AM   #7
ezhacker1
ezhacker1's Avatar
Drives: Decepticon - Ravage
Bumping up my thread cuz its already filled with so much Ecometer info.
I have proven at least one so far that, the Ecometer is accurate to 0.002% (too high) on stock intake. On the AFE dry filter type 2 short ram it was consistenly ~10% too high AND using more fuel.
On my latest fill up (10.119gal/last bar blinking), i got
34.2mpg Reading / 34.12mpg actual
Compared with AFE
~35.6mpg Reading / 32.7mpg actual
I never touched the eco-meter settings. so the only thing changed is the airbox replaced, one thing to note is i ran these two tests on stock size tires, the 185-60-15 flavor, reset ECU, cleaned MAF sensor with MAF cleaner spray, mix of Neutral/DFCO. Ironic enough I also drove much more spirited on the stock box, and dropped .4mpg cuz i idled to power my sub when i was doing some settings.
I have no idea why the eco-meter reads higher value than actual with more air, which should equate to more fuel burned. So there you have it, stock air box/TIRES = perfect accuracy.
Ill do another tank on stock box, to prove without a doubt. Tho it sucks to roll on steelies...
Check out my Build thread:
Old 09-13-2010, 11:36 AM   #8
KrazyDawg
KrazyDawg's Avatar
Compared with AFE
I have a K&N air filter, stock tires, and steelies but my ecometer EFF was adjusted to 94 to make it 0.2% accurate. I also run my tire pressure at max sidewell of 44 PSI.
Old 09-13-2010, 05:49 PM   #9
ezhacker1
ezhacker1's Avatar
That's helps prove my point. Pretty sure at stock setting the eco meter would give you higher than actual. Plus I got to .002% 1/5th a percent. I'm gonna try to drive as conservative as I can this tank, then good bye steelies
