Old 11-07-2010, 07:01 PM   #1
JumpmanYaris
USAF_SrA_E-4
JumpmanYaris's Avatar
Drives: C300 / Del Sol
uuuffff cheveron yo le pinte los projectores de negro lol
Originally Posted by sw07gt
Old 10-11-2010, 12:49 PM   #2
were you careful to install the left side on the left and the right side on the right?
Old 11-29-2010, 02:25 AM   #3
crolandiz
Drives: Yaris Sedan '08
Hi, I bought proyectors on eBay, how can I know which one is the left/right side proyector? and How can I adjust the cutoff?
Thank you.
PS:Jumpman, tu auto esta de lo mejor, tambien pintare mis proyectores de negro, que pintura usaste? que le pusiste antes de pintarlos?
crolandiz is offline   Reply With Quote
Old 01-14-2011, 02:13 AM   #4
crolandiz
Condensation
Hi, I opened my headlights, paint and install the projectors. After 3 weeks, water or condensation appeared in the left headlight, remove the headlight for two days I let it dry and apparently went all the moisture so I went back to put silicone around.
Wash the car today morning and in evening note that the two headlights had moisture in and also the left angel eye is not starting.
What do you recommend or suggest? How can I solve this problem and prevent the more moisture?
Thank you.
Old 01-14-2011, 02:22 AM   #5
Thank you.
Make sure you push the lens into the housing all the way, and that the three screws all screw into place (one of my screws in each headlight won't screw into place, so I'm thinking that's what is causing my condensation problem). Also, the portion of the housing that engulfs the lens, make sure that's pinched down onto the lens.
Old 01-08-2012, 10:46 PM   #6
JumpmanYaris
USAF_SrA_E-4
I can't remember the size of the bulb for this projector, anyone
Old 01-08-2012, 11:08 PM   #7
D2H, I believe.
Old 01-08-2012, 11:49 PM   #8
JumpmanYaris
USAF_SrA_E-4
Wow so basically there is no replacement ?
Old 01-09-2012, 12:12 AM   #9
None in stores. I ordered mine here: http://www.theretrofitsource.com/pro...oducts_id=4126
Old 01-09-2012, 12:17 AM   #10
JumpmanYaris
USAF_SrA_E-4
Hahahaha yeah I see
Lol
Old 01-09-2012, 03:54 PM   #11
jamal1984
The Beautification of Car
Drives: Toyota Yaris S
Send a message via MSN to jamal1984
We sell them here in state of GA. It's called G3 bulb i believe.
The Beautification Of Car Enthusiast
jamal1984 is offline   Reply With Quote
Old 01-09-2012, 09:55 PM   #12
JumpmanYaris
USAF_SrA_E-4
G3 is the projector
Old 01-10-2012, 09:50 AM   #13
jamal1984
G3 is the projector
yes jumpmanyaris, it's also they the name of the HID Bulbs, i think ebay sell them for $20. Search G3 Bulb on ebay.
Old 02-05-2012, 04:13 AM   #14
menz
Drives: yairs blue 2007 automatic 1.3
guys i just installed HID 6000k last weekend and i noticed the glare and i think i am blinding the other drivers. This thread is talking about HID+projectors kit at once. Can I install projectors only so I don't have to buy the whole kit? any help asap please. I asked a friend of mine and he told me that the people who do it in our country will not do it correct to change the headlamps to have projectors in it. He mentioned that it needs to be aligned or something that I have to align the projectors itself. Any help would be appreciated.
menz is offline   Reply With Quote
Old 09-07-2009, 02:36 AM   #15
Brian
Brian's Avatar
Thanks. I plan on getting a new set of headlights in a few months cause mine have taken a beating the last couple of years from rocks and the clear protectant is beginning to wear off on the lens. When I do I will get some better pics of the install. All I had was my phone at the time. I'm very happy with the outcome though and love the blacked out look.
Old 10-12-2009, 12:00 AM   #16
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
Thanks for that . just trying to show the suppliers that the cut off
does not suit right hand drive cars
Old 10-12-2009, 01:33 PM   #17
Brian
Brian's Avatar
Originally Posted by camelll View Post
Brian, you should adjust that drivers side, you will see a huge difference in the way the road lights up. I am surprised you got it to go that low without popping the adjustment screw out of the socket behind the reflector bowl. I did that on mine and I was not even close to that far down, I could not go any lower than the drivers side you see in the 4th pic and right below that I popped the adjuster screw out. Had to reopen the headlight and fix it, was kind of a pain in the butt.
I will lower the passenger side when I get a new set of headlights in a few months. I didn't want
to cut into the reflector housing at the time to lower it more. I was surprised too at how low they
came out.
Old 10-12-2009, 04:52 PM   #18
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
1nz the housings these projectors came in were RHD. The cutoff shield is for LHD but the RHD housings were rotated so the projectors shined up on the left. I don't know if yours is the same or not. It may be hard to understand what I am saying so I will post a pic of the cutoff in the RHD projectors and hope this helps.
The first pic, 3 black circles shows how the h4 grooves are rotated to the right allowing more light to shine on the left and less on the right. You can see the cutoff shield how it is angled. The shield is on the bottom but when the light comes out of the projector it is upside down. The housing was sitting flat for this pic.
2nd pic is the housing sitting flat so you can see how the cutoff would look in a RHD housing. This would probably work without blinding oncoming traffic but the proper way would be to have the cutoff shield going the opposite direction, I don't know if they make these or not. Would need to ask someone who has stock hid in RHD housing.
3rd pic is the same projector in a LHD housing, 3 black circles show how the h4 grooves are flat. It looks like it goes to the left but it is because the whole housing was rotated when I took the pic, but it is not rotated left or right. I hope this helps. If you have any more questions you can pm me or post in here if brian does not care.
Thanks for that Camel , but if i can't get the right cut off , then it's not worth the risk .
i do to much night driveing , to take short cuts on lighting ,
not to mention the fact it would not get a road worthy cert like that .
which it requires to pass every 12months .
DIY Sedan Spoiler Install Kaotic Lazagna DIY / Maintenance / Service 36 01-19-2020 11:35 PM
How To Smoked Sedan Headlight -DIY zulhizainL902S DIY / Maintenance / Service 26 01-14-2011 02:12 AM
DIY needed for amplifier for sedan install YarisSedan In Car Entertainment + Electronics (audio / video / alarm) 2 02-27-2009 10:07 PM
DIY Sedan Spoiler Install Interest? Kaotic Lazagna DIY / Maintenance / Service 28 09-11-2007 11:02 PM
