#1 | |
toyota
Should be more worried hitting your gas tank... So I've heard.
If my calculations are correct, when this baby hits eighty-eight miles per hour... you're gonna see some serious shit!!!!!! "Horsepower is how fast you hit the object. Torque is how far you move that object.." |
Ive taken my rear lower tie bar few days after doing this mod due to it hitting it on bumps.
Ive only hit my gas tank maybe twice and only on a really huge bump with the car really loaded when i had my factory shocks. Once switching to tokikos i havent had issues since.
Are you on the Blues or Reds? Also, I'm lower than you and only on TRD shocks, so it's not as dampened as yours =\
![]() Drives: 2007 Red 5dr RS Join Date: Mar 2012
Sorry to revive a 10 month old thread but I just got a Yaris LB with M2 lowering springs and am interested to see if anyone can provide any long-term update on this mod.
1) Any solution to the rubbing talked about in this thread? 2) Are you using aftermarket struts/shocks? Thanks |
![]() ![]() ![]() Drives: 2009 3dr LB Manual Join Date: Mar 2010
I've been running this mod for over a year with well over 40,000 miles of Michigan roads. I have stock shocks and DF210 springs. The rear springs have rubber inserts to stiffen the back up. The inserts fixed the rubbing of the suspension member on the fuel tank. Also, when I took the car in for an alignment, there were no changes that needed to be made.
![]() Drives: 2009 3rd Polar white Join Date: Apr 2011
I moved mine back to the stock holes until I could get some bump stops. Then I started autocrossing the car and I really like how the car handles as is, so I decided to leave it. It enters the corners very predictably and if I trail brake int the corner I can get the rear to rotate for me. When the rear rotates, it is so controlled and predictable that I didn't want to take the chance of messing that up. By the way I have a 2008 3door LB with Megan Racing coil-overs, UltraRacing rear brace, and A rear swaybar that I think is 22 mm. For racing I turn the rear dampers all the wy up.
Only Happy When it Rains
so for those who have had problems, are your running a full interior or have you removed any rear interior pieces?
Colin Chapman disciple |
I am running stock interior, including spare tire.
www.yarisclub.gr
Drives: yaris 1.3 2sz - 1.33 1nr Join Date: Jan 2009
i think that the upper holes are for the 4wd version
Minimalist
Drives: 07 silver sedan Join Date: Jun 2014
Wait, what? AWD? Which country?
japan, and other countries that get Japanese cars. Toyota, and other Japanese car companies give their home market a hell of a lot more toys than they give us.
#15 | |
Minimalist
Anyone know how much heavier the AWD version is? |
![]() ![]() Drives: Toyota Yaris 1.33 SR Join Date: Nov 2014
Anyone knows if this mod is possible also on the 3rd generation Yaris? I saw the hole, but i don't know if it's threaded inside like the 2nd gen
it's not that big of a deal if it's not threaded, just get the ol' tap and die set out and make it so...
Alright, I'm bringing this thread back form the dead with some hopefully helpful hints and updates.
I stumbled upon this thread last week and switched my axle yesterday. I am currently running MI lowering springs and Tokiko Blue's in the rear. I have a custom exhaust that already hit the axle (I'm getting a new one made in a month) so other than the axle still hitting the exhaust on bumps, there doesn't seem to be any extra impacts (gas tank etc). The rear end feels like it is sitting much lower when I am driving the car and the turn in is much more improved. It's too the point where I found myself over turning on high speed sweeping turns like off ramps. The car doesn't actually sit any lower, it just feels this way. The rear suspension also feels slightly stiffer now and the highway stability has seemed to improve As others have stated, this likely changes the toe of the rear to proper factory specs which improves it's planted feel and turn in. The increased stiffness likely has to do with the angle that the springs are now compressed in relation to the pivot point of the rear axle. These are my alignment specs from a month ago ![]() If you are doing this mod I'd recommend a tap to clear out the rusted threaded hole. I have an '08 and at first I thought that there were no threads. Turns out rust and oil spray were covering them and the bolts wouldn't thread it would just spin. The bolts have a 1/4" or so of threadless space at the tip which was the reason it was just spinning. The bolt threads couldn't grab the threads in the hole since they were all gummed up. The threadless part allows you to safely tap the bolt into position if need be without damaging the threads, just don't go ape on it. I didn't have a tap of the correct size so I use a ton of PB blaster to push out any dissolved rust as well as a long air nozzle to spray out any loose rust. I put anti seize on the bolt and used a ratchet to slowly tighten a bit and loosen a bit. Then I'd remove the bolt and flush it with PB blaster. This took about 20 minutes a side (didn't want to damage the threads) but if you had a tap it would take 2 mins as the rust would have a place to go in the grooves of the tap instead of jamming up the threads. I figured out a convenient trick to getting the axle bushings lined up with the new hole. I used an extra axle stand and a long pry bar, the axle stand gave me a fulcrum where there previously wasn't one. I had the car sitting on jack stands and a jack was placed under the center of the axle so I could move it how I wanted. I then used the pry bar and the bolt to line up the hole. I covered the whole bolt in antiseize before I reinstalled them. Torqued them down to 62 ft/lbs when I put weight on the axle via the jack. ![]() ![]() My bolts were in good shape when I pulled them out, minimal to no rust. I covered the old empty hole and areas around with an anti rust spray ![]() All in all I'm happy with the mod, especially since it cost nothing. For anyone with a 2010 or higher who said they don't seem to have threads. Make sure you spray out the hole with a penetrant and stick your finger or something to actually feel for threads. I almost convinced myself that mine didn't have any with how much crap was on them. Worst case scenario you could always use a tap and cut your own.
| When will the Yaris hit the showrooms at dealers? | Petrolhead | New YARIS Purchase Forum | 181 | 11-28-2011 08:03 AM |
| Any Yaris hatch rear suspension tweeks? | woof | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 26 | 12-05-2009 07:04 PM |
| Hyperco 5.5" single pigtail rear spring test | kngrsll | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 33 | 06-15-2009 11:11 AM |
