Old 01-21-2011, 08:01 PM   #1
sqcomp
Roadrunner Jr.
sqcomp's Avatar
CA-There used to be a DIY for the headliner...I took my DIY off the site. I'm not sure if Derick has taken his down.
The purpose of the matting is to reducs vibrations and absorb sound.
― Thomas Paine
Old 01-21-2011, 10:23 PM   #2
sqcomp
Roadrunner Jr.
sqcomp's Avatar
D,
You know you can holler at the boys at the shop if you want some insight for a box. I know we just made a vented box for two of the DD 1508's that will make your ears bleed with 1200 Watts (okay, maybe not bleed). The sealed applications are much easier though...AND they already have a Yaris sedan to model a box on! Also on the kicks, if you're using the same general space as I am, look at the sub frame holes by the front wheel wells.
Oh, a tease for you, I'm laying down a frame, fleece, and glass for my new sub enclosure. I'm flipping the sub to have the magnet out in the center of the trunk. That Mille's magnet is SECKS! We're also putting a whammy 60 Ampere power supply in the Yaris for shows.
― Thomas Paine
Old 01-21-2011, 11:40 PM   #3
derickveliz2
derickveliz2's Avatar
Drives: Yaris Sedan "S"
D,
Thanks I know, what I'm looking now is for a set of rings for the L6s so I can install them flush!
For the kicks, the sub-frame down the floor, right?
D.
CLA 250, 4MATIC
Old 01-21-2011, 10:51 PM   #4
packetrace
packetrace's Avatar
Drives: Yaris Sedan 2009
Derick!
How much you paid for your HL-70 ? and your tweeter ?
Interior:ALL red, black roof
Old 01-21-2011, 11:37 PM   #5
derickveliz2
Originally Posted by packetrace View Post
Derick!
Hertz HL-70 are around $180
Legatia L1v2 sell for around $220, I got them at DIYMA in the Classified section for a lot less than that. (o:
D.
CLA 250, 4MATIC
Old 01-21-2011, 11:54 PM   #6
sickpuppy1
Drives: 2010 Yaris Sedan
Quick, vague question. Just an opinion. going between a kenwood 2 channel amp or Pioneer both 60 watt . Think a pioneer would work better with the Pioneer HU I just bought or would it make any difference...I'm thinking sound quality wise is all.
Old 01-22-2011, 03:36 AM   #7
derickveliz2
Like SQcomp mentions above, no difference.
In that case I think the good sound will come from a proper installation, more than what amp to use.
D.
CLA 250, 4MATIC
Old 01-22-2011, 01:40 AM   #8
sqcomp
Roadrunner Jr.
sqcomp's Avatar
^ Not at all between those brands.
D,
Here's what the passenger's kick looks like under the stock panel:
Here's the same area with the wiring bundle relocated:
Whoa! Tons of room for a speaker!
― Thomas Paine
Old 01-22-2011, 03:42 AM   #9
derickveliz2
Post
D,
So you think its better to vent on the vertical panel than going down the floor...?
D.
CLA 250, 4MATIC
Old 01-22-2011, 08:17 AM   #10
sickpuppy1
LOL, thanks guys. And very diplomatic too! Its gonna be a budget system for sure. Just trying to maximize what I can with what money I have to spend on stuff. I was thinking of more the "sonic signature" some brand seem to display, clearity and such. But seriously, do you hear a big difference going to a higher end amp, I mean, that may be a loaded question, cause I know there is a big difference between, lets say my Denon receiver and a radio shack receiver, so ok I see that, but then there are alot of other components beside the amp section in a receiver that "color" the sound. And I also dont want to open up a can of worms for some of the folks who gave you shit in the past. So if youve used stuff in the bracket I'm talking about and when you moved up, what differences did you hear? I know going from one brand to another some times one seems brighter , one clearer, one more bass etc. Things I have often attributed to the preamp section quality and settings ,more than the amp itself. If its more comfortable, do it in a PM rather than here. I know both of you've been ambushed before,lol
By the way, where did you move that wiring bundle to? Is it tucked in behind the panel to the right or up above so it doesnt hang down? LOL, WTF did it go!
Old 01-23-2011, 01:10 AM   #11
derickveliz2
In my case, I went from an old Class D Premier (Pioneer) amp to a new Class A/B Power Bass amp. Yes there is a difference. And I like it.
D.
CLA 250, 4MATIC
Old 01-22-2011, 02:05 PM   #12
sqcomp
Roadrunner Jr.
sqcomp's Avatar
The individual amplifiers differences in sound are a result of several conditions. The most important thing to consider is that a Watt is a Watt. You'll ask, well why does one amplifier sound different than another? I submit that it is a difference in the crossover section, power supply, output device construction, gain settings (including real headroom), and other various little components like op-amps that all add up to a difference in sound.
Oh and if someone does want to give me a hard time, I'll just move on and not really respond. Everyone knows where to get a hold of me anyway...PM.
The wire bundle? Note, there's one on the driver's side as well. It's relocated up into the dash area. Also note, when and if you decide to take off your passenger's side A-pillar, there's a molex there as well. I killed that one off all together. I was more than an un-needed piece of plastic. The whole connector only help one wire as I remember and it was to the antenna (I don't listen to the radio anyway). All I did was to remove the two ends from the connector and solder them together. Whoa! What an idea! :) It saved me a 1/2" of room so I could put my L4 mids in the A-pillar on that side.
― Thomas Paine
Old 01-23-2011, 01:50 AM   #13
sickpuppy1
SQ, I was afraid we'd get some of the non constructive smart ass remarks like awhile ago and poof there goes a great source of learning for all of us. I hate it when it when you go poof! I'll keep and eye out for the wiring to when I start to put in some deadening. Source of rattles too. I'm not gonna go the super cheap route on deadening. I've read enough to know I'll end up with raamat, or some of the goodies from SDS (Dan). Interesting stuff over at second skin too. I'm intrigued by the Spectrum...any opinions on that? Havent talked with anyone who's used it yet.
Oh and Derick, I made sure the amp I'm getting is A/B also. Even at my price bracket I knew I wanted to go that route. Not that there arent good sounding class D amps, I know there are, just seems like they are mostly in high watt sub area's
Old 01-23-2011, 02:16 AM   #14
derickveliz2
To me there are 2 ways of deadening a car, one is oriented to improve the sound like in a sound studio (less rattles, absorbing materials) in other words... acoustically better.
The second one is to reduce out side noise (road noise, engine noise, tire noise, passing vehicles and trucks) most of it is when your car is in motion!
A good balance makes your sound system and your ride a much pleasant experience!
Go for it!
D.
CLA 250, 4MATIC
Old 01-23-2011, 02:26 AM   #15
sqcomp
Roadrunner Jr.
sqcomp's Avatar
Don't worry about me. I know that most don't mean to mess with me more than just ribbing. Sometimes I get a little short as of late. It's an "artifact" of me coming back from Iraq.
Deadening...
There's a wide range of choices. I've used several different mats and foams in my experience. I'm satisfied with what I run now. Stinger Roadkill Expert and the Stinger Overkill...that overkill is AWESOME stuff! You should take a look at it personally. Notice I didn't say buy it! Any advice I might give would be my opinion. It's not scripture.
I'm using a version of the spectrum sludge in my kicks right now (Lizard Skin). That will change with the change in speakers for said kicks as well. I'll either be purchasing a pair of L6 SE's or L8 SE's soon. I'm going to be using a "special" coating for the kicks and the sub-woofer enclosure. ...If you guys could see me smiling right now...
What is your price bracket for the amps you're using?
― Thomas Paine
Old 01-23-2011, 09:52 AM   #16
sickpuppy1
I ordered a little Pioneer gm3400t Saturday on line. Shortly after that I read your comment on possibly being able to get some brands at a really good price. Its the only amp I've ordered so far, but all I'm powering is a set of component speakers for the front end. They are rated at 50 watts per channel and I'll be getting 60, so I have a little head room. I will be getting a sub too, but in a little while....something in the 8-10 range probably as I want it to "fill in" the bottom and not thump my whole car. Plus I will travel with this car and want to save on trunk room
Old 01-23-2011, 04:04 PM   #17
_S7V7N_
_S7V7N_'s Avatar
Drives: Yaris 4 Door Sedan
Check out the digital design 8's.
Old 01-23-2011, 04:26 PM   #18
sickpuppy1
Couldnt find pricing on them anywhere, but when to the website. Look very nice. I'll bet their out of my price range,lol. I definitely have champagne taste and a beer budget,lol
