On a trek to upgrade...
Drives: 2003 Echo Coupe Join Date: Mar 2010
Question about calculating MPG
In the sticky at the top of the forum it says to divide your trip miles by the number of gallons it takes to fill up the tank again. But, logically, doesn't it make more sense to divide the trip miles by the amount of fuel you put in the first place?
If I were to be using the method I just described, would it make a big difference? |
Is now a Corolla S Owner
Fill the tank and set trip odometer to zero. Drive until you need gas again. Fill the tank again, and the amount of gas it takes to fill it the second time is the gas that you ran out while accumulating the miles indicated on the trip odometer. Divide that number of miles by the number of gallons it took to fill the tank the second time. Set the trip odometer back to zero again and repeat for the next MPG check.
You ALWAYS have to start with a full tank to check MPG. When you fill the tank the next time, that is how much gas you have used to drive whatever number of miles you have driven. Tom |
Steals terrorist's lunch
Drives: 2007 Yaris Liftback Join Date: Mar 2007
Over time you would end up with the same average so it wouldn't matter, but it's more logical to calculate when you have both variables at once (tank miles plus tank fill amount).
Your method would require tracking what you consumed on your last fill up for as long as the tank lasts, which for me is about 2 weeks in the summer. That's a lot of work to get the same result.
- Brian Share the Road I often carry 2 carpool passengers and mountain bikes or snowboards/skis over a 4,500 foot elevation difference. Click the graphic above to see my detailed mileage logs. |
#4 | |
![]() ![]() ![]() ![]() Drives: 08 Sedan Join Date: Oct 2008
#5 | |
Drives: '10 Yaris5drHB+99 4runner LTD Join Date: Sep 2009
and....for the most accurate measurement, [without using your own graduated cylinder] try to do this 3 times in a row, using the same gas station, same pump, parked in the exact same spot, and same time of day (early morning is best) for the most accurate mpg calculations. different pump handles shut off tolerance can vary by 1-5 tenths |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2008 Yaris Liftback (Sprocket) Join Date: Oct 2008
For a truly accurate fuel mileage, you need to average your results out over as long of a period of time as possible.
There are far too many independent variables to honestly know how well your car is doing with just one tank... Many, as you can see, use GasSavers.org to track their results.
I guess I've been doing it wrong. But, the good thing is that I've been keeping track in a little notebook, so all I have to do is reconfigure my equation.
Thanks fellas. |
The method you guys described actually boosted my MPG numbers. :)
Only Happy When it Rains
i think the most accurate way would be to get a scanguage.
and congrats on higher numbers. now what are they?
Colin Chapman disciple |
I'm considering a scanguage. The numbers were slightly higher now that I calculated the MPG correctly. My mean is in my sig.
Half a Bubble Off Plumb
A Scangauge is a good thing to have for showing instantaneous and trip mileage, which can help you to adjust your driving technique to improve your mileage. But what it's showing is actually an estimate, which you have to cross check against the real mileage figure you get from dividing the miles driven by the fuel you put in when you gas up. It'll probably be very close when you get the device programmed right, but not exact.
![]() ![]() Drives: 2008 Yaris LB 5 speed Join Date: Oct 2008
Scanguage is Great!
![]() ![]() Drives: 2007 Yaris Hatchback Join Date: Mar 2010
I use the Road Trip app on the iPhone to track my milage. There is a free version which is great but I ended up buying it cuz with the paid version you can export your data. Milage is just something fun for me to obsese over.
#14 | |
#15 |
Right.
Better MPG in the City vs. Hwy | Loren | Fuel Economy Forum | 21 | 01-29-2010 11:49 AM |
The Bars and MPG question | UncleMo | Fuel Economy Forum | 34 | 11-03-2009 09:19 AM |
My progression into hypermiling | BailOut | General Yaris / Vitz Discussion | 8 | 10-13-2009 06:31 PM |
Anyone from Missouri? MPG problems inside | 4MPG | Fuel Economy Forum | 31 | 12-17-2008 05:48 PM |
Am I calculating MPG correctly? | YarisBlazer | General Yaris / Vitz Discussion | 24 | 08-18-2007 11:57 AM |
