![]() ![]() ![]() Drives: 05 YRS Silver Lining Metallic Join Date: Jan 2006
yep, its included in the package.
![]() ![]() ![]() ![]() Drives: Thndr cl metallic HB 3 drs '05 Join Date: Mar 2006
QUESTION:
I have mine installed this way: ![]() I purchased the base for the bulbs but when i removed the bumper i found that the factory harness and plug was already there, followed the cable inside the dash and removed from the plug, connected that cable to a relay and from the relay to a fuse and that to a live line to the battery. The relay is powered by the key switched line and then to a switch. Problem is that the line marked in red in the diagram gets hot. Is this normal or what should i do to prevent this??? Kitt
20 years... alive and kickin'!! ![]()
Low in should be the line that comes from your switch, low out should be ground, 30a in, from your battery and 30a out should go to your fogs... This is a standard type of relay, they usually have a diagram printed on its side, if you could post a picture of it i may help you better
Rwseattle
Drives: 2007 Toyota Yaris (BASE) Join Date: Dec 2006
Pix
My PC is not downloading the relay pix. I'm not sure why. I will downloaden tomorrow at work. The relay does not show any wiring diagram. It only says YLE YL-388-S Automotive relay 12V/40A. I got 4 connectors and they're all the same size. I will post pix tomorrow. Thanks for your help.
It should have something like this...
![]() post the picture anyways and i'll see what i can do
Rwseattle
Here's the pic
Hopefully this helps.
ummmm not that much tough... you will need a continuity tester then to find it out. The 2 connectors that have continuity are ones that will go to the switch and to the ground, the other two ones will come from the fuse to the fog lights...
and try to post a bigger picture to see if it helps, focused on the pins of the relay
Shiny Chromey Coolness
Drives: 2007 Toyota Yaris Liftback Join Date: Feb 2007
Foglights installed and functional...the best mod for me yet!!!
Bringin the Bling to Yarisworld |
Rwseattle
Thank you.
I found the correct connection. I did use the continuity tester. I will post pictures of working fog lights soon. I'm installing a front strut bar and will post pictures all together. Thank you for your help.
Rwseattle
Here a pic of wrk foglights.
Green is good
Thanks Jimcat for the fog light kit!!! It came in one day ahead of schedule hehe.Will install on Friday night
Ok. Got them installed today. So happy
![]() ![]() Drives: Blazing Blue 07 YAris Join Date: Jun 2007
Hey guys, I think that I am going to try and tackle this myself. Did you have to remove the bumper to install the fog lights?
Thanks, MYT |
I went though the wheel well and front bumper......not very smart but it got the job done and I ended up with a lot of bruises from my arm being squashed in there
Gotcha I guess I was thrown off by your pic on the underside(or back of the bumper). thanks though guys, hopefully I'll get some pics when I finish it up :)
MYT |
fogs install
wheel well remove the front pushpins and under the bumper remove the three self taping screws wheel well plastic will fold back giving plenty of room i wired direct to bat with inline fuse works fine just don't for get to turn them off
| Ebay OEM style fog lights installed | fantabulousbaby | Cosmetic Modifications (Exterior/Interior) | 29 | 04-28-2009 11:14 AM |
| EBAY OEM BUMPER FOG LIGHTS | Wayside | General Yaris / Vitz Discussion | 41 | 01-09-2007 01:52 AM |
| can i / where to get factory switch for aftermarket fog lights? and exhaust tip q. | fantabulousbaby | Cosmetic Modifications (Exterior/Interior) | 22 | 08-29-2006 02:13 PM |
| "OEM" fog lights from ebay | drell42 | Cosmetic Modifications (Exterior/Interior) | 5 | 07-28-2006 10:21 AM |
| Liftback Fog Lights on eBay | Chris07LB | General Yaris / Vitz Discussion | 8 | 07-24-2006 08:06 AM |
