Old 10-11-2010, 01:41 AM   #1
PETERPOOP
PETERPOOP's Avatar
Drives: 08 white liftback
so much for a sleeper...
Old 10-11-2010, 02:27 AM   #2
sleey0
Drives: 2008 Yaris LB
When I am done, mine is DEF gonna be a sleeper.
I don't even have a body kit on mine (maybe next summer) or aftermarket wheels - rolling on steelies!
lol
Sleeper = me
"And that goes for any of you, never get put down from someone who gets jealous of you; build it and prove them wrong. There will always be haters and naysayers but those are also the ones who's cars are worth less than my seats."
xbgod - 9/23/2010
sleey0 is offline   Reply With Quote
Old 10-11-2010, 11:27 AM   #3
Focus_Sh1ft
Focus_Sh1ft's Avatar
Drives: 08 Yaris Turbo; 06 tC Turbo
Glad to see you got that worked out, I really didn't know what to tell you. So, you've decided to keep the car constantly in open loop? I dunno if you've checked my thread, but closed loop is definitely an issue... I was also wondering, since you pulled O2 sensor 2 when you had your exhaust done... Wasn't your car constantly in open loop anyway?
Focus_Sh1ft is offline   Reply With Quote
Old 10-11-2010, 08:47 PM   #4
pimp my yaris
C'est la vie
pimp my yaris's Avatar
Drives: 2009 2 door hatchback
[QUOTE=Focus_Sh1ft;521878]Glad to see you got that worked out, I really didn't know what to tell you. So, you've decided to keep the car constantly in open loop? I dunno if you've checked my thread, but closed loop is definitely an issue... I was also wondering, since you pulled O2 sensor 2 when you had your exhaust done... Wasn't your car constantly in open loop anyway?[/QUOTE
Removing the after cat. O2 wont put you in open loop. But dissconnecting the manafold O2 will. I was still idling lean and had a rough idle after dissconnecting the O2. I added 20% fuel during idle and whenever runing out of boost. Its runing so much smoother now and I feel safer. The correct way would be to modify the O2 with the FIC. This would keep the CEL off. But I have no converter anyway, so it would still be on. Im sure mileage will suffer, but i would rather keep rings and pistons cooler with a richer mixture.
pimp my yaris is offline   Reply With Quote
Old 10-11-2010, 09:53 PM   #5
sleey0
[QUOTE=pimp my yaris;522037]
Patience.
CTScott is gonna look at it in a few weeks. I bet anything he comes up with some type of workaround
AND a good idea is to start a donation fund for him. The dude has helped nearly everyone on this site lol.
I would def donate to thus project, IF CT wants to set it up.
xbgod - 9/23/2010
Old 10-11-2010, 01:48 AM   #6
So I guess no one had any tips or sugestions,
never saw the thread, but glad you got it worked out
Old 10-11-2010, 01:54 AM   #7
sleey0
I hope the better pump works for ya.
How much boost are you aiming for?
xbgod - 9/23/2010
Old 10-11-2010, 11:33 AM   #8
sleey0
Yes, that is how one of garms buddies runs open loop constantly. But it come with the price of a constant CE light.
xbgod - 9/23/2010
Old 10-11-2010, 08:55 PM   #9
pimp my yaris
C'est la vie
I also had a problem with dying out at idle with a hot engine or when idling for a long time. Its all been taken care of now.
Old 10-12-2010, 08:48 PM   #10
pimp my yaris
C'est la vie
Found a good thread on a scion forum with pics of a step by step engine teardown for piston and rod replacement http://www.scikotics.com/forums/showthread.php?t=46597
Just wanted to share
Old 10-12-2010, 10:06 PM   #11
Nexus1155
Bathroom + Laptop = <3
Drives: Audi
There is already such a device, it is a narrowband simulator. You obviously need to have a wideband of your own to tune. But once you have the fuel tuned and the wideband still sees 11.* the narrowband simulator will tell the ECU that it is at 14.7 therefore not have the ECU going crazy.
Most in car widebands/managements have the ability to do such a thing. Check it out on most of the spec pages. I beleive both the FI/C the Uego and the emanage can do this, just alot of people never take advantage of it.
That and a MAF clamp, you should be running CEL free.
Old 10-23-2010, 09:44 AM   #12
pimp my yaris
C'est la vie
I took some pics for the micro image calendar. I call this one, In Your Face! I wonder who's phone number is on my license plate?
Old 11-02-2010, 06:36 PM   #13
pimp my yaris
C'est la vie
I recently have noticed a small problem with my cheap turbo. When the car sits overnight and U first start it up in the morning. If I just let it idle and warm up for a while I will get some white smoke coming from my exhaust when the engine starts to warm up. If I rev it up I get a little cloud of smoke. Once I start driving the smoke is gone and no more problem. I have removed my downpipe and have noticed some oil leaking from the turbo into the exhaust when the car sits and gets cold. I have also checked my oil level regularly and never noticed any oil burning issue. Even making 800mile trip there was no oil loss.
So I think its only a drop or two that leaks into the exhaust every night. It just really pisses me off though. I have done everything to prevent this. My coolant lines are connected and I have a turbo timer.
I guess thats what U get for buying the cheap Chinese turbo. I hope it holds up through winter and mabe I will get a Garret next summer. Its 950$ compared to the 240$ I spent for my turbo.
I wonder if I had a converter, mabe that would eliminate the smoke?
Old 11-02-2010, 08:04 PM   #14
Focus_Sh1ft
Yeah, doesn't seem like it's THAT big of a deal. I'm still dripping oil a bit, but it's like your case where the amount is so insignificant that its not even effecting oil level.
And let's be real here, your install went wayyyy too good regarding leaks until now lol.
Old 11-04-2010, 03:07 PM   #15
weapon5
Drives: VITZ
I want to build a costom turbo setup using mostly E-bay parts. I am thinking t25/28 turbo. I have found exhaust manafold/turbo, intercooler and piping,oil and water lines if needed. Also a air intake and filter to mount the mass air sensor. I am sure I will need to buy at least 1 more intercooler piping kit and a blow off valve. And I found a downpipe witch will need to be costomized from a nissan silvia. Or I will need a complete costom downpipe.
My questions are what piggy back system should I use to control injector pulse? Will I need bigger injectors right away? I am only looking for 150-170whp. Also should oil source for turbo be tapped from oil pressure sensor or do I need to buy adapter to tap near the filter? I am also sure a new clutch will be in my future shortly after install. I am thinking center force dual friction.
Also can I tune a piggy back system with a lap top and a wide band o2s or do you need some specialized training to complete this. I am a ase master tech for about 12 years, but I have never done tuning. Its just so dame expensive around Chicago. Very few places to go.
that turbo kit is ebay so i would suggest spend more cause that turbo kit is but like i said is up to you. FYI for a good turbo kit and to save you the time and money get a real kit which are around 3k :D
weapon5 is offline   Reply With Quote
Old 11-04-2010, 03:10 PM   #16
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
HAHA, wow, he's already built the turbo and is in the tuning process now.
Old 11-05-2010, 04:59 AM   #17
pimp my yaris
C'est la vie
Ya I guess he missed the previous 17 pages.
Old 11-12-2010, 04:19 AM   #18
weapon5
Drives: VITZ
yea very late didn't know it went on this long
Under $2500 Turbo Kit w/Intercooler coming soon! cdydjded Forced Induction Forum 58 09-23-2007 03:02 PM
turbo manifold build... joey1320 Forced Induction Forum 4 06-30-2007 03:26 PM
ZPI to produce yaris turbo kit and exhaust turboyaris Forced Induction Forum 15 06-09-2007 02:24 AM
ZPI soon to release their turbo kit turboyaris Forced Induction Forum 10 04-26-2007 03:52 PM
ZPI to produce yaris turbo kit and exhaust turboyaris Forced Induction Forum 30 04-04-2007 03:10 PM
