C'est la vie
Drives: 2009 2 door hatchback Join Date: Aug 2009
I am going to pull the bottom end on sunday and check it out. I will most likely order crower rods and je pistons and rings from this Race engineering web sight. https://www.raceeng.com/c-375-1nzfe.aspx
I am also thinking of buying a new clutch from micro image. |
^ They list CP pistons. I have those and Pauter rods on the shelf. I can probably beat their prices if you want JE and Crower instead.
C'est la vie
Ok, engine is built in the car and running with cp pistons and Pauter rods for those who didnt see the build thread. I am working on a return line now. I plan to drill a hole in the top of mystock rail and tap the hole. I then will screw in a -4an fitting and run that line to a boost controled fuel regulator and then back to the pump top with another hole and fitting. I was thinking of using a larger -6an line but that would be even larger then the stock feed line coming from the pump. I will also remove the stock filter and regulator and attach the feed line directly to the pump. I will attach a in line filter somewhere on the bottom of the car.
Has anyone tried this or something similar yet? Thoughts? ![]() Garm or blown xa if you see this can you tell me what size your return line is? |
Mr. 155 and climbing
Wish I had my data for you Brian, but with the hiccups I am dealing with I haven't been able to get to the dyno for real world evidence to upgrade mine. It will happen before fall though.
^ I'll check this morning.
C'est la vie
1200mi on the rebuilt motor. It is running great. I did a compression test yesterday after I had some tuning issues on a long road trip. All cyl. were 120-123 psi. Also no oil burning at all.
I have my fuel map perfectly tuned while in the boost. Unfortunatly my AFR's vary a lot during normal out of boost driving. Depending on engine temps. and under hood temps. Its getting pretty hot under there in 90+ degree temps. I am thinking of hooking up my factory o2 sensor to see if this helps. I am tired of dragging my lap top around on every long trip. |
C'est la vie
The new fuel rail I got from MI is awsome. I will post pictures later.
didn't know it was in stock. Is it the proto type?
C'est la vie
It is the final design. He sent me one early. The rest are going out for polishing. I was in a big hurry. I havent mounted it yet, I am still working on getting all the needed fittings. Mabe this week end I get some some real work done.
Should have finished and polished production stock early next week.
^ Jog memory Garm, where are the inlet and outlet ports in regards to orientation drivers/passengers side?
I am going in for my new tune on the 9th. I will shoot video to show fuel pressure ration under boost to add to my article on fuel system upgrading.
Not too bad put me down for one. Post or pm me cost so I can put it aside plz.
$149.95 shipped, going up into the store today.
As for direction, my regulator and gauge are on the driver side, I thought that was the inlet because of that. I will confirm with Art, I suppose it could be plumbed the other way?
Cool...I could be confused, but I thought that Art had said that was the case.
![]() Drives: Yaris T Sport Join Date: Jan 2011
Hi, I'm in the process of fitting a turbo to my Yaris 1NZ-FE. Just wondering if you could help. Which one is the oil pressure switch, the one that sits behind the intake manifold or the one that's slightly below it?
Cali Yaris, does the fuel rail require a piece of the valve cover to be chopped off like the perrin and OBX? |
#18 | |
| Under $2500 Turbo Kit w/Intercooler coming soon! | cdydjded | Forced Induction Forum | 58 | 09-23-2007 03:02 PM |
| turbo manifold build... | joey1320 | Forced Induction Forum | 4 | 06-30-2007 03:26 PM |
| ZPI to produce yaris turbo kit and exhaust | turboyaris | Forced Induction Forum | 15 | 06-09-2007 02:24 AM |
| ZPI soon to release their turbo kit | turboyaris | Forced Induction Forum | 10 | 04-26-2007 03:52 PM |
| ZPI to produce yaris turbo kit and exhaust | turboyaris | Forced Induction Forum | 30 | 04-04-2007 03:10 PM |
