Old 01-24-2011, 02:16 AM   #1
derickveliz2
derickveliz2's Avatar
Drives: Yaris Sedan "S"
Originally Posted by packetrace View Post
how much you paid for your carozzeria ? and th p-99 ? aahaha
P-99s are around $1200
What I think you would like is:
HU to EQ6500
EQ6500 has 3 rca outputs
. for Sub-Woofer (you all ready have an amp for this)
. (get a 4 channel amp) and you could have
Chanels 1 = a passive x-over with 3" or 4" Mids + tweeter
Channel 2 = 6.5" (Mid-bass) in doors (you can use the built in x-over in the amp)
D.
CLA 250, 4MATIC
Old 01-24-2011, 12:51 AM   #2
sqcomp
Roadrunner Jr.
sqcomp's Avatar
Probably the same as derick. The only thing I got over the American version is the little amplifier...and Japanese sub menus.
I forecast in a couple years I'll sell the piece and buy into a more advanced processing system. It'd be a long shot to get my hands on a JK Labs type piece.
I know tha SB's processing power is something like 300 dB sloped and a completely infinite parametric equalizer system with a very advanced time alignment process. I'd LOVE to gave the headache of setting that one.
― Thomas Paine
Old 01-24-2011, 12:26 PM   #3
packetrace
packetrace's Avatar
Drives: Yaris Sedan 2009
I like much more the one with th 6XS audiocontrol...because i want to change as often as I want the filter.....but I've talked with one of my teacher at college...and I could built a circuit with a PIC and I could program it as a filter.....and build one for tweet, mid bass sub.....but it would be between speaker and amp.....
ps: we are actually drawing our schema for a subwoofer amp....we'll have our amp in MAY or early !
Interior:ALL red, black roof
Old 01-25-2011, 09:38 AM   #4
packetrace
packetrace's Avatar
Is there some deck with 4 outpout like yours p-99 but for less then 1200$....around 500$ ?
because its mcuh more wire with my actual HU....HU to eq6500 to 6QS to AMP
Thanks...and would you have a kit of tweeter,mid-range and mid-bass to suggest me....not as expensive as your system....but....not a crappy system ....
THANKS
Old 01-25-2011, 09:56 AM   #5
packetrace
packetrace's Avatar
I took a look at some amp...and found this....
4 ohms: 75 watts x 4 chan. + 250 watts x 1 chan.
2 channel for tweeter, 2 channel for mid range and 1 channel for mid bass.....would iit work?
Old 01-25-2011, 10:47 PM   #6
derickveliz2
Thumbs down
That is the amp I'm using to power my Mids, Tweets and Subwoofer.
Channel #5 is in Mono! It won't work for Midbass you need stereo!
D.
CLA 250, 4MATIC
Old 01-25-2011, 11:34 AM   #7
sqcomp
Roadrunner Jr.
sqcomp's Avatar
Powerbass is a good choice. The "lower power" for the sub might lead me to use a ported enclosure for a bit more output. You could also use two small woofers as well.
― Thomas Paine
Old 01-25-2011, 12:06 PM   #8
packetrace
packetrace's Avatar
i already my amo + sub....the channel ''sub'' on the powerbass would be for my MIDBASS.....which would go in the door...maybe kickpanel...but IN A WHILE
Old 01-25-2011, 07:19 PM   #9
sqcomp
Roadrunner Jr.
sqcomp's Avatar
I was under the impression that mid bass would be stereo instead of mono.
― Thomas Paine
Old 01-25-2011, 08:11 PM   #10
packetrace
packetrace's Avatar
You're right ! newbie I am....!! it would be better to take a PB a 4channel for mid and tweeter...and a 2 chanell for midbass.....and my sub i already have all i need!
Old 01-25-2011, 09:47 PM   #11
packetrace
packetrace's Avatar
2 powerbass amp would be really good i guesss......
what kind of 3 way component should I be looking for....? I'D like to do something like derick...in ball on a-pillar...or maybe fiberglass...
Old 01-25-2011, 10:41 PM   #12
sqcomp
Roadrunner Jr.
sqcomp's Avatar
How about looking for what you want on the net, show us what you are thinking. I've got TONS of pictures of component builds, I'm sure Derick does as well.
...Derick does have a good setup. I wonder who helped there? :P Why not describe what kind of listening you're going to do and we can tailor something for you.
Here's mine:
Any ideas?
― Thomas Paine
Old 01-25-2011, 10:51 PM   #13
sqcomp
Roadrunner Jr.
sqcomp's Avatar
Nice looking amp! Is everything going okay with it? (customer service checkup)
― Thomas Paine
Old 01-27-2011, 12:04 AM   #14
derickveliz2
Thumbs up
Thank you,
Yes every thing is OK, a big improvement from my old Premier Pioneer amp.
One question, it makes a little noise when turns on/off on the speakers, my Pioneer amps never did, when on sounds like "Thrrrst" and when off sounds like "Tukk"
listen to this VIDEO...
or...
http://www.youtube.com/watch?v=HvFqMbs5VN0
Thanks
D.
CLA 250, 4MATIC
Old 01-26-2011, 07:31 AM   #15
packetrace
packetrace's Avatar
I'm listening to a lot of kind of music!
Most of the time I listen to punk music....just like sum41, Blink182
ps:your system looks sooo great !! I Like those 3 amp mounted in the back!! and ypour tweeter+mid-range in the A-Pillar! WOOW
Old 01-26-2011, 11:07 AM   #16
packetrace
packetrace's Avatar
http://cgi.ebay.ca/HSK-163-HERTZ-6-5...#ht_6540wt_905
TAKE a look at this!
Old 01-26-2011, 11:11 AM   #17
packetrace
packetrace's Avatar
http://cgi.ebay.ca/New-Hertz-HSK165-...ht_4671wt_1139
these one...and i would add HL-70!
what do you think
Old 01-26-2011, 12:21 PM   #18
sqcomp
Roadrunner Jr.
sqcomp's Avatar
...just wait until you see the finished trunk. I'm floating the ML3800 sub woofer with the magnet out in front of the amps as you look into the trunk. I layed down the frame and the bottom glass yesterday. Next week will be more glass buildup. I'll have around a cube and a half for the enclosure.
Anyway, one word of warning, With the ebay purchases...watch yourself. Woofersetc isn't an authorized retailer for Elettromedia. 9 month warranty? Seriously? That's an in house trick. You won't be getting factory support if something goes wrong.
You're closer to Palmer than I am to you. Perhaps one of us can work something out for you to get the real product.
― Thomas Paine
ACRONYM thread Shroomster Off-topic / Other Cars / Everything else Discussions 45 02-15-2025 10:30 PM
Yaris Sedan Deadening and Sound system upgrade derickveliz2 In Car Entertainment + Electronics (audio / video / alarm) 2992 11-18-2021 02:14 AM
Electrical System Upgrade Advice sqcomp In Car Entertainment + Electronics (audio / video / alarm) 6 03-23-2016 01:15 AM
Very Important Question about Sound System Upgrade. Falconeer In Car Entertainment + Electronics (audio / video / alarm) 5 07-07-2010 03:57 AM
Cheap sound system upgrade. I like it. kac In Car Entertainment + Electronics (audio / video / alarm) 11 06-22-2010 09:48 PM
