![]() ![]() Drives: 2007 4dr sedan Join Date: Jun 2009
Read post #152
![]() ![]() ![]() Drives: 2007 Yaris Sedan Join Date: Apr 2009
It is in post #162
![]() Drives: 2007 3dr Hatchback Join Date: May 2025
Just did the install today and no luck. I have a 2007 with no indicator light and want to troubleshoot to see if I'm at least the switch to the ECM is working.
How do I troubleshoot this? I saw that some are mentioning that they're testing voltage while depressing the on/off switch. Are you removing the pin from the D3 connector and then using a multimeter to test? I'm not sure how else that would be done. I did pull the pin and checked and am getting 13.3 volts whether I press the on/off button or not. |
Update - I found the issue. The splice connector under the hood was not set up properly. Set it up correctly and all is working well.
| Cruise Control Available for 06/07 Yaris | TOYOTaejien | General Yaris / Vitz Discussion | 8 | 08-27-2010 12:58 PM |
| Cruise Control | chessclubloser | DIY / Maintenance / Service | 11 | 03-27-2010 11:59 AM |
