Old 09-18-2014, 03:19 AM   #1
TerenceCruz
Drives: 2011 Toyota Yaris
Originally Posted by nobodywise View Post
Still not low enough for my though haha
I love the back of my car, the front... not so much
Oh sorry the way I typed it made it seem like I only got the front coilovers haha. I have the full coil overs, front and rear. But, the rear coils didn't go as low as I'd like to. As I'm sure you know the rear spring is independent from the shock. That's why I said I'm only on the springs in the rear cause I took off the locks/perches that came with the coils to get the maximum drop. I want to get shorter/stiffer springs though so I can put the locks and perches back on to be able to adjust my height as I please again. Plus, it looks like you have bigger rims so that should fill the gap nicely if you feel like the Megans don't have a low enough drop for you.
TerenceCruz is offline   Reply With Quote
Old 09-18-2014, 03:20 AM   #2
TerenceCruz
@aspro - Thanks a lot man!
Old 09-19-2014, 11:59 PM   #3
TerenceCruz
Got the crew banner on! #Sus_Spec Okay, no more new posts from me until I get my wheels mounted ;)
20140919_185035 by TerenceJCruz92, on Flickr
Old 09-21-2014, 05:55 PM   #4
TerenceCruz
Does anyone know the diameter of the rear springs on Megan Racing coilovers? I found some shorter, stiffer springs for my rear, just want to make sure it'll fit. I know our springs are independent from the shocks, but still lol
Old 09-21-2014, 07:27 PM   #5
ezhacker1
ezhacker1's Avatar
Drives: Decepticon - Ravage
65mm inner diameter should be the standard. I have 6in 8k springs all around.
Check out my Build thread:
Old 11-26-2014, 01:03 AM   #6
TerenceCruz
Hey guys, it's been a while since I've updated this. Just doing more research and saving money before I do any more mods. These are a couple of items I am looking for in order to finally put my wheels on:
1) -3 OR -5 camber shims from RealCamber. I don't know which yet, if -3 is enough to fit some 16x8.5 +25 offset wheels wrapped in 195/45s I would rather stick with that so I don't burn through tires as fast.
2) 6" 10k springs for the front, and 5" 8k springs for the rear for my Megan Racing coilovers. Want to add stiffer and shorter springs so I can go lower and get tighter fitment.
I am paypal ready, please comment below if you have any of these items! Thank you very much. Also, just wondering, do any of you guys know which lug nuts I'd need to buy to work with some BBS RS reps? Preferably with a lock. (I know they're reps, but I still don't want to worry about them getting stolen. Haha) Thanks everyone!
- Terence
Old 11-26-2014, 03:48 AM   #7
ezhacker1
ezhacker1's Avatar
just get some gorilla lock nuts. either ones with 1 lock nut, or all 4 lock nuts, or just basic type where a socket adapter is needed to remove.
As for springs, there is a diminishing return on getting stiffer springs as it relates to ride height. Did you already calculate the drop with those spring specs?
Old 11-26-2014, 04:11 AM   #8
TerenceCruz
Sweet, I'll look into those lug nuts Jonathan. And as for the springs, what do you mean a diminishing return on getting stiffer springs as it relates to ride height? Sorry I'm having a brain fart and I'm sleepy lol. I basically just want 5" springs in the rear (so I can put my locks/perches back while being able to go as low) that are stiff enough to where I can have one or two people in the back without the spring compressing an inch. I want the lips of my wheels to be pretty close to my fenders when everything gets dialed in correctly. If I can find those stance coil springs you showed me, in 8k BUT in 5", I will definitely pick those up. If I go with the 6" that are available, once I put the locks/perches back on it, its max low would be the same height where I am at right now basically. So I want to get a shorter spring so I can even out that rear height cause my rear passenger side is about 1/4th of an inch higher remember?
Old 11-26-2014, 05:11 AM   #9
ezhacker1
ezhacker1's Avatar
cool sounds like you did your math. I just mean that the stiffer you go obviously the less compression you get given a fixed amount of weight (3 passengers in the rear). But the difference between say 9k and 12k is smaller than 6k and 9k. etc etc, you wont see much of a compression difference but your butt will sure feel it. 8k all around feels jolting in SF streets, and i run full soft on the shocks/struts.
At the extreme end of the spectrum of spring rate, a solid unmoveable spring = cinder block as your spring, you wouldnt get any compression, and your car will bounce everywhere. Try and find a spring height that will accomadate your drop, vs using spring rate. Of course making sure short springs will work with your shocks / struts to make sure they dont bottom out.
Old 11-26-2014, 02:47 PM   #10
TerenceCruz
Ahh gotcha.. Hmm, I'm debating on going 8k all around now. I mean it's not like I race, or ride on bad roads often. The worst roads I encounter are probably in SF, Berkeley, and Vallejo. But that's not too often. Also, I contacted the seller of those springs you showed me online, the stance coil springs, he said they won't fit on my Megan coils. Maybe cause my Megan springs were 62mm ID and the stance coil springs were 65 mm ID? I was hoping these would work on my coils
Old 11-27-2014, 11:55 AM   #11
coheed
Drives: 08 BB LB
http://www.racingsprings.com/2.5-ID-Coil-Over/Store/15
All the springs I'm running on my Megans i got from ^^this^^ site. I've got 6" 9k in front and 4" 7k in the rear no issues with fitment, and my ride quality isn't that bad.
Old 11-27-2014, 06:17 PM   #12
TerenceCruz
Sweet, yeah a buddy of mine on IG showed me those springs. The 2.5ID threw me off though so I didn't think I could use those. If I go with these I'm probably gona go with 6" 10k front, 4" 8k in the rear. If I could find them on this website.. Haha. Am I looking at this wrong? Under 6" spring it only goes up to 7k? And this 4" only goes up to 5k?
Old 11-27-2014, 11:35 PM   #13
coheed
Drives: 08 BB LB
Looks like the only choices for 4" are 7k or 9k and it looks like 6" goes up to 12.5k. All their rates are lbs/in not kg/mm. Edit: conversion rates for springs> http://coilover-store.com/expert-adv...kgmm-to-lbsin/
And like i said I'm running their 2.5" ID springs front and rear with no issues. But be advised with my 4" on the rear with the collars just a 1/4" fron the top of the perch my shock is almost bottoming out, like I have about 3/8" between bumpstop and body....
Old 11-30-2014, 05:29 PM   #14
TerenceCruz
Ahh, gotcha. Thanks for all the help man.
Old 11-30-2014, 06:11 PM   #15
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
Forget the springs and put on those wheels now!
Old 11-30-2014, 09:16 PM   #16
TerenceCruz
Hahaha Sugi! Man, I know. It's so tempting. I just feel like 3k is so soft, and I want to be patient and do the stiffer springs, camber shims and wheels all at once.. But.. I might just do that and worry about proper fitment with the stiffer springs and camber shims after they're on..
Old 11-30-2014, 09:26 PM   #17
TerenceCruz
Sorry Sugi, this is all I have for you for now :)
20141022_121051 by TerenceJCruz92, on Flickr
Old 11-30-2014, 10:01 PM   #18
sheekeebut
Minimalist
Drives: 07 silver sedan
Shiny!
sheekeebut is offline   Reply With Quote
2010 Vitz RS Modellista Completed Car Vitz Rs Modellista Photo-Video-Media Gallery 38 11-18-2014 01:25 PM
2012 Vitz from the 2011 Tokyo Auto Salon CTScott Third Gen Yaris General Discussion 14 02-10-2011 09:06 AM
Is UA-NCP13 1.5L Manual Trans a Vitz RS? WesSunday General Yaris / Vitz Discussion 1 11-28-2010 11:47 AM
Newly refreshed 2011 Toyota Corolla Kal-El Off-topic / Other Cars / Everything else Discussions 23 11-27-2010 01:57 PM
A German Yaris/Vitz/Echo ;) we-to-11 Photo-Video-Media Gallery 5 06-27-2007 09:26 PM
