![]() ![]() ![]() ![]() Drives: 06 Yaris HB CE Join Date: Aug 2009
Does EFI cleaning helps with mileage?
I haven't done EFI cleaning since 50,000km, car has 130,000km right now.
My mileage has dropped because of the winter but should I do EFI cleaning, how much mileage benefit will I get from it, because dealership is charging me $140 |
EFI cleaning can definitely help, as injectors that are gummed up will not properly atomize the fuel. Running a pour in the tank cleanser will typically not do much of a job of cleaning the injectors though.
#3 | |
"LibertyRides!"
Drives: 2010 Yaris 3Dr LB | 2020 Stang Join Date: Mar 2010
Cheers!
~ Mark ~ 2010 Yaris 3-Dr Liftback, 5-Speed Manual, P185/60R 15, Bayou Blue Pearl I Love my YARIS Most miles Tank: 538 tank/10.148 gal = 53.015 MPG / Most MPG: 54.95 MPG (ethanol) 425 tank/7.73 gal "The evils of government are directly proportional to the tolerance of the people." -- Frank Kent |
#4 | |
![]() My engine's compression is near new, get good mpg despite how my car is set up, engine doesn't make any weird sounds, etc. Then again, I also use Seafoam once a year. LOL |
#5 | |
#6 | |
A SGII really helps with mpg. I would have been getting lower mpg's (lower than I can get) if I kept driving 55 mph and not conduct my own tests.
I also use nothing but Chevron for gas, and Amsoil for engine oil and MT lube. I also have max psi in all four tires.
Mr. 155 and climbing
You can also use the products from AMSOIL which are great.
Yup, can't beat once a year oil changes. My oil is still pretty clear considering I last changed my oil in August 2012.
![]() Not only that, it protects better. My compression test shows that. And it gets better mpg. |
There is also these:
http://www.amsoil.com/shop/by-produc...ngine-cleaner/ http://www.amsoil.com/shop/by-produc...line-additive/ I do use Seamfoam as well from time to time.
Power Foam not available in California...le sigh. Cali Y U SO STINGY!
Might order the P.i. additive when I place my engine oil and MT lube order near August, and just store it somewhere as I won't be needing it any time soon.
Thanks for the input, Kaotic and others. I think I'm going to buy some Sea Foam Motor Treatment in the next couple of weeks and a Scan Gauge either at the same time (if I can convince myself I won't be obsessive right off the bat re using it
) or later this Summer (if I think I'll be obsessive right off the bat). My 'new' tires (about 15,000 miles ago) are the same model as my previous set, but the max psi is now 40 rather than 44...not really germain since anything over 38 (which I sustain), personally...just me, feels like driving on rocks on these tires...great tires though...got 85k out of the last set. When I eventually say goodbye to this Yaris (for a new Yaris), I'll probably use AMSOIL right off the bat, and change the exhaust as many of you have.
#14 | |
![]() Which stock tires did yours come with the Eagle LS or the Potenza's? I don't mind harsh rides, 205/40/17 (stretched in the rear) and 51 psi (cold).
#15 | |
#16 | |
. I drove on those for I think a couple thousand miles and did not like them. I went back and made them put new FR710s on. I recently posted that I just rotated those at about 15k miles, but it must have been a lower number (I forgot to take the brief time with the Affinity Touring into account). I like this set of FR710s pretty much as much as the previous set.
#17 | |
I'm trying to find a set of tires for when my current tires (came with the rims, we basically new and some generic brand made in Japan) wear down. Looking for a balance of life and grip since I do like to take on/off ramps faster than the suggested speed (then again, it seems like everyone and their mother takes on/off ramps way faster than the suggested speed).
#18 |
So it pretty much cleans the head only??? The thing I like about Seafoam is it's an all around cleaner. May not be the strongest or best at cleaning a particular part, but it gets around to everything. I'd love to try the Power Foam, but I would still have to get Seafoam to pour into the crank.
| -Mileage Thread- -Log your mileage, year, model, color, any problems here... | Kal-El | DIY / Maintenance / Service | 317 | 07-20-2016 10:07 AM |
| Amazing Gas Mileage .. way too easy. | edmscan | Fuel Economy Forum | 9 | 07-19-2012 06:36 PM |
| Does Gas Mileage Increase After 1st Oil Change? | ChilliwackGuy | Fuel Economy Forum | 10 | 08-04-2010 02:13 PM |
| 2009 Yaris Mileage | wornways | Fuel Economy Forum | 3 | 07-29-2009 11:42 AM |
| Performance mods that won't affect/will hardly affect gas mileage?? | Mr.Yaris | Performance Modifications | 15 | 07-30-2007 12:32 AM |
