![]() Drives: Toyota Yaris Track prepped Join Date: Nov 2013
![]() ![]() New belt in place and its much better compared to a standard 4PK belt. Supercharger goes like hell but i have the feeling its running lean in high revs. So next step is an wideband 02 AFR kit to see what the engine is doing. If its running lean than the next step will be upgrading the fuel system (Injectors, Fuel pressure regulator, fuel pump) Also need a new clutch so the choise is between a TRB Stage 3 or a Clutchmasters FX350 |
![]() ![]() Drives: yaris 09 ncp91 Join Date: Nov 2011
can you said how do you remove this shaft ?? it is press fit or screwed on the other
check your mp's please
| August 18th Sunday-Touge.ca Mosport DDT track event 12:30-5pm #15 of 20+ Events! | Touge.ca | Canada | 1 | 08-17-2013 06:00 AM |
| Touge.ca June 23rd Shannonville Full Track event 6 - 9pm, 10th event of 20+ 2012!! | Touge.ca | Canada | 0 | 06-14-2012 02:09 PM |
