01-31-2020, 07:17 AM | #37 | |
Anyway, with so many fans, can't be easy to keep up with all messages, I don't take it personally!
The price of freedom of religion, or of speech, or of the press, is that we must put up with a good deal of rubbish. - Robert Jackson Bye bye 1NZ... |
01-31-2020, 09:22 AM | #38 | |
2ZR swap. DO IT! Ask how!
It's kidspeak for Direct Messaging. I think there's a distinction in younger generations between instant messaging (IM) as we knew it and DM because things like Twitter and Instagram are both instant messaging but are broadcast to a public audience, whereas something like FB Messenger or your phone number would be private and therefore "direct" to the recipient. Messenger clients on a public page can get billions of hits from bots or spammers so they probably filter a lot of it out. |
01-31-2020, 06:46 PM | #39 | |
Drives: 06 2ZR Turbo Yaris RS Join Date: Aug 2017
01-31-2020, 06:48 PM | #40 | |
02-01-2020, 05:54 AM | #41 | |
2006 Yaris 5 Door RS 2ZR-FE (2011 Corolla 1.8L) Swapped, Automatic, T-28 Turbocharged (8 psi), HSD MonoPro Coilovers, DIY W/M Injection, custom 3" cold air intake, custom 2.5" exhaust, TRD rear sway bar, Penguin Garage 13mm spacers (rear), custom Civic front lip, full repaint, Android 6.0 7" touchscreen, Rockford Fosgate speakers, tweeters, NVX underseat subwoofer https://www.instagram.com/2zr_turbo_yarisrs/ Last edited by 06YarisRS; 02-01-2020 at 06:16 AM. |
02-01-2020, 09:33 AM | #42 | |
02-02-2020, 04:11 AM | #43 |
Drives: Corolla 1.8 Join Date: Oct 2010
Mightly car mods yaris 1.8 2zr turbo
02-04-2020, 10:10 PM | #44 |
New episode 138kw at the wheels (stock is 70kw)
https://youtu.be/K4UQsAe9-E4 |
02-04-2020, 10:30 PM | #45 | |
Drives: Starlet Join Date: Nov 2017
02-04-2020, 11:01 PM | #46 |
200hp, not too bad, but looks like they were playing it safe... Which, judging by the after-credits scene, failed miserably!
02-05-2020, 01:15 AM | #47 |
Drives: 2013 NCP130 Join Date: Nov 2015
It didn't sound healthy.
They kept mentioning the $169 turbo, but never mentioned the cost of the Haltech ECU.
Running on standard AU 14" steel wheels (14x5 rims, 175/70R14 tyres). Added reversing camera and touch screen radio, cruise control, 16" rear wiper blade, tow bar and dash cam. |
02-05-2020, 02:32 AM | #48 |
02-05-2020, 05:50 AM | #49 |
I sure hope that's not the limit. But it was an older engine and you never know what shape it was in originally. I can't see the failure being caused by the Haltach technician. Surely those guys could see detonation coming before it occured. I'd love to see the dyno sheet if it had info on AFR.
02-05-2020, 09:14 AM | #50 | |
Drives: No longer own a yaris :( Join Date: Mar 2012
eBay turbos aren't always bad, but one that cheap is destined to fail. Check out the turbos that the BoostedBoiz and PFI Speed are using from ebay. Several cars making 1000whp with honda K series and ebay turbos pretty reliably.
I'm a hermit named Lee |
02-05-2020, 11:42 AM | #51 |
It's probably not the limit of the 2ZR. Lotus runs the Series 3 Elise up to 186 kW (at the crank) with a supercharger. I'm pretty sure they wouldn't ship production vehicles at the ragged edge of performance. =)
02-05-2020, 03:40 PM | #52 |
I am planning to use haltech, not sure how they get around any check engine lights or other lights.
02-05-2020, 04:37 PM | #53 |
Surely Lotus would be not be using off the shelf 2zr motors though. I'd love it if they are as point proven, but surely not if punching out 186kw in a track car.
02-07-2020, 06:02 AM | #54 |
Drives: 2000 3dr LB Join Date: Dec 2018
Lotus uses the 2ZZGE motor with VVTLi , different motor .
Thread Tools | |
Display Modes | |
Similar Threads | ||||
3rd gen 2zr swap with 6 speed | stidnam | Performance Modifications | 97 | 06-29-2021 04:59 AM |
T Montague's 2zr swap - '08 m/t sedan some extra info | tmontague | Performance Modifications | 285 | 04-20-2021 11:56 AM |
3rd gen engine swap, 2ZR? 2AR? Swap newbie | m.flores.0928 | Third Gen Yaris General Discussion | 6 | 10-02-2020 10:54 AM |
06YarisRS's 2ZR-FE Swap 5-Door Hatchback (Automatic Transmission) | 06YarisRS | Performance Modifications | 448 | 12-06-2018 08:12 PM |
2zr swap and e-test in Ontario | tmontague | Performance Modifications | 7 | 12-23-2016 09:12 AM |
