08-28-2020, 02:44 PM | #1 |
Drives: Yaris Join Date: Aug 2020
1NZ-FE (TS) - transmission fluid change, 1.9 liters or let it overflow?
Hi,
I have a Yaris T sport from 2001 with the 1.5 liter engine with the manual 5 speed gearbox. I changed the trans fluid today, the toyota dealer (and the manual) stated that it would take 1.9 liters, i did add 1.9 liters but it didnt flow over the lip. Should I add more or let it be? Thanks / Sweden |
08-28-2020, 10:24 PM | #2 | |
Drives: 06 2ZR Turbo Yaris RS Join Date: Aug 2017
08-29-2020, 03:20 AM | #3 | |
I used the Castrol Syntrans Multivehicle 75W-90, it's API GL-4. Do not use a GL-5, even if the manual say so. ( https://www.yotatech.com/forums/f116...gl-5-a-201741/ ) |
08-29-2020, 03:22 PM | #4 |
Knower of little
Drives: None Join Date: Jul 2019
If the dealer said an actual amount then stick with that. Normally filling until it spills out the fill hole is standard procedure for pretty much all cars/trucks/bikes etc. But that's only if actual measured amounts aren't available.
08-29-2020, 08:32 PM | #5 |
Yaris Hybrid Limited 2015
You should really stay with the Toyota 75w GL4 oil, or you probably get bad shifting, these old toyota gear boxes dont like multigrade oil.
https://www.ebay.co.uk/itm/Genuine-T...-/282917939837 This should be the same at a much higher price for our US friends. https://www.ebay.com/itm/LEXUS-TOYOT...-/233126119936
08-30-2020, 03:31 AM | #6 | |
Thread Tools | |
Display Modes | |
Similar Threads | ||||
NEWS: TOYOTA REVEALS ALL-NEW YARIS SEDAN AT 2006 LOS ANGELES AUTO SHOW | VitzBoy | General Yaris / Vitz Discussion | 7 | 09-20-2023 07:50 AM |
2012 Yaris hatchback, 5MT: when to change transmission oil? | matti | General Yaris / Vitz Discussion | 14 | 11-18-2016 12:23 AM |
Manual Transmission fluid change | bankrobber | DIY / Maintenance / Service | 1 | 01-17-2010 10:32 AM |
2007 Yaris Pricing Info ! | YarisBueller | New YARIS Purchase Forum | 104 | 06-24-2009 04:54 PM |
Maintenance - Change Auto Trans Fluid | Linkseal | DIY / Maintenance / Service | 1 | 08-15-2006 10:57 PM |
