![]() ![]() ![]() Drives: 2013 NCP130 Join Date: Nov 2015
The response from Toyota will be "this meets Australian Design Rules".
ADRs allow the speedo to read 3 percent plus 4 km/h higher than the actual speed but must not read lower. This is tested at several specified speeds. I have the same error in my Yaris. Interestingly, the data from the OBDii port agrees with GPS speed readings. I have asked a few time on the forum before, but no one seems to have determined if the speedometer has any internal calibration adjustments.
Running on standard AU 14" steel wheels (14x5 rims, 175/70R14 tyres). Added reversing camera and touch screen radio, cruise control, 16" rear wiper blade, tow bar and dash cam. |
#2 | |
feed my pet
| Tags |
| speedometer, speedometer problem |
| Speedometer issue: Cluster shows 2X true speed w speed limitation at 95 km/h (190km/h | vince90ca | General Yaris / Vitz Discussion | 0 | 02-17-2021 11:45 PM |
| Inaccurate analog speedometer | JudgeM | DIY / Maintenance / Service | 2 | 12-23-2014 06:00 PM |
| Analog Speedometer instead Digital | Sesjusz | DIY / Maintenance / Service | 7 | 07-01-2014 12:42 PM |
| yaris voltage issue | yaris2010RS | DIY / Maintenance / Service | 11 | 12-29-2012 05:20 PM |
