#235 |
Dobbiedoo
Drives: 2009 5 door Hb Yaris Join Date: Aug 2010
What about adding a 3rd hole between the 2 stock holes?
#236 |
New Vios(Belta) Owner
Drives: 2009 Toyota Vios 1.3J Join Date: Apr 2009
This has got to be the most "eye-opening" thread I've read so far. I'll look under my car about this. Thanks guys.
Juan Miguel Tejero Dealer Sales Trainer Toyota Makati, Inc. Metropolitan Avenue Makati City, Philippines +63(917)5416453 jetejero@toyotamakati.com.ph www.toyotamakati.com.ph |
#237 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 08 Yaris Sedan Join Date: Oct 2008
So I work at a new shop now that has a hunter laser alignment machine and put my car on it and checked the spec for the rear alignment after doing this mod. Surprisingly all my rear specs for caster camber and toe were all within green and very close to perfect. Its been awile since I had an alignment and my mods in the back are trd springs swaybar and this rear mod. So apparently shifting it does correct alignment issues from lowering the car.
#238 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '14 GT86, '08 Vitz Join Date: Dec 2006
#239 |
toyota
Drives: 2007 Yaris RS Blazed Join Date: Oct 2006
Should be more worried hitting your gas tank... So I've heard.
If my calculations are correct, when this baby hits eighty-eight miles per hour... you're gonna see some serious shit!!!!!! "Horsepower is how fast you hit the object. Torque is how far you move that object.." |
#240 |
Ive taken my rear lower tie bar few days after doing this mod due to it hitting it on bumps.
#241 |
#242 |
Ive only hit my gas tank maybe twice and only on a really huge bump with the car really loaded when i had my factory shocks. Once switching to tokikos i havent had issues since.
#243 |
Are you on the Blues or Reds? Also, I'm lower than you and only on TRD shocks, so it's not as dampened as yours =\
#244 |
![]() Drives: 2007 Red 5dr RS Join Date: Mar 2012
Sorry to revive a 10 month old thread but I just got a Yaris LB with M2 lowering springs and am interested to see if anyone can provide any long-term update on this mod.
1) Any solution to the rubbing talked about in this thread? 2) Are you using aftermarket struts/shocks? Thanks |
#245 |
![]() ![]() ![]() Drives: 2009 3dr LB Manual Join Date: Mar 2010
I've been running this mod for over a year with well over 40,000 miles of Michigan roads. I have stock shocks and DF210 springs. The rear springs have rubber inserts to stiffen the back up. The inserts fixed the rubbing of the suspension member on the fuel tank. Also, when I took the car in for an alignment, there were no changes that needed to be made.
#246 |
![]() Drives: 2009 3rd Polar white Join Date: Apr 2011
I moved mine back to the stock holes until I could get some bump stops. Then I started autocrossing the car and I really like how the car handles as is, so I decided to leave it. It enters the corners very predictably and if I trail brake int the corner I can get the rear to rotate for me. When the rear rotates, it is so controlled and predictable that I didn't want to take the chance of messing that up. By the way I have a 2008 3door LB with Megan Racing coil-overs, UltraRacing rear brace, and A rear swaybar that I think is 22 mm. For racing I turn the rear dampers all the wy up.
#247 |
Only Happy When it Rains
so for those who have had problems, are your running a full interior or have you removed any rear interior pieces?
Colin Chapman disciple |
#248 |
I am running stock interior, including spare tire.
#249 |
www.yarisclub.gr
Drives: yaris 1.3 2sz - 1.33 1nr Join Date: Jan 2009
i think that the upper holes are for the 4wd version
#250 |
Minimalist
Drives: 07 silver sedan Join Date: Jun 2014
Wait, what? AWD? Which country?
#251 |
japan, and other countries that get Japanese cars. Toyota, and other Japanese car companies give their home market a hell of a lot more toys than they give us.
#252 | |
Minimalist
Anyone know how much heavier the AWD version is? |
| When will the Yaris hit the showrooms at dealers? | Petrolhead | New YARIS Purchase Forum | 181 | 11-28-2011 07:03 AM |
| Any Yaris hatch rear suspension tweeks? | woof | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 26 | 12-05-2009 06:04 PM |
| Hyperco 5.5" single pigtail rear spring test | kngrsll | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 33 | 06-15-2009 10:11 AM |
