Old 04-14-2010, 02:59 AM   #271
Falconeer
Bayou Blue Pearl.
Drives: Yaris 5D Liftback Full Options
talnlnky: Thanks for the info. I will keep 85 in mind.
By the way:
100 Deg. C. is the boiling point of water, at 1 Atm pressure... That means at sea level. In a car's sealed engine and radiator, its under pressure.
This keeps it from boiling at 100 Deg. C.
Ofcourse its packing a lot more heat than water at 100 Deg. C. in an open container at sea level.
BOSCH 8000k HID Headlights, BOSCH 8000k HID Fog Lights. BOSCH Horn. 30% tint all round. 70% Tint mirror-finish tint on front wind shield. TRD Leather Shift Knob, Leather Steering Wheel, TRD Emblem. Height adjustable driver's seat is cool! and... That great armrest from ebay
Falconeer is offline   Reply With Quote
Old 04-25-2010, 12:50 PM   #272
Hershey
filled up the 2010 automatic 3 door yesterday and the E.M. was right on the money with the calculated mileage . The C.M. and E.M. were 37.8 . The ECO-METER is set at 97 . This is a 1st for being exact . Have to see if next tank is the same .
Old 07-20-2010, 06:57 PM   #273
KrazyDawg
KrazyDawg's Avatar
Drives: 08 3dr LB AT
I'll be getting mine in 2 days. I update my gas logs every 2 days if someone wants to track my data.
KrazyDawg is offline   Reply With Quote
Old 07-21-2010, 12:14 AM   #274
Hershey
Nope . Reset to 98 . Reads a bit low , but at least I know it's doing a bit better than what the E.M. is showing .
Old 07-21-2010, 03:59 AM   #275
just a heads up, the Ecometer is $59.95 in my store with free shipping.
Old 07-22-2010, 12:22 PM   #276
KrazyDawg
KrazyDawg's Avatar
I'm looking into getting this cup holder mount so I can easily remove the Ecometer.
I found it for $11.84 on Walmart. http://www.walmart.com/ip/Bracketron...Mount/14248250
The other alternative was getting a flat mat. http://www.newegg.com/Product/Produc...82E16858999148
Old 07-23-2010, 03:08 AM   #277
caineroad
caineroad's Avatar
Drives: 06 Yaris HB CE
can someone tell me where is the odc II port located? thanks
caineroad is offline   Reply With Quote
Old 07-23-2010, 09:04 AM   #278
STC
"LibertyRides!"
STC's Avatar
It is on the left side under the dash in front of the fusebox.... Next to the interior hood pop-up latch.
Cheers!
~ Mark ~
Old 07-27-2010, 01:38 PM   #279
KrazyDawg
KrazyDawg's Avatar
Office Depot sells the clear 3M Dual Lock strips if you need more for under $3. My initial install wore off the adhesive since I didn't apply it long enough and I remove the Ecometer from the dash on a regular basis. In my opinion, the included 3M Dual Lock works better than velcro. It "snaps" into place and looks more durable.
Old 09-13-2010, 05:12 AM   #280
ezhacker1
ezhacker1's Avatar
Drives: Decepticon - Ravage
Bumping up my thread cuz its already filled with so much Ecometer info.
I have proven at least one so far that, the Ecometer is accurate to 0.002% (too high) on stock intake. On the AFE dry filter type 2 short ram it was consistenly ~10% too high AND using more fuel.
On my latest fill up (10.119gal/last bar blinking), i got
34.2mpg Reading / 34.12mpg actual
Compared with AFE
~35.6mpg Reading / 32.7mpg actual
I never touched the eco-meter settings. so the only thing changed is the airbox replaced, one thing to note is i ran these two tests on stock size tires, the 185-60-15 flavor, reset ECU, cleaned MAF sensor with MAF cleaner spray, mix of Neutral/DFCO. Ironic enough I also drove much more spirited on the stock box, and dropped .4mpg cuz i idled to power my sub when i was doing some settings.
I have no idea why the eco-meter reads higher value than actual with more air, which should equate to more fuel burned. So there you have it, stock air box/TIRES = perfect accuracy.
Ill do another tank on stock box, to prove without a doubt. Tho it sucks to roll on steelies...
Check out my Build thread:
Old 09-13-2010, 11:36 AM   #281
KrazyDawg
KrazyDawg's Avatar
Compared with AFE
I have a K&N air filter, stock tires, and steelies but my ecometer EFF was adjusted to 94 to make it 0.2% accurate. I also run my tire pressure at max sidewell of 44 PSI.
Old 09-13-2010, 05:49 PM   #282
ezhacker1
ezhacker1's Avatar
That's helps prove my point. Pretty sure at stock setting the eco meter would give you higher than actual. Plus I got to .002% 1/5th a percent. I'm gonna try to drive as conservative as I can this tank, then good bye steelies
Old 01-10-2013, 10:19 AM   #283
allannews
[url=http://www.news77.co
Drives: Man
Send a message via ICQ to allannews
Hello!
Good day!
I'm new here and came to this topic on www.yarisworld.com from yahoo search engine.
I really think this topic on www.yarisworld.com is really interesting.
I'm work on compared us payday loans related work and I have a blog which giving out info about loans
For those, who asked me about payday loans reviews, I've obtained useful news about it. Now I don't have to worry about the unexpected bill getting paid. No personal questions, bad credit accepted, and the money is directly deposited into your checking account. I would suggest http://www.news77.com/payday-loans/ to anyone who needs quick, fast payday loans.
There you can find the most trusted US compared lenders! I really hope that everyone here don't need some unexpected cash, but if any emergency appears, do not hesitate to use these services!
thanks.
allannews is offline   Reply With Quote
Old 01-10-2013, 10:07 PM   #284
nookandcrannycar
^^^^^ This. They are fantastic. I have been using them for at least 10 years. When you do apply enough pressure for a long enough period of time, the mount is rock solid for years on end. I currently have one strip on each side (driver and passenger) not too far from the lower corner of each side of the windshield. These were two previous locations for the little square antennae head for my XM radio (when I had that hooked up). I left the 'dash side of the lock' in place on each side to occasionally use with other accessories. I've found it is best to make sure any aftermarket protectant has been removed from the mounting location prior to mounting. I've always purchased these at Radio Shack for less than the amount you stated, but now I can't find them on the Radio Shack website. Good to know that Office Depot has them.
