Old 12-05-2018, 11:15 PM   #271
Civic_JDM
Drives: KSP130
Dear Experts
Please help to confirm if ECM # 89661-5C340 (Japnese spec, 1.0L engine i.e. 1KR-FE) support cruise control?
Civic_JDM is offline   Reply With Quote
Old 03-01-2019, 03:03 AM   #272
Stargate
Drives: Yaris Active 2018
Ciao, have Active Yaris 2018. I can't open for install Cruise control. Can you help me. Thanks
Inviato dal mio ONEPLUS A5010 utilizzando Tapatalk
Stargate is offline   Reply With Quote
Old 03-01-2019, 11:35 AM   #273
stykerdk
Yaris Hybrid Limited 2015
https://www.youtube.com/watch?v=H8r_oUV_plI
C-HR 1,8 Hybrid premium 2020
Old 07-01-2019, 04:23 PM   #274
Spidious
Spidious's Avatar
Drives: 2010 Toyota Yaris 5dr
Been thru this twice. If I have to plug in the cruise wires in the steering wheel connector which and what colors ? I have a 2017 Yaris L
Spidious is offline   Reply With Quote
Old 02-28-2022, 06:14 AM   #275
Immanuel
Drives: Yairs 2015 hybrid
Yaris hybrid 2015 CC install
Can I install CC on my 2015 Yaris hybrid? Has anyone tried? Can anyone tell me if it will work? Thanks
Immanuel is offline   Reply With Quote
Old 01-01-2023, 10:08 PM   #276
storyofakid10
Drives: Toyota Yaris 2012
^Nice!
By the way, I recently acquired a batch of the replacement covers for the side of the 2012-2013 steering wheel, which have the hole for the cruise control stalk. They are $5 shipped in the US.
Hi CTScott, I know this post is now 10 years old, but I am looking to install a CC stalk on my 2012 Toyota Yaris and am wondering if by any chance you are still selling the side steering wheel covers (with cutout for CC stalk) for $5? I am in the US. Thanks
storyofakid10 is offline   Reply With Quote
Old 07-20-2023, 04:33 PM   #277
lancap
Drives: Toyota Yaris NPL130L
Hi,
May someone help me, already sent a post, and had some help, but Am stuck.
( Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Technical Forums > DIY / Maintenance / Service
2014 Yaris Cruise Control - No Success )
I have this Yaris:
NLP130L-CHFNXW (2014 European Model MT)
ENGINE: 1NDTV 1400cc Diesel turbo
Can someone tell confirm the CC will not work on Yaris Diesel Models?
Thanks
Kind regards
lancap is offline   Reply With Quote
Old 10-10-2023, 05:23 AM   #278
velle
Drives: xp130 d4d
same here, no luck. from what i ve researched you will also need to route pin cables through the wheel to the ecu
velle is offline   Reply With Quote
Old 08-02-2026, 02:50 PM   #279
asura6
Drives: Yaris NSP130
I successfully installed the cruise control on a 2012 french made 1.3 L 6-speed Yaris. 1NR-FE. This version of the car had a different way of removing the steering pad as it had only one hole for accessing the clips which was located around 6-o'clock. You remove the steering pad by pushing a screwdriver through the hole to disengage the bottom clip and then you can disengage the other clips by pushing the steering pad upwards just using your hands. My steering wheel had audio buttons and and call buttons. There was a vacant 4-pin connector that I simply plugged in the cruise control stalks connector into and it started working.
asura6 is offline   Reply With Quote
cruise control. 2012
Cruise Control chessclubloser DIY / Maintenance / Service 11 03-27-2010 11:59 AM
