#19 |
Drives: 2014 White VITZ Join Date: May 2007
#20 |
School'er of hard knocks
Drives: Silver Yaris 4dr. HB Join Date: Oct 2008
I want someone to photo-chop an interceptor police light bar on the little Yaris.
#21 |
![]() ![]() ![]() ![]() Drives: 2008 Yaris HB Join Date: Oct 2008
Rally Yaris would be so cool.
#22 |
![]() ![]() ![]() Drives: 2008 Yaris Sedan Join Date: Oct 2008
i dont understand why anyone would want this.. i personally think it looks really bad. why not just put hids in your headlights and fog lights?
#23 |
![]() ![]() ![]() ![]() ![]() Drives: . Join Date: Feb 2007
Luckily, not everyone like the same things. It's what makes the world fun.
![]() I personally find underbumper "fog lights" to be a useless PITA, since any ilttle bump means they don't shine very far. I would much rather have the extra light at the same height as the heads. You say "tomayto", and I say "tomahto". |
#24 |
boohachimono
these would be easier to stuff in the grill hella ff75
#25 |
The Martian
I have a sketch I just did but I cant the scanner to work. I should have it soon though>.< My general idea is 4 round lights on the bumper itself right below the grille and then 4-5 Baja style lights on a low profile bar im fabricating that would fit on the roof. I will probably have to invest in a beefier alternator and an optima battery^-^
"The lead car is absolutely unique, except for the one behind it which is identical." – F1 commentator Murray Walker. |
#26 |
![]() ![]() ![]() Drives: 08 liftback 5spd Join Date: Oct 2008
i picked up a set of truck driving lights from NAPA, trucklite brand, but small profile rectangular (3x5 i believe). drilled holes vertically in lower grille, mounted lights hanging down. i left everything loose so i could manually adjust, and once tightened everything's holding up well enough. over bumps you can see it flex a bit when the lights jump, but they're light enough i don't expect any damage or trouble.
larger lights could be supported via the "bumper" or bumper mounts behind the plastic bumper cover.... ill post pics once i get around to taking them, i also installed an air horn at the same time that pulls around 10 amps and fits behind the grille... |
#27 |
Vroom Vroom Beep Beep
C-ONE makes a rally light bar for other models of the yaris that you may want to look at.
Ever blown out an R-200 diff god know's I have
#28 |
http://www.rhdjapan.com/jdm-low/C-ON...Pod-Vitz-52234
EXPENSIVE AS HELL!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!11
| Tags |
| lights offroad |
