#19 |
#20 |
Reluctantly Crouched...
Drives: 2008 Yaris HB M/T Join Date: Oct 2008
The 17's will have an effect, as will the 75 mph driving. Honestly, I think 30 mpg is respectable for the info you give about your driving.
Lafiro, low 30's tells me you drive a lot like me; relatively smooth, but still on the gas quite often. You like passing pokeys as much as I do? I get 33-34 around Dallas (80% freeway, 20% in-town) morning rush M-F, 39-41 on the highway (cruise set at 70). |
#21 |
I like passing slow people all the time. People hate slow drivers.
Red lights cause 20seconds-2minutes of idle wasted gas every time I stop. Could happen a few ties in a trip. Just filled this tank, exactly 30.5MPG again. But I noticed all my tired are around 31PSI. Maybe I should up that to 36? Or 40? Then again I will feel like bumps even more doing so which sucks. |
#22 | |
![]() ![]() ![]() Drives: '08 5-door Join Date: Apr 2009
#23 |
2008 Prht Miata Red
Drives: 2009 3D 4AM PWR Pkg, Yel Jolt Join Date: Feb 2009
The Only way i think you could get less than 30mpg with a 5sp Yaris is if Driving like a grampa you were lugging the engine too much,
this engine should be driven, not foot to the floor but enough to keep it in the proper rev range. I have an 09' automatic 3-door (totally stock) and get 35+ mpg with less than 10K, I drive 85% city, 15% hwy just my 2cts westgl |
#24 |
Half a Bubble Off Plumb
Drives: 2009 Yaris Sedan Join Date: Mar 2009
You're likely using the brakes too much. Every time you touch the brake pedal you're turning kinetic energy into waste heat. You built up that kinetic energy by burning gas. Drive like you didn't have any brakes.
#25 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 08 Yaris Sedan Join Date: Oct 2008
I typically adverage around 30 or close to 30. If i drive as economical as possible following my eco meter i can get about 36 to 38 on my normal commute.
#26 |
![]() ![]() ![]() ![]() ![]() Drives: car Join Date: Oct 2008
I drive like a bat out of hell with 205/50/16 tires and get 30 MPG without trying.
#27 |
Q(','Q)
I live in So. Cal near the beaches.
Temperature usually around the 75 degrees Fahrenheit on average. My commute for each tank is mostly 30city/70hwy. Traffic when I drive is usually in the Light category. The street I use most is mainly a flat road(Brookhurst), until the freeway on ramp(405) unfortunately the main road I use has a lot of street lights. I believe the speed limit is @ 45mph with 3-4 lanes. I drive a '07 3dr LB 5 speed manual with rear seat removed. Drive on 17x7 Konig Feathers with Toyo Proxes 215x40x17 Drive with Mobil 1 5w-20 syn oil, NST wp/alt/crank pullies, NST short shifter(don't know if this matters), and K&N filter. I don't have a scan-gauge so my MPG isn't accurate down to the last drop. I write how much I driven and divide it with the amount of gas I filled up with. I call it a rough estimate. I also don't have a Tachometer so I drive by feel. MY typical driving gear change will be: 1st: 0 to 18mph 2nd: 18-30mph 3rd: 30-40mph 4th: 40-50mph 5th: 50-72mph I'm not one to slowly creep up to my shifting speeds but I'm also not the one that fully opens throttle either. I'm not one to remove my foot and coast myself to slow down to the next red light(I will try it now though) but I'm also not a hard breaker. I tend to give 2 car sedan space in front of me so I can slow down accordingly. I find that since my car isn't so fast I just gave in to that fact and just go at my own flow. Most time I try to get the mid lane because it seems to have the smoothest flow. Far right lane tend to have drivers pulling into complexes(thus forcing other drivers in front of me to brake, usually late because they're impatient -_-) or pull into the far right lanes from complexes. That in turn will cause me to slow down or completely stop. I try to drive in middle lane on the freeway but sometimes the flow is just too fast(80+mph) so I just drive in the "slow" lane. I also try and avoid heavy traffic hours For the 2 1/2 years that I've been driving my Yaris I have yet to reach 40mpg, but then again I haven't actually tried. I just been satisfied with my 34mpg-36mpg per tank. The lowest I've ever gotten in one tank was 25mpg and that was because my friend was driving my car up hill with the A/C on the way to Vegas I'm sure smaller rims, coasting to stops, and slowly accelerating up to speed will help me reach 40mpg. We shall see. As for the OP. I hope my info I provided (how I drive, the conditions I'm driving in, and the specs I have on my car) will gives you a chance to compare and possibly help you reach your goal. |
#28 | |
Pretty green Yaris Verso
Drives: Toyota Yaris Verso Join Date: Mar 2009
#29 | |
![]() ![]() ![]() ![]() Drives: 2009 Meteorite 3dr Join Date: Jul 2009
Use momentum to keep you going. DFCO for slowing down, and slow down in advance if you're gonna get to a red light.
Touchscreen DVD Navigation - 10" Bazooka Subwoofer - Kenwood Speakers - Toyota Premium Horn set AFE Pro Dry Air Filter - modified air intake box - 1ZZ-FE Throttle Body - Ultra Racing Rear Sway Bar & Front Strut Bar NST in cabin & engine bay SSK's - TWM shifter base bushings & cable bushings - Megan Racing C-Pillar Brace |
#30 |
Thank you all for your responses. I've put the tips to good use and average 35 now. That's on 17" 75% city driving. Made me laugh.
#31 |
What?
Drives: 2007 Yaris LB Join Date: Nov 2008
Nicely done! Keep applying what you've learned and it will get even better as those things become habit.
I decided to drive a little more "normally" and just enjoy driving for a while, so on my current tank, I haven't really been hypermiling. I do the occasional jackrabbit start, wrap out 1st and 2nd gear to near the limiter, drive fast when traffic allows, etc. But, my "smooth cruising" and "coast when possible" habits still have me averaging nearly 37 mpg for this tank! |
#32 |
Loren, thanks for words of encouragement. I suppose you and I drive very similar. I can't help my peculiar ways. I have to feel the raw power of 78WHP sometimes lol.
#33 |
![]() ![]() Drives: 2008 Yaris LB 5 speed Join Date: Oct 2008
sig
| My progression into hypermiling | BailOut | General Yaris / Vitz Discussion | 8 | 10-13-2009 06:31 PM |
| 29.5 mpg | doublewam | Fuel Economy Forum | 26 | 06-24-2009 02:57 PM |
| Help me see 55 mpg! | Loren | Fuel Economy Forum | 76 | 04-02-2009 04:23 PM |
| Anyone from Missouri? MPG problems inside | 4MPG | Fuel Economy Forum | 31 | 12-17-2008 05:48 PM |
| Buddy Club Wheels | BulletProofAuto | Sponsors Classifieds Area | 8 | 10-19-2006 06:55 PM |
