Old 06-27-2011, 01:32 AM   #1
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
My new Leather Scion tC steering wheel!
Bought it off eBay. This is the link I bought it from:
http://cgi.ebay.com/ebaymotors/ws/eB...T#ht_500wt_956
only issue is that the wheel will sit crooked. The sl9otsin the locking ring don't line up properly with the Scion wheel I got. The stock yaris wheel has a ridge in the metal part that sits on top of two ridges in the locking right, whereas the Scion wheel does not have these ridges, and therefore mus sit crooked in the other slots in the locking ring. A bit irksome.. but it's leather!
Old 06-27-2011, 06:15 AM   #2
I have a TC one on Crashy. To make it not sit crooked, you rotate the clockspring by the width of that tab.
Old 06-27-2011, 10:34 AM   #3
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
doesn't that make your signal on one side shorter than the other?
Old 06-27-2011, 10:59 AM   #4
The signal cancel difference is really not even noticeable with how little you have to shift it.
Old 06-27-2011, 11:55 AM   #5
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
Awesome
Ill give it a shot in a bit when I have time!
Old 06-27-2011, 01:55 PM   #6
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
Hey CT, I shifted the locking ring to the left and now my wheel is straight BUT! for some reason it clicks excessively when I turn?
Old 06-27-2011, 02:12 PM   #7
Very strange. No clicking with mine.
Old 06-27-2011, 02:20 PM   #8
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
It sounds very.. patterned. They're not random. I hear two clicks when I reach a certain point, and then two clicks again when I pass back around the other way. The signals and everything work fine, but this annoying me. As far as I know I haven't rotated the clock spring a full cycle around accidentally so it's not like it could be off.. Maybe I'm crazy but, does your normal yaris click when you turn? More than just the once when the signal passes the point of return?
Old 06-27-2011, 02:29 PM   #9
No. Neither clicks. Are you sure that it's not your airbag screws making the clicking sound (provided that you haven't remounted the airbag yet)?
Old 06-27-2011, 03:51 PM   #10
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
Everything is on tight and proper
Old 06-27-2011, 04:11 PM   #11
I just pulled mine back off to take another look. If you look at the round part that inserts into the center of the clockspring, the continual diameter of the TC one is equal to the widest width of the Yaris one. I wonder if the extra material is sitting wrong on yours to where it is pushing against some of the fins on the inner surface of the clockspring and hence deforming the clockspring case enough to cause the clicking?
Old 06-27-2011, 04:21 PM   #12
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
It may be that you're right and it's not seated right. When I get back to my car in a bit I'm going to go e it another reseat. Which way did you orient your clocksprong? More clockwise or counter?
Old 06-27-2011, 05:24 PM   #13
The Clockspring connector is to the right of center.
Old 06-27-2011, 07:01 PM   #14
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
^ Which incidentally fixed my problem. I set it clockwise form center. Magically fixed itself.
Old 07-21-2011, 11:32 AM   #15
PROX4x4
1.5 or 2.5 both=0-60 in 8
Drives: 08 Toyota Yaris
Man what an idiot, I wish I knew about this, just wasted the money on a after market leather steering cover!
PROX4x4 is offline   Reply With Quote
Old 06-26-2012, 06:07 PM   #16
packetrace
packetrace's Avatar
Drives: Yaris Sedan 2009
does it fit with the silver parts that have the volume control ?
http://www.ebay.com/itm/Scion-TC-Ste...#ht_889wt_1344
Interior:ALL red, black roof
Old 06-26-2012, 06:21 PM   #17
No. They have to be removed to fit the Yaris' airbag.
Old 12-19-2013, 06:37 AM   #18
Originally Posted by TOLMACH View Post
F..ck .. still clicking ((
Bzinn mentions that something might need be trimmed..
http://www.yarisworld.com/forums/showthread.php?t=34749
Any opinions?
Thanks
I believe he is talking about the metal tab that prevents it from lining up straight (unless you tilt the clockspring a small amount).
Take the airbag off and rotate the steering wheel back and forth to see where the clicking is coming from. The TC wheel I have on Crashy does not click.
The Yaris Steering Wheel wornways General Yaris / Vitz Discussion 12 10-09-2012 01:41 PM
Scion XB/XD Silver/Dark Grey Leather Steering wheel DED1982 Items for Sale by private party 15 07-30-2010 08:51 AM
Leather Steering Wheel MGargano Cosmetic Modifications (Exterior/Interior) 29 05-08-2009 04:53 PM
OEM foglight switch and leather wrap steering wheel 808yarisLB Cosmetic Modifications (Exterior/Interior) 8 03-11-2009 12:05 AM
SCION SPORT STEERING WHEEL, RED, XA AND XB, 03 TO 06 justoneyaris Items for Sale by private party 3 12-04-2008 06:30 PM
