Old 09-22-2012, 06:03 PM   #19
BennyLava
Drives: 1987 Silverado
I just want to get rid of that horrific factory wheel gap, but not have enough left to be able to say something like:
"Yeah, its lowered... but it still looks like it should have gone down just a bit more..."
I hate when that happens.
BennyLava is offline   Reply With Quote
Old 09-22-2012, 06:14 PM   #20
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
Yea that's why I upgraded to coilovers
Old 09-22-2012, 11:10 PM   #21
The OP is asking for a medium drop, 1.5" to 1.75" if I read it correctly. S Techs drop 2" or very close to it.
I would recommend the Sportlines, our MI springs or H&R.
H&R have such a nice ride, being a progressive spring that gets stiffer when you corner hard.
Old 09-23-2012, 05:01 PM   #22
Originally Posted by BennyLava View Post
Bout like stock?
Nope, nothing like stock. lol
Old 09-23-2012, 06:29 PM   #23
ciscobear
Drives: Toyota Belta
Then you want Tein S-Tech Springs.....
ciscobear is offline   Reply With Quote
Old 09-23-2012, 06:38 PM   #24
BennyLava
I now have Megan coilovers which I love. The adjustability of ride height and stiffness is awesome and you can dial your car in to the exact settings you desire. The drop and dampening can be a lot higher than springs or a lot lower depending how you set it. But those are pretty expensive, a little easier than springs to install though.
btw my ksport springs only ran about $100 shipped.
Got a link to the exact Megan combo setup you're running? That sounds like the right way to go for me. I'm seldom satisfied with the ride height after lowering a car. So maybe I'll just save up and get those. That way I can adjust the ride height to be what I want.
The other member says they ride kinda rough. Don't want that at all cause the wife also drives this car sometimes when needed. And I really don't want to hear her complain about how I messed up the ride quality of that car. So which springs should I go with that really aren't going to change the ride quality? But still lower the car enough.
Old 09-23-2012, 06:48 PM   #25
1.5
Form>Function
1.5's Avatar
KSPORTS!!!!!
But here's the Megan's link
http://shop.microimageonline.com/Meg...R-CDK-TY07.htm
Old 09-23-2012, 10:52 PM   #26
I gave three choices, and you said "they" ride kinda rough. which ones did you mean?
The H&R or Sportlines are going to be a nice, firm ride.
The Tanabe DF210 springs will give you a FACTORY ride while lowering the car.
Old 09-23-2012, 11:06 PM   #27
BennyLava
Sorry I meant the Tien S-techs. I believe it was 1.5 who said that they don't ride anything like the factory ride quality. I'm looking to go as low as I can possibly go, while still keeping factory ride quality. Something tells me that's about 1.5 inches max.
Old 09-23-2012, 11:12 PM   #28
1.5
Form>Function
1.5's Avatar
That was kaotic who said that. I never rode on s techs.
You said you want 1.5-1.75 no less but then you said you want almost no wheel gap and that you don't want to drop it and then think it's not enough. This all makes it sound like you may want more of a drop than you thought. For the lowest spring drop its going to be s techs with a few others coming in close second like ksports and MI. The ride will be considerably stiffer. I can say the ksports actually retain a very smooth cushy ride for having a more a aggressive drop. The shorter drops should be closer to stock feel but will give you very minimal ride height change.
And again there are coilovers.
Old 09-24-2012, 12:20 AM   #29
b20vteg
no show, no go :(
b20vteg's Avatar
Drives: 2012 yaris 3dr hb
i just dropped my car on s-techs 2 weeks ago, and on stock shocks, mine rides completely like stock.
b20vteg is offline   Reply With Quote
Old 09-24-2012, 12:20 AM   #30
1.5
Form>Function
1.5's Avatar
I doubt that ^
Old 09-24-2012, 12:23 AM   #31
b20vteg
no show, no go :(
b20vteg's Avatar
I doubt that ^
why would i lie about something like that? then again, i've heard the gen3s ride stiffer than gen2s...
Old 09-24-2012, 12:39 AM   #32
Freestylin
Freestylin's Avatar
Drives: 09 Blizzard Pearl RS LB
There is less suspension travel to absorb the bumps with a stiffer rate and shorter springs.
Freestylin is offline   Reply With Quote
Old 09-24-2012, 12:43 AM   #33
b20vteg
no show, no go :(
b20vteg's Avatar
i cut off half of my bump stops - about 1.5 to 2 inches - makes up for the reduced height.
Old 09-24-2012, 01:23 AM   #34
Yeah, they are nothing like factory. No boat feeling. But then I do drive around with max psi in my tires.
Old 09-24-2012, 01:26 AM   #35
But yeah, keep in mind that I'm on TRD Sportivo dampers, 205/40/17 tires on max psi, and I do have spring coil spacers in the rear.
Old 09-24-2012, 06:10 AM   #36
1.5
Form>Function
1.5's Avatar
@b20, lowering springs have to be stiffer than stock or the car would bottom out on like every bump and you'd be eating up your tires with your fenders. I did some searching and our stock spring rate is ~130lbs and the s techs are rated ~165 lbs (both front rates). So you're trying to say either teins numbers are off or you can't feel the difference between the two. Its just almost impossible for the teins to not be stiffer. That's all we're saying.
Dash Kit - No Mods barryware In Car Entertainment + Electronics (audio / video / alarm) 8 09-14-2014 03:59 PM
what to look out for when installing lowering springs songa Performance Modifications 34 09-15-2012 03:29 AM
I need a body kit LA Yaris California 1 11-06-2009 01:26 AM
Is aftermarket HID kit legal (in NJ)? Jfoofoo Cosmetic Modifications (Exterior/Interior) 25 03-19-2009 02:05 PM
