Old 04-14-2007, 11:47 AM   #19
eijikikimaru
Q(','Q)
eijikikimaru's Avatar
Drives: 3dr Meteroite
Hell yeah...
YEah that does look so much cleaner w/o the door handle... perphaps my next mod after the sideview mirrors
eijikikimaru is offline   Reply With Quote
Old 04-14-2007, 02:45 PM   #20
Clarence
Drives: yaris 1.3automatic '04
i love shaved doors^^
best if rear doors are suicide doors! like RX8
Clarence is offline   Reply With Quote
Old 04-14-2007, 05:50 PM   #21
yrsdrgn
yrsdrgn's Avatar
Drives: 2007 Yaris
if some one finds a kit for the trunk handle removal then hook it up!
Old 04-14-2007, 07:30 PM   #22
Black Yaris
der Zeck
Black Yaris's Avatar
There is not going to be a kit, for say, it is more you buy what you need an put it together, and weld the hold shut, and paint over it
Old 04-15-2007, 08:16 PM   #23
yrsdrgn
yrsdrgn's Avatar
Drives: 2007 Yaris
what would be needed to have it open up by remote? as for welding the hold shut I'm guessing sheet metal then weld then paint.
Old 04-15-2007, 10:45 PM   #24
Black Yaris
der Zeck
just need to wire up a solenoid to a keyless entry pad (this is not as easy as it sounds, after you remove most of the locking mechanism you are going to have to rig something up), and you got the rest
Old 04-15-2007, 10:48 PM   #25
yrsdrgn
yrsdrgn's Avatar
Drives: 2007 Yaris
o. Sounds way too risky to a newbie like myself. I'd rather wait until someone more experienced has done it and shows us how it's done.
Old 04-16-2007, 06:39 AM   #26
Chris07LB
Chris07LB's Avatar
Drives: Yaris Liftback
If you plan on getting an alarm, you will be able to use the channels, to pop each door by itself.. or hatch, whatever you may be doing.
My CompuStar has 4 channels, and you can also get their channel expander to run, for example, my strobe's from my remote, roll down the windows by remote, etc.
Rear hatch wouldnt be hard at all. To patch that small void, and wire in one solenoid is not hard, especially if its getting wired into one of the channels of your alarm. Remember, you will need poppers though. Like mentioned in my last reply, this will force the door/hatch to "pop" open once the solenoid releases the latch inside. It will also keep it "propped" up so you dont need to be standing right next to the hatch before it relatches again.
Old 04-16-2007, 08:03 AM   #27
ChinoCharles
Drives: LB
User acrbill had some nice pictures from when he installed a solenoid-based power hatch. This would be step one for anyone interested in eventually going with a shaved hatch.
http://yarisworld.com/forums/showthread.php?t=2947
Old 04-16-2007, 08:59 AM   #28
DollaZo
DollaZo's Avatar
Drives: Toyota Yaris YRS
Originally Posted by echo_hrs View Post
Did mine this morning...
Cheers
would it be illegal to do the side indicators?
DollaZo is offline   Reply With Quote
Old 04-16-2007, 09:13 AM   #29
kurokoma-kun
Drives: 2007 Yaris HB
oh lordy... better hope your clicker does not stop working... mine did after a couple years... "breaking into" my own fweakin car with alarm going off was real pain in the arse... new clicker cost $99 from dealer plus $35 for programming... I ended up having to lock with key for two more years
Old 04-16-2007, 01:09 PM   #30
Chris07LB
Chris07LB's Avatar
Thats why whenever you shave ANYTHING on the exterior that aids in entering your car, you have emergency pull cables hidden underneath.
Its attached directly to the solenoid, so if your "clicker" or battery ever go dead, you dont have to break into your own car.
Old 04-16-2007, 02:19 PM   #31
ChinoCharles
Drives: LB
Neither does John Doedamnhejuststolemycar.
Just out of curiosity, lets say you wanted to shave the side markers. You gain access to the inside of the fender and weld a plate behind the hole, then use bondo to fill the rest of the gap left to match with the rest of the fender? Or, do you have to cut the right sized piece of sheet metal to fit the hole left from removing the marker, then kind of precision weld that piece in place, then use bondo to finish? Does either way work?
Old 04-17-2007, 01:38 AM   #32
from what I understand a proper job will not need bondo, just weld a replacement piece in and polish the whole area smooth, then repaint.
Old 04-17-2007, 02:07 AM   #33
yrsdrgn
yrsdrgn's Avatar
Drives: 2007 Yaris
i wonder. who will be the first with the shaved door handles or trunk handle or side marker lights on the yaris?
Old 04-17-2007, 02:35 AM   #34
spkrman
Drives: 1
i think the car could stand to have shaved handles, would really clean up the lines
Old 04-17-2007, 06:53 AM   #35
Chris07LB
Chris07LB's Avatar
Well Chino has seeen first hand what a shaved job should look like... secret pictures, oh yea he does.
2007 Greenest Vehicles redglare45 General Yaris / Vitz Discussion 14 02-20-2007 02:51 AM
Calling All College Graduate Finance People! mutatio New YARIS Purchase Forum 0 01-12-2007 10:08 PM
Install a Yaris deck into a Matrix... bad idea?? Help needed!! SimmZ In Car Entertainment + Electronics (audio / video / alarm) 4 12-17-2006 01:01 AM
REALLY BAD CAR ACCIDENT! MacMaster761 General Yaris / Vitz Discussion 25 11-30-2006 11:20 AM
GTA People jcove Items for Sale by private party 0 05-07-2006 09:39 AM
