Old 07-24-2007, 03:36 AM   #19
Kioshi
Heart Up! Vitz
Kioshi's Avatar
Drives: トヨタ Vitz
When's the DIY gonna be posted up rwseattle? Waiting for it this whole time haha. Desperate need of an easy-to-install tach ^_^
Old 07-24-2007, 12:16 PM   #20
REM
REM's Avatar
Drives: 2012 Nissan Leaf SL
Okay, I posted a few pictures in my garage. You can see how slim the tach is and I even snapped a picture with my storage box door open.
Cheers,
Ryan
REM is offline   Reply With Quote
Old 07-24-2007, 01:31 PM   #21
Meteorite Man
Passin' The Gas...Station
Meteorite Man's Avatar
Drives: Same As You But Different
Send a message via Yahoo to Meteorite Man
Thanks for the pics. That helps me out alot. I like the placement. Are there 4 wires? Looks pretty simple. Did you pull that steering column to mount the tach with screws/bolts?
Again, thanks for the help.
Chuck
MY Gas Station Attendant Misses Me...
Chuck
Meteorite Man is offline   Reply With Quote
Old 07-24-2007, 04:58 PM   #22
rwseattle
Rwseattle
rwseattle's Avatar
Drives: 2007 Toyota Yaris (BASE)
DIY
First remove:
2 screws in the front of the steering wheel. Turn the steering wheel and you will see the screws. (DO NOT REMOVE THE HORN COVER, TURN THE WHEEL AND YOU WILL FIND THEM)
You will find 3 screws at the bottom of the steering column that hold the plastic cover. After removing the 3 screws you can pull the plastic top/bottom part of the steering column and install you new tach. You can also pull you wiring nicely behind the dashboard.
4 wires,
1. Black, ground wire
2. Red main power wire
3. White tach light wire
4. Green RPM signal wire
1. I attached the ground inside the driver side kick panel.
2 and 3. I attached the red power/white light wire to the primary stereo power line
4. I attached the green RPM signal wire in to the ECU wiring block under the driver side dashboard. Its the most left wire in the connector block. This is the connector block that the ScangaugeII guys use.
It's pretty easy. You could decide to attached the white light wire to the dimmer on the driver side but, I didn't really mind having the light on in the tach 24/7.
Hopefully that helps.
RwSeattle.
rwseattle is offline   Reply With Quote
Old 07-24-2007, 04:59 PM   #23
rwseattle
Rwseattle
rwseattle's Avatar
REM nice tach. Looks great.
Old 07-24-2007, 06:07 PM   #24
REM
REM's Avatar
rwseattle,
Thanks, I actually like the way yours looks better, but I use my storage box, so I was unable to use the Autometer tach.
Cheers,
Ryan
Old 07-31-2007, 01:19 AM   #25
cm07yaris
Drives: 2007 Toyota Yaris Blazing Blue
Send a message via AIM to cm07yaris
What is the exact red line for a 2007 Liftback, Manual Transmission?
cm07yaris is offline   Reply With Quote
Old 07-31-2007, 11:38 PM   #26
REM
REM's Avatar
I'm pretty sure it is 6,500. Someone correct me if I am wrong.
Cheers,
Ryan
Old 08-07-2007, 09:25 PM   #27
DorytheYaris
aka Eleni
DorytheYaris's Avatar
Drives: 10 Yaris LB Auto- Blazing Blue
I like it. It reminds me of the Tachometer in a MINI Cooper.
Repeat Offender
Former owner 2007 2 dr Liftback ("Dory") - Blazing Blue
Former owner 2009 2 dr Liftback ("Wendy") - Blazing Blue
Current owner 2010 4 dr Liftback - Totaled after 5 months :'( Blazing Blue
DorytheYaris is offline   Reply With Quote
Old 08-07-2007, 09:31 PM   #28
cdmyaris
cdmyaris's Avatar
Drives: 07 Yaris Liftback
ur right. Its at 6500. Btw, awesome idea for your tach.
cdmyaris is offline   Reply With Quote
Old 08-13-2007, 10:03 PM   #29
decesarebrian
decesarebrian's Avatar
Drives: 07' Yaris HB
I hate micro fuses
So I have had the car for 4 days and decided to install a tach. Well me and my friend did everything in about ten minutes and then spent a half an hour pulling out a fuse! Haha Im gonna buy some real small pullers! The tach looks great and is 100% accurate though so I'm a happy camper. I didn't realize gears12 and 3 were so big and 4-5 so small. Sweet.
07 Yaris Hatch Crap MTX
Meteorite Grey
decesarebrian is offline   Reply With Quote
Installed Tach...Tach works, RADIO doesn't! 5spBlazer DIY / Maintenance / Service 17 08-06-2007 09:57 PM
Pictures of tach 5spBlazer Photo-Video-Media Gallery 14 07-10-2007 10:03 AM
US Yaris: Adding a tach? Thirty-Nine General Yaris / Vitz Discussion 159 04-05-2007 09:23 AM
Auto-Meter Silver Sport Comp Mini Tach ChinoCharles In Car Entertainment + Electronics (audio / video / alarm) 7 02-26-2007 06:14 PM
Liftback - Easiest Way to Get a Tach and Cruise Control... weeze-dog General Yaris / Vitz Discussion 60 10-20-2006 06:40 PM
