Old 11-27-2009, 07:54 PM   #55
Lazerdot
Lazerdot's Avatar
Drives: Blazing Blue 08 liftback
Not sure the answer.
I can give tech a call next week.
One Year One Oil-AMSOIL at www.Trulube.com TRD Exhaust, Springs and Struts. TRD SSK. NST Underdrive Crank Pulley. Amsoil Dominator 10w-30 Racing Oil, Amsoil DOT4 brake fluid, Amsoil Severe Gear 75w-90 transmission oil, Ultra Racing 23mm Sway Bar, Camber Bolts, R1 Drilled Slotted front Brakes and SS Brake cables from Micro-Image. Orange Konig Daylight 17s, Kumo MXs. Greg@TruLube.com
Lazerdot is offline   Reply With Quote
Old 11-27-2009, 08:02 PM   #56
woof
Drives: Yaris 3dr Hatch/Black
If you want your 60K warranty you obviously have to go every 5K miles to change. Right now I do 5K using GTX full synth. I'm thinking about going Amsoil for longer oil changes.
Porsche, Mercedes, Audi, VW are letting customers go 10K on Mobile One so why not go longer with Amsoil? I have it in my manual and it is good stuff.
woof is offline   Reply With Quote
Old 11-27-2009, 10:21 PM   #57
Lazerdot
Lazerdot's Avatar
Longer drain intervals used by Amsoil will not void your warranty. But the filters have got to be changed more often in the Toyotas then the 25,000 miles Amsoil usually allows with the EAO oil filters.
Old 11-28-2009, 12:54 PM   #58
deerebilt
Drives: 2008 Yaris sedan S
i think synthetic oil is a waste of money unless you are running a nhra funny car. no one knows what is in synthetic oil anyway. or what base oil stock is used. use a name brand petroluem oil and filter, change at 3000 mi or oem recommended interval and i believe you will have no oil related failures. also any fuel mileage gains will not offset the price.
deerebilt is offline   Reply With Quote
Old 11-28-2009, 06:47 PM   #59
UTVitz
UTVitz's Avatar
Drives: Black Vitz Liftback
Synthetic is probably not the most cost effective choice for people that change their oil religiously or don't keep there car long enough to matter. However, Toyota had to settle a class action law suit a few years back for sludged up motors due to 7500 mile oil change intervals being too long with conventional oil. Now they recommend 5000 miles accross the board on their vehicles which none of them come with synthetic from the factory. Tiny oil passages, higher operating temps-trying to get more power out of smaller displacement motors-after a lot of consideration and since I do my own oil changes I finally jumped ship deciding my to give synthetic a try. It took some trial and error with some brands-but finally settled on expensive redline and feel comfortable going 5000 miles now between changes. Before I switched you definitely want to change conventional oil every 3k and those were coming too frequently for me with all the road trips I was making.
Old 11-28-2009, 07:40 PM   #60
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
Toyotas covered by the Louisiana settlement include the:
• Camry 4 cylinder from 1997-2001,
• Camry 6 cylinder from 1997-2002,
• Camry Solara 4 cylinder from 1999-2001,
• Camry Solara 6 cylinder 1999-2002,
• Sienna 6 cylinder from 1998-2002,
• Avalon 6 cylinder from 1997-2002,
• Celica 4 cylinder from 1997-1999,
• Highlander 6 cylinder from 2001-2002,
• Lexus ES 300 from 1997-2002 and
• Lexus RX 300 from 1999-2002.
Read more: http://www.consumeraffairs.com/news0...#ixzz0YCk1Z2Ka
Old 11-29-2009, 01:15 PM   #61
toad
toad's Avatar
Drives: street-legal go-kart
someone earlier mentioned the filter is just as important as the oil. i just changed the wife's yaris with pennzoil platinum 5w-30 and a mobil1 'extended performance' filter. i know the platinum is good stuff, but are the mobil1 filters any good(i would hope so as the filter retailed for 12.99 at autozone, but i got a deal for 5 quarts pp and mobil1 filter for 27.99)? i'm hoping this combination will get me 7500-10,000 miles as i'm already out of warranty(i normally change every 5000-6000, but i figure the fancy filter and full synthetic will help extend that).
toad is offline   Reply With Quote
Old 11-29-2009, 07:52 PM   #62
06silveryaris
Drives: 2006 yaris
Mobil 1 filters are very good quality and so are the pure one from purelator. You should be just fine with that oci
06silveryaris is offline   Reply With Quote
Old 11-30-2009, 02:18 PM   #63
HTM Yaris
resident senior
HTM Yaris's Avatar
Drives: 07 Yaris
I have 85K miles on my Yaris (07). I use Amsoil with Toyota air and oil filters ( Sparks Toyota sells a case of 10 oil filters for $30 ). I change my oil @ 10K intervals and filters at 5K intervals . I have been doing 10k oil changes since 30k . My other Yaris (09) has 8k miles . It was driven off the lot with Amsoil . The 09 will also see 10k oil change intervals .
Old 12-03-2009, 06:37 PM   #64
Go4th
Go4th's Avatar
Drives: Yaris S Sedan color Flint Mica
Amsoil once a year
I use AMSOIL 5w30 w/AMSOIL filter EAo09 and change it once a year. I do not go over 20k and will change at 20k if I do.
Go4th is offline   Reply With Quote
Old 12-03-2009, 07:35 PM   #65
Lazerdot
Lazerdot's Avatar
The EAO09 filter is no longer recommended for extended use in our cars due to the Toyota engine issue that came up with the 1.8 liters. The filter should be changed at OEM intervals. Amsoil does recommend the MANN filter for use up to 7500 miles if used with Amsoil.
Ask your Amsoil dealer for more info or e-mail me and I'll send the TSB.
best synthetic oil and m/t oil?? doodoo DIY / Maintenance / Service 122 04-03-2017 08:43 PM
Synthetic Oil Questions. Twistoffate0817 General Yaris / Vitz Discussion 19 07-15-2009 08:54 PM
