Old 05-19-2009, 05:21 PM   #91
gwasabi
Drives: 07 Blazing Blue LB
no i think u gotta put resisters in between?
Most Satisfying Crew
Serious Business...
MunkyWurks Garage - 8088488794
gwasabi is offline   Reply With Quote
Old 05-19-2009, 05:39 PM   #92
Originally Posted by Taiyaki View Post
Ok so to get rid of it without a switch all you have to do it start off with the light not on, turn off the car, unplug the thing, and cut the green and brown wire and connect them to eachother, and leave the harness unplugged?
Jump to post 45 and you'll see the resistor voltage divider. You need to make one of those up. Clipping the wires turned out to not work.
Old 05-20-2009, 03:56 AM   #93
Taiyaki
アキバ製
Taiyaki's Avatar
Ok i think ill just put a switch in it.
Old 05-20-2009, 07:34 AM   #94
Just to clarify; adding the switch doesn't really make it any easier. If you want to do it without the switch, you build the voltage divider shown below (from page 3 of this thread). You unplug the TPWS connector (and leave it disconnected) and connect the red wire to the red wire show below, the black wire to the white wire shown below, and you connect the green wire to the brown wire below.
The switch method is just for people who run two sets of rims with one of the two sets still having the sensors installed.
Old 05-25-2009, 10:42 PM   #95
Taiyaki
アキバ製
Taiyaki's Avatar
Ok so a few days ago I did this. I added a switch. And it worked perfect for a few days. But now the light flashes and when I turn the switch off is stays on (doesn't flash).
Old 05-25-2009, 10:48 PM   #96
Measure the voltage on the brown wire.
Old 05-26-2009, 05:48 AM   #97
regal
I'm not getting any voltage off the brown, white, or red wire, where is the fuse for this thing?
Old 05-26-2009, 06:21 AM   #98
It's the ECU-IG 10A fuse.
Old 05-26-2009, 06:29 AM   #99
regal
Thanks where would that be located?
Old 05-26-2009, 07:34 AM   #100
In the fuse panel that faces the driver's side floor mat at the bottom left of the dash.
Old 05-26-2009, 07:43 AM   #101
regal
looks like I'm buying an 09 service manual there is no such fuse in that location
Old 05-26-2009, 07:47 AM   #102
TIRE AND WHEEL TIRE PRESSURE WARNING SYSTEM ECU Power Source Circuit (2009 Yaris).bmp
Old 05-26-2009, 07:59 AM   #103
regal
nothing there but I butch of relays, no fuses
Old 05-26-2009, 08:54 AM   #104
regal
are these odd ball fuses or something?
Old 05-26-2009, 09:17 AM   #105
You're looking in the wrong place. Lay on the floor and look up at the bottom of the dash (directly under where you are looking). You'll see a plastic panel with the fuse locations. Pull that plastic cover off and the fuses will be visible.
Old 05-27-2009, 06:19 AM   #106
regal
found it thanks a bunch
Old 05-28-2009, 09:14 AM   #107
regal
but now when I turn my headlights on the instrument panel goes dim, under daytime running lights the dash is illuminated, very odd and can't find anything in the owners manual.
Old 05-28-2009, 09:40 AM   #108
That's the normal behavior for the instrument panel lighting - Full bright with headlights off and dimmed, per the knob, with headlights on.
Tire pressure sensors Tink1 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 11 10-21-2008 05:53 PM
