Old 06-23-2016, 10:32 PM   #127
NJP440
2010EGGHATCH
NJP440's Avatar
Drives: White 2010 Yaris Hatch
Originally Posted by codemonkey23 View Post
is this plug and play?
Just have to follow what the comment above you says and you'll be good
Sent from my SM-G920T using Tapatalk
IG: 2010EGGHATCH
NJP440 is offline   Reply With Quote
Old 06-27-2016, 02:57 AM   #128
codemonkey23
Drives: 2015 Toyota Vios
thanks for your response..
i have saved some important pointers from this thread about the swap.
another question is do we need to have a piggyback ECU to tune the A/F mixture? since we are running 55mm TB, doesn't that make the fuel mixtures lean?
so basically what i understood on my back-read.
  • 1st slap in 1zz-fe TB in the intake manifold. screw 4 screw
  • plug the connector
  • look for the epoxied screw, and adjust idle to 600 - 700 rpm
then ENJOY??
codemonkey23 is offline   Reply With Quote
Old 06-27-2016, 11:18 AM   #129
tarkus
tarkus's Avatar
Drives: 2006 Yaris RS 3-Door
You've forgotten about the chip swap. Not sure though if the swap is required for the 0D030 TB version.
Sent from my LG-D801 using Tapatalk
Old 06-27-2016, 08:30 PM   #130
codemonkey23
oh.. right.. i have to re read about that chip swap.. i don't think it was discussed here in detail
Old 06-28-2016, 08:06 AM   #131
Fluxtasy
feed my pet
Fluxtasy's Avatar
Drives: Yaris Sedan '10
I bought the 0D030 and did not require a chip swap
Fluxtasy is offline   Reply With Quote
Old 06-29-2016, 01:22 AM   #132
codemonkey23
hello everyone,
what is the chip swap for?
i mean every throttle body has a wiring socket right? so i will just unplug the wire socket from the 2nzfe TB then snap it into 1zzfe TB? then check if the butterfly opens when accelerator is depressed?
i am confused.. if the TB works why do i have to swap the chip?
and what is the chip? can sombody post a picture of the chip? :D :D i only know potato chips :D :D
Old 06-29-2016, 05:40 AM   #133
Fluxtasy
feed my pet
Fluxtasy's Avatar
I believe you will have idling issues if you don't do the chip swap. Try to source a 0D030 TB and save yourself the hassle on the chip swap. There's a thread somewhere on it.
Old 06-29-2016, 11:22 PM   #134
codemonkey23
oh i thought that i can fix idling issues by removing the epoxy on the allen screw of the TB? turn it 1 round counter clockwise?
thanks for replying
Old 06-30-2016, 01:48 PM   #135
tarkus
tarkus's Avatar
You will need to adjust that screw as well. This is all explained in previous posts in this thread.
Old 06-30-2016, 10:16 PM   #136
codemonkey23
yep.. but i guess the chip swap was not discussed
Old 10-29-2016, 11:49 PM   #137
rabbito
rabbito's Avatar
Originally Posted by yariseggvvti View Post
How's the sounds like when you run 2.5" exhaust? Did you delete resonator and second CAT? Do you lose any lower end and getting more high end. VVTI kicks harder?
Thanks!
responding after 2 years later..lol...2nd cat delete do increase the flow and faster rpm gain...con is the bumble bee noise when accelerating up to 2000rpm, no more sound after 2000rpm 😣
Sent from my SM-J710F using Tapatalk
Cosmetic: Toyota red emblem
Old 11-29-2016, 11:01 AM   #138
JessMess
Drives: 08 Yaris hatch back
Does anybody know what years and models have the 1zz motor?? I do alot of junkyard shopping lol what car would i find the correct TB??
JessMess is offline   Reply With Quote
Old 12-01-2016, 10:18 PM   #139
rabbito
rabbito's Avatar
any 60mm should fit...you should look for steel intake manifold for corolla 1zz...this one is really hard to come by...you have to modify the adapter a little bit but out comes pretty crazy..
Old 05-25-2017, 03:37 PM   #140
Yaris874
Yaris874's Avatar
Drives: 07 yaris hatchback
Uuuu
Sent from my SM-G935T using Tapatalk
Yaris874 is offline   Reply With Quote
Old 05-25-2017, 03:42 PM   #141
NJP440
2010EGGHATCH
NJP440's Avatar
Are we reviving this thread? Lol
Sent from my LG-H918 using Tapatalk
IG: 2010EGGHATCH
Old 05-25-2017, 04:02 PM   #142
Yaris874
Yaris874's Avatar
I was just thinking of putting the 1zz throttle body lol I wanna to read the thread later wat u think
Old 05-25-2017, 04:03 PM   #143
Yaris874
Yaris874's Avatar
And any 1zz fit ??
Old 05-25-2017, 04:05 PM   #144
NJP440
2010EGGHATCH
NJP440's Avatar
I think its a good idea. I still haven't installed mine yet its just sitting in a box in my closet but I'm installing my header and cold air intake this Saturday so the throttle body will be the next install on my list. Ill post up pics and reviews once its installed. If you're on Facebook my name is Nicholas Prendergast and on Instagram I'm 2010egghatch I always post updates on both as well
IG: 2010EGGHATCH
TPS reading at WOT with 1ZZ throttle body? 4/20 NEVER FORGET Performance Modifications 14 07-02-2023 04:20 AM
Installed the 1zz throttle body - AlexNet0 DIY / Maintenance / Service 135 08-01-2014 07:57 AM
FS: 1ZZ throttle body and Fujita intake mrbond Items for Sale by private party 25 09-08-2009 10:21 PM
Intake to match the 1ZZ throttle body fuji DIY / Maintenance / Service 2 06-17-2009 10:02 PM
For Sale: 1ZZ Throttle Body and 0.25" aluminum wheel spacers m911gt Items for Sale by private party 6 04-25-2009 08:52 PM
