Old 01-05-2010, 03:11 PM   #145
Doc Zaius
Lurker supreme!
Doc Zaius's Avatar
Drives: old and boosted!
Originally Posted by kuyabheda View Post
I am new here and my car (2008 yaris) did that yesterday- with both abs and ! coming on..They told me 2 wks for the part. 2 $%&*^@ wks without a car.. and they dont offer any courtesy vehicle at all.
You are OK to drive. Brakes will basically be functioning same as none ABS equipped vehicles.
Yeah, I've been driving with those lights on for about 8 months now... it's fine, just no ABS. Waiting till spring to try to clean the contacts.
2006 Red Blitzed RS 5-door
Old 01-07-2010, 02:22 PM   #146
devinlamothe
devinlamothe's Avatar
Drives: '07 Yaris HB
Originally Posted by firstyaris View Post
Just had this issue. Warranty lapsed. I am not a mechanic, does anyone have pictures where these contacts/connectors are so I can clean them?
I can take some pics but it won't be until summer ... since I don't have a garage where I can work in the winter.
But if you need to do it now you can always take a look here http://www.etimago.com/yaris/repairm...%20Control.pdf
Page 97 is where the installation/removal diagrams are for the ABS sensors are on the front and rear wheels.
devinlamothe is offline   Reply With Quote
Old 01-07-2010, 02:28 PM   #147
grchristoff
Drives: 2007 yaris
Hi there, new to the list but I am having the same problerm; ABS/Brake light came on just recently during a snow storm.
If someone has pictures of what needs to be changed that would be great as my 2007 yaris 4dsd is off warranty now.
I wouldn't think it would be too hard to install the sensor or wiring but resetting the computer is probably something the dealer would have to do.
grchristoff is offline   Reply With Quote
Old 01-07-2010, 02:43 PM   #148
devinlamothe
From what I can tell the lights should go off by themselves once the ECU regains connection to the speed sensors. I know this since it happens to me once the ice/snow/sludge/whatever is dislodged from the sensors, my lights go back off and ABS works again.
For those of you looking for part #s, I have them for the 2007 Hatch, dunno if they are the same across all years:
SENSOR, SPEED, FRONT RH
89542-52050
SENSOR, SPEED, FRONT LH
89543-52050
SENSOR, SPEED, REAR RH
89544-52040
SENSOR, SPEED, REAR LH
89544-52040
The wire harness is:
WIRE, SKID CONTROL SENSOR
89516-52090 NCP91..CND; RH
89516-52100 NCP91..CND; LH
Old 01-07-2010, 03:57 PM   #149
grchristoff
Drives: 2007 yaris
Devin,
Thank you every much for these part numbers. That helps immensely.
greg
Old 01-07-2010, 04:25 PM   #150
fidgell
Drives: 2006 Yaris RS 3 door
I had these two lights come on last week, and ABS didnt work during that period. Yesterday I jacked the car up, took off the rear wheels and fixed it myself - I have only a basic knowledge of fixing stuff, the most Ive done on the Yaris to date is change front rotors/pads so no expert knowledge required!
Once the wheel is off you will see a plug - the only one you will see - on the rear of the drum near the axle. A small screwdriver is needed to push the plug (gently) off the socket and hey presto....Get cleaning! I used a compressed air cleaner like one would use on a PC keyboard to clean the snow/crap out then WD40 to clean. Cleared any excess off with the air again then put the plug back. Finally a little grease on the small gap between plug and socket and wheel back on.
I got in turned the key and drove off.... NO lights on.... ABS working as it should.
I suggest everyone do this BEFORE going to the dealer as it will save you a fortune. It took 20 mins to do both sides and is as easy as taking off the wheel!
Southern Ontario weather does cause problems to the little car, but this is a free fix... well free if you have cleaning products already in the house!
If anyone wants it, PM me and ill go outside and photograph the plug area for you... But I dont know how to post it on here so ill have to email it!!! Proof its easy to do eh?
fidgell is offline   Reply With Quote
Old 01-07-2010, 05:50 PM   #151
Old 01-07-2010, 07:00 PM   #152
devinlamothe
Sweet you know what, I think I will try that tomorrow. Maybe I will post a DIY.
Also wouldn't hurt to apply some dielectric grease on the connection ... maybe that would help keep out some of the grunge.
I'll see if crappy tire sells some.
Old 01-07-2010, 07:59 PM   #153
Adriaan
In between cities
Adriaan's Avatar
Drives: 2006 yaris ce
You can go to the DIY section and download the 2007 Yaris Factory Repair Manual. or go on line to http://www.etimago.com/yaris/repairmanual/.
From there go to brake control or BC
for the front it BC 94 - 97
for the rear it BC 98
When i did it i was able to park inside a heated garage. Wash under the car to remove the road salt and that stupid anti-gel crap they spray on the roads here. That stuff is so bad for cars. It the same stuff they use on planes and if left on for a while can cause problems. Anyways once that is all clean. Disconnect the negative terminal, and start in front. I used contact cleaner it doesn't leave any residue and film. Clean the sensor and the chamber it goes into. Not sure if dw40 would be good for the chamber since i believe it need the fiction to tell the abs brake sensor whats going on. Do the same for the rear plug and apply dielectric grease on the connections. Iy should be good till the summer.
After doing this i found that it still comes back every once in a while, But when it very cold and the car sits outside for more that five hours. I thing it because the grease freeze and can't work as well. But after five to ten minutes the light goes out. or when i restart the car its fine for the rest of the day. I'm hoping it just a problem with the early models. If so maybe i can get parts from a 2009 or 2010 and switch them out, if there the same. Hope this helps.
Adriaan is offline   Reply With Quote
Old 01-08-2010, 04:48 PM   #154
Doc Zaius
Lurker supreme!
Doc Zaius's Avatar
Originally Posted by fidgell View Post
... A small screwdriver is needed to push the plug (gently) off the socket and hey presto....Get cleaning! ...
This small step caused me hours of frustration last spring when I installed my wheel spacers! Argh!
Old 01-10-2010, 02:49 AM   #155
asiliat
Drives: 2007 Yaris Hatch
Yep, ABS works again for me too. I used WD40 and then dielectric grease to coat the plug to keep salt out going forward. When I switch between summers/winters, I'll probably wipe and re-coat as needed.
Yes, definitely need a screwdriver. Pry the tab gently open at the top, and then push it out and away from the drum brake itself (I used the same screwdriver - flat head to push it out). Make sure to use WD40 or the like and soak it for a couple of minutes before trying to remove, minimizing risk of breaking the clip. It should make a small "pop" sound when it comes off.
BTW, I joined the forum JUST thank you for reporting this fix. :D
asiliat is offline   Reply With Quote
Old 01-12-2010, 07:43 AM   #156
grchristoff
Drives: 2007 yaris
This sounds pretty easy and straight forward. I plan on doing mine this weekend.
Old 01-13-2010, 04:40 PM   #157
Spockis53
Drives: 2007 Yaris
I have a 2007 Yaris with ABS. The first rear ABS sensor and wiring harness needed to be replaced (under warranty) at 59,000km. And now the other rear ABS sensor and wiring harness need to be replaced at 80,000km. ... for $900.00 !!!
It seems these things are becoming consummables!
Spockis53 is offline   Reply With Quote
Old 01-13-2010, 07:34 PM   #158
devinlamothe
WOA OK first of all the parts shouldn't even come close to that $, your dealer is ripping you off like CRAZY.
I would first try the DIY here to see if that fixed the issue.
Old 01-15-2010, 06:31 AM   #159
mijemc
Hej
I have a Yaris from 2006. I have it from brand new 30-3-2006. I am from Denmark
At 36.243 km. ABS VSC lights came on. fix by the dealer.
At 41.277 km. ABS VSC lights came on. fix by the dealer.
At 104.000 km. ABS VSC lights came on. the dealer say that there is no longer warranty on the car. Damm !
Today I am startet to do the things that figdell is telling, hope it works.
I will see if I can take some fotos today.
I hope that you can understand my School English.
mijemc is offline   Reply With Quote
Old 01-18-2010, 10:33 AM   #160
mijemc
Hej
I try the things that figdell is telling about, but no luck.
It a shame, becouse I like to drive my littel car.
Old 01-18-2010, 11:57 AM   #161
Doc Zaius
Lurker supreme!
Doc Zaius's Avatar
That is too bad. I hope it works for me when I try it!
Old 01-18-2010, 12:17 PM   #162
devinlamothe
Me too I still haven't gotten around to do it yet. I just bought a new torque wrench so I will be doing it soon.
Man I really hope it works.
