09-22-2011, 10:20 AM | #1 |
Drives: Yaris '07 Join Date: Dec 2010
power steering off
hi guys, I need a little help:
I own a 2007 1.0 toyota yaris and this is what happened: I lost - power steering -indicators - radio -cig lighter - power steering liquid. and the engine light is on. can someone tell what this can be? I've checked most of the fuses and thy seem ok. regards |
09-22-2011, 11:13 AM | #2 |
Drives: Yaris sedan Join Date: Apr 2011
Do you have electric power steering. See the Rayleigh
I like very much travel |
09-22-2011, 01:59 PM | #3 |
yes, I do have electric power steering.
What is the Rayleight? regards |
09-22-2011, 02:02 PM | #4 |
I wanted to say RELAY
09-22-2011, 03:23 PM | #5 |
can u tell me where the relay and fuse of this item are located?
regards |
09-22-2011, 04:00 PM | #6 |
Drives: 09 5dr LB, 2x 08 3dr LB Join Date: Oct 2008
For how many things are out, I would check the following fuses:
ECU-IG, DOME, ACC - (All are in the fuse panel that is under the bottom of the dash).
09-22-2011, 04:33 PM | #7 |
for example, the cigarrete lighter is not working although its fuse is ok.
is there any fuse that controls some of the other fuses, like a " master fuse"? ´ I forgot to say that the car is starting and running ok |
09-22-2011, 07:25 PM | #8 |
The AM2 fuse is the next level up for the lighter. Above that, the 60A fusible link, which is part of the positive battery terminal.
09-23-2011, 05:17 AM | #9 |
Is there any chance that the problem comes from the alternator? Because the car is starting and running but some other features ( electric power steering, windows, wipers, indicators, radio) that require power are not working.
Regards |
09-23-2011, 06:49 AM | #10 | |
All of the things listed above that are not working are ignition switched, but not alternator dependent. Did you check the AM2 fuse? Besides it, the IG1 relay is involved. IG1 is the relay on the bottom left of the under dash fuse panel. IG2
09-24-2011, 12:01 PM | #11 |
the fuse in question is the AM1.
thank you |
09-11-2012, 02:22 PM | #12 |
Drives: yaris sedan AKA belta Join Date: Sep 2012
hi
hi i have been reading all the comments here
i have a toyota belta aka yaris sedan ,,,,its 07 30000kms done 1.0 L it was running absolutely fine since few days my steering is bit heavier than it should be its like 75 out 100 its working fine but slightly heavier and that annoys me as its power steering so it should be soft and smooth kindly advise me what i should do to make it lighter thanks alot for you time |
09-11-2012, 02:38 PM | #13 | |
09-11-2012, 11:02 PM | #14 | |
Drives: 2('14+'07)MT 3d ,wHandCrWndws! Join Date: May 2009
Similar Threads | ||||
Electric power steering | Geoff Peace | DIY / Maintenance / Service | 4 | 04-10-2018 05:28 AM |
Power Steering Fluid | jstantherprsn | DIY / Maintenance / Service | 8 | 04-05-2016 06:24 PM |
Power Steering Light | sıɹɐʎ | DIY / Maintenance / Service | 12 | 02-19-2014 07:22 PM |
Temporary lack of power steering, abs, fan, airbags!! | the other hand | DIY / Maintenance / Service | 11 | 12-24-2010 10:34 PM |
Can't find power steering reservoir on '10, is there one? | JerseyJeff84 | DIY / Maintenance / Service | 4 | 09-07-2010 10:47 AM |
