12-07-2008, 09:48 PM | #1 |
here again..
remote start rumor...
ok, so I heard a rumor that we can actually install a remote starter on a standar '08LB, the rumor is that there's an actual sensor that tells the remote starter when the car is in neutral hence it start the car, and the best part is that because of this safety sensor it won't void the warranty...anyone care to share some light in the matter? Is it truth?
Don't be threating me with a good time!!! |
12-07-2008, 09:56 PM | #2 |
Drives: 2008 blazing blue yaris LB Join Date: Oct 2008
remote starters cant void warranty unless it is installed wrong and causes a problem
http://cardomain.com/ride/3151056 mods: custom sub box, i hit 141.4 db, new speakers, double-din nav, foglights, cruise, CAI, strut brace, under car braces, short antenna, remote start, alarm, actuators in doors and hatch coming soon: window tint, custom sub grills, tach and........ |
12-07-2008, 10:03 PM | #3 |
here again..
what they told me was that because in order for the remote starter to work you'll need to bypass the clutch safety pressure switch and that would void it (at least on older vehicles they told me that) now because of this rumored "neutral sensor" bypassing the pressure switch would not void anything or you wouldn't even need to touch it since you'll conect the starter to the sensor instead...
12-08-2008, 03:03 AM | #4 |
A rumor? lol.
12-08-2008, 04:03 AM | #5 |
it may have changed for the 08's, but on the 07's there's a clutch sensor that needs to be bypassed, for manual cars, and the automatics have essentially the same system, so that the car must be in neutral to start, maybe that's what you are referring to?
The price of freedom of religion, or of speech, or of the press, is that we must put up with a good deal of rubbish. - Robert Jackson Bye bye 1NZ... |
12-08-2008, 08:59 AM | #6 |
my 04 xrs had remote start...it was s 6spd
you end up having to leave it in neutral w/ the ebrake on, or it wont work....starting the car w/o the starter i still had to push the clutch in.... never had any problems with mine, but i had it professionally installed. acutally, i have my alarm/starter sitting in a box if you wanna buy it, lol
12-08-2008, 09:02 AM | #7 |
Start another Oil Thread!
i can build you a neutral safety switch.. it mounts to your shift linkage and your shifter cage.
12-08-2008, 01:30 PM | #8 |
Just call me Ray, better?
uhm how much are you asking for it??
12-08-2008, 06:06 PM | #9 |
here again..
+1 here...let me know how can we get that...
12-08-2008, 11:07 PM | #10 |
all u need is a pulse while cranking output on the rs which all DEI systems have and use that with a relay to trip the clutch wire while starting then it will work, as for actually finding a nuetral safety wire, i had no luck finding any wires in these cars.
12-13-2008, 05:03 AM | #11 |
neutral saftey switch its normally a switch mounted to the trans i did one on a maual liftback worked fine and its an 08 just recently did it to but i just hooked it up to the black wire on the clutch switch which is the starter side wire
08 junction produce belta almost done and ready for paint 06 junction produce tc 604 bhp 445tq ddriven still trying for 700+hp 90 crx sir ls vtec turbo 755 hp mecp masters certified |
12-28-2008, 10:53 PM | #12 |
I just did my '07 LB 5spd w/ remote start, I just pressure crimped the two wires together on the switch itself behind the clutch pedal, and there you go, no more clutch safety switch. You just have to be sure its in neutral when you leave the car or you'll have it take off on you when you start it.
Similar Threads | ||||
Northeast DIY Remote Start / Keyless Entry Workshop - Sunday, October 26 | CTScott | General Yaris / Vitz Discussion | 51 | 11-10-2012 01:32 PM |
Viper Remote Start | goku87 | In Car Entertainment + Electronics (audio / video / alarm) | 4 | 12-13-2008 05:06 AM |
warranty issues & remote start | homerj | In Car Entertainment + Electronics (audio / video / alarm) | 14 | 11-27-2008 12:19 PM |
checkmate burglary alarm and remote sart 4/s | deadworld | Items for Sale by private party | 2 | 09-09-2007 11:25 AM |
yaris sedan remote trunk relase question pls help soon | fantabulousbaby | New YARIS Purchase Forum | 4 | 08-05-2006 01:26 AM |
