Old 11-27-2022, 02:01 PM   #1
Suey 1958
Drives: 2007 toyota Yaris
Spark plug choices
I have 235k miles (2007 hatchback) on original plugs and still runs perfect but want to change them. The guy at auto zone said the cheap 3 dollar plugs won't do the job and iridium plugs are a must. If that is true, then I will buy the 10 dollar iridium's. Not sure if that was a sales pitch or if iridiums are really necessary. Thanks
Suey 1958 is offline   Reply With Quote
Old 11-27-2022, 08:06 PM   #2
bronsin
bronsin's Avatar
Not necessary at all in my experience. We have a tech day for Honda ST 1300 motorcycles and we change a lot of plugs. One guy with 35,000 miles on his iridium equipped ST found a damaged iridium plug. Not sure how it got damaged. Another guy from Columbia with 75,000 miles on his bike have the original conventional plugs. We went to honda to get new ones but they didn’t have any. So we just carefully gapped and reinstall the old ones. Machine ran like a watch.
Old 11-27-2022, 09:09 PM   #3
NYC-SE
NYC-SE's Avatar
Drives: 2014 Yaris SE
The Yaris is spec'd for iridium plugs. DENSO SK16R11 or NGK IFR5A11, as per the manual.
Old 11-28-2022, 04:33 PM   #4
sh0rtlife
personaly ive found a few things with plugs...
NGK on euro/jap/bike
champion on small engine/american older stuff and BIKES
autolites are hit n miss at best..cheep plug you toss in something your selling
bosche seem to only work well in volvo/MB/bmw and some audis..but not most vw's
as far as the iridums go...they work well on modern engines not so much on "old" stuff...that said i noticed an improvement when i changed the yaris plugs at 100k
but ive only ever found issues with BRAND vs make/model not so much what "type" of plug it is
Old 11-28-2022, 05:19 PM   #5
mitch9521
Gen 3 > Gen 2
mitch9521's Avatar
Drives: NCP131, F-150
Denso or NGK only. I change mine every 60,000 miles or so.
2014 NCP131 5 Speed
2007 F150 4.2L 5 Speed
Old 11-28-2022, 08:03 PM   #6
bronsin
bronsin's Avatar
I would definitely NOT Be spending $40 plus on a car with 235,000 miles on it. Go with the three dollar plugs for $12! YEAH !
Then leave them in there for 100,000 miles. I change the plugs on my wife’s Camry at 150,000 miles it didn’t make any difference at all cost $40
The plugs I took out were excellent condition. I couldn’t bear to throw them out.
The only thing I recommend about changing spark plugs is take them out every 30,000 miles or so and clean the threads. On my wife’s Camry I left them in for 150,000 miles and when I try to take them out they were stuck. To get them out I had to start the engine and remove them with the engine hot. Than it was easy
Old 11-30-2022, 06:09 AM   #7
Suey 1958
Thanks for the input. I think I will go with the 12 dollar set.
Anyone know what the gap should be on those?
Old 11-30-2022, 08:05 AM   #8
bronsin
bronsin's Avatar
These will only sent you back eight dollars
Actually the the autolights Are only $1.10 apiece!
Gap is ..44
https://www.rockauto.com/en/catalog/...park+plug,7212
Old 11-30-2022, 10:46 AM   #9
Suey 1958
Thanks Bronsin, I appreciate the info.
Old 12-02-2022, 05:55 PM   #10
remcafee
yikes, im worried about all the bad advise going around, the 1nzfe is made for iridium plugs, nothing else, period!
Old 12-02-2022, 08:16 PM   #11
Why exactly do you say that? I ran old school Champion plugs for a couple years. Honestly didn't notice a lick of performance or fuel economy differences compared to the iridium.
Old 12-12-2022, 04:50 PM   #12
remcafee
because you run the risk of increasing carbon in combustion chamber, worse fuel economy, power, the 1nzfe was tuned and calibrated to run iridium spark plugs that can take high heat from fairly lean afrs like the 1nzfe, you could be ok with your champion plugs now, but in reality you technically are not maximizing the life of your engine
Old 12-12-2022, 04:52 PM   #13
remcafee
oh yeah and not to mention that iridium is more conductive than copper so it takes less voltage to spike and fire the spark, so you are also prematurely wearing out the ignition coils
Old 12-13-2022, 08:13 AM   #14
bronsin
bronsin's Avatar
An interesting theory. Can you quote a source on that?
Old 12-13-2022, 02:17 PM   #15
thetut
Drives: 2007 4dr sedan
https://www.championautoparts.com/Pa...Materials.html
thetut is offline   Reply With Quote
Old 12-13-2022, 07:01 PM   #16
bronsin
bronsin's Avatar
Yes you can set a .44 gap on those plugs.
But I’m pretty sure you can’t gap Iridium plugs without damaging them. That is if you find the gap on your iridium plugs much greater than .44 bending the plug will damage it.
Old 12-13-2022, 08:06 PM   #17
bronsin
bronsin's Avatar
dear thetut
That was an interesting piece. But it didn’t explain why copper core plugs will wear out your coils. I also didn’t get from it why copper core plugs would cause premature engine wear
Old 12-14-2022, 12:43 PM   #18
thetut
More research required but I'm too lazy.
Spark plug gap for Toyota Platz 2005 1.0L expee15 DIY / Maintenance / Service 2 09-22-2021 05:49 AM
Replacing spark plug wire with bell wire bronsin Off-topic / Other Cars / Everything else Discussions 1 11-11-2020 01:17 PM
bit of spark plug insulation may have fallen into cylinder alagappan the proud DIY / Maintenance / Service 20 01-09-2014 06:10 PM
Spark plug replacement vinny121 DIY / Maintenance / Service 3 08-29-2013 12:25 PM
How hard I should try to remove spark plug mf4361 DIY / Maintenance / Service 24 03-30-2013 02:07 PM
