#55 |
![]() Drives: Yaris Join Date: Oct 2008
I am planning to install a cheap kit in the yaris using the original stalk and relay in the inside part of the car. However, since there is no possibility of getting the adapted harness, could you tell me which kind of pins should be used to connect both lights to pin 1 and 2 in the relay box?
#56 |
![]() ![]() Drives: 2007 5dr canadian import Join Date: Dec 2016
dead links suck....
just got a "cheep" ebay kit and let me tell you what i got was on par with OE if not better...actual glass lenses, OE switch etc 40$ well spent after multiple passes thru this site digging for the hookup points on dash etc i eventualy figured it out |
#57 | |
![]() Drives: Mazda Join Date: Nov 2021
#58 |
![]() Drives: 2013 Toyota Yaris LE Hatchback Join Date: Aug 2021
Ok, I bought a new Stalk Switch. I'm just trying to find where the relay is located for my Daughter's 2013 Yaris. The loom connection for the bulbs are there. The fuses are in the fuse boxes that are identified as front Fog Lights. I'll buy whatever the f**k i need to buy for her car to work safely but the link you gave to micro whatever took me to a site when I clicked the Toyota Yaris tab it took me to a Nissan parts manual. Really appreciate a direction to get things for this vehicle. I see buying a Yaris in the Midwest is as bad as buying a Toyota in 1978 with respect to finding documentation on it. Everything is RHD.
At any rate any help would be appreciated. I can't find the damn relay or where it should be.on this 2013. Her 2010 was so much easier. After reading the entire thread, not realizing it went back several years and rhe Microimage has been closed for years now. Do I need to short any pins on the Stalk Switch connector? I bought a new switch with the Fog light switch on it for the 2013. It's installed as are a nice set of Fog Lights and Ultra 2 GTR Lighting LED fog light bulbs so I'd really like to get these fired up for her. Just can't seem to find the relay or where it needs to be installed. Last edited by Captamrica; 01-02-2022 at 07:16 PM. |
#59 |
Was hoping to find CTScott was still around since the last post on this thread was in 2016. His PM box has exceeded. It's storage cap so I'm guessing he's not around anymore. Guess I'll figure this out myself. Finding schematics on this vehicle sucks.
#60 | |
Gen 3 > Gen 2
Drives: 2014 LE, 2007 F150 Join Date: Jul 2019
Totally pre-wired, no finding fog light relay nonsense. Even the indicator on the gauge cluster works.
2014 NCP131 5 Speed 2007 F150 4.2L 5 Speed ![]() |
#61 | |
![]() Drives: 2015 Toyota Yaris LE Hatchie Join Date: Oct 2021
![]() Quote:
https://www.youtube.com/watch?v=drqpznBdnaw |
Thread Tools | |
Display Modes | |
DIY (08' USDM Liftback): ESUSE Fog Light Install v2.0 | goku87 | DIY / Maintenance / Service | 125 | 08-23-2015 09:12 PM |
Fog Light wiring | Rammy | DIY / Maintenance / Service | 0 | 11-08-2012 08:34 PM |
viene viene FOG LIGHT IN Da HOUSE!!! | toro yaris pr | Caribbean | 27 | 07-18-2010 04:50 PM |
My Yaris Fog Light | ezlove0710 | DIY / Maintenance / Service | 7 | 08-07-2009 06:15 PM |
DIY:Day time running light Disabled with stock fog light remain function | summergxz | DIY / Maintenance / Service | 12 | 09-26-2007 10:42 AM |
