subtle rattle
i have a 2009, yaris with 284k miles. Recently noticed a subtle rattle/vibration noise that comes on after 30-40 mph and only under load, if i remove my foot off the pedal the noise goes away. It kinda sounds like a purring kitten but not load enough to hear if the radio is on. It appears to be coming from the tranny or cv axles area. it does not do it in idle or when the car is just coasting in neutral. Anybody heard this noise before or know what's about to go bad on the car?
I'd start looking at the front wheel bearings. Does the "purring" change at all when curving to the left or right on the road?
![]() ![]() ![]() Drives: 2010 yaris 3 door hatch Join Date: Jun 2013
Most likely a heat shield, they rust out around the bolt head. All you need to do is pull the bolt out an reinstall with a large washer. The first one that did it on my car was the one in the front of the tunnel.
rattle sound
No,not when turning left or right. like i said it does not do it when coasting. I believe that if it was the bearings it would do it when the wheels were turning and in neutral. it only purrs like that when under tranny load or accelerating and only around 40-60 mph.
rattle sound
where exactly is this heat shield? you mean the muffler shield? but it only does it when under load or when pressing the gas pedal, it doesn't do it at random or when coasting in neutral. i'll crawl under there this weekend and see what i find loose or what?
Good to see you amended thread topic to Subtle Rattle rather than Subtle Sound. A heat shield rattle could never be described as a kitten purring.
The first heat shield to let loose is often the one bolted to the exhaust manifold directly behind the engine. All others are visible from under the vehicle placed at strategic positions along the run of the exhaust.
#7 | |
subtle rattle
![]() ![]() Drives: 2007 Toyota Yaris Sedan Join Date: Feb 2019
My wheel bearings make noise but have zero play. I've been chasing down a purring noise, wobbling noise, and clattering noise. I'm just attributing this to old age and twice bent wheels that I've straightened twice with a large hammer. 345k miles. Original everything, except for sway bar, crash damage, and home rebuilt alternator
#9 | |
subtle rattle
![]() ![]() ![]() Drives: 2007 Toyota Yaris 3 door Join Date: Sep 2018
if its accelerating under load, its a driveline issue, look at your cv joints and makes theres no grease splooging out everywhere, check your transmission fluid, could also be an internal issue with the tranny, if its an automatic, the torque converter could be having a shudder
#11 | |
noise
Since you've not stated that you've ruled them out, my money is still on bearings. Your milage is high enough for them to be starting to fail. CVs typically last much longer than bearings under normal circumstances.
Noise
But if it was wheel bearings wouldn't it still make the noise when I lift my foot off the gas Pedal or coasting in Neutral ? It only does it when under load and after about 40-50 mph, if I release the gas Pedal the noise goes away.
![]() Drives: 2007 Toyota Yaris Join Date: Dec 2021
Not always, I have heard bearings just make noise under load. A simple check would be jack front of car up, both wheels off ground and put it in gear and let wheels spin. Then you can hold the strut and could easily feel a bad bearing.
Thread Tools | |
Display Modes | |
Uh oh another engine bay rattle.... | YAR1S | DIY / Maintenance / Service | 15 | 06-02-2014 05:56 AM |
rattle in right side rear cargo area | D-Flo | DIY / Maintenance / Service | 17 | 05-13-2014 11:17 PM |
Rattle noise under the speaker’s cover - sedan | karat747 | DIY / Maintenance / Service | 1 | 10-22-2011 08:41 AM |
Please help with Rattle coming from cam cover? | c-dub | DIY / Maintenance / Service | 11 | 08-07-2011 09:33 PM |
2010 US 5 door stock exhaust, big rattle | 127.0.0.1 | DIY / Maintenance / Service | 3 | 06-20-2010 09:39 AM |
