Old 04-15-2022, 04:35 PM   #1
xdarkxfirex
Drives: 2015 yaris le
Coolant filler neck
How often do these need replacement? Alot of times my arm is leaning beside it flexing it a little but nothing is leaking. I spray rubber protectant on it and plastic parts under the hood every once in a while
xdarkxfirex is offline   Reply With Quote
Old 04-21-2022, 09:46 PM   #2
remcafee
you can get an aftermarket metal one, or just replace it and get that weight off your chest, they will break eventually.
Old 04-21-2022, 10:47 PM   #3
mitch9521
Gen 3 > Gen 2
mitch9521's Avatar
Drives: 2014 LE, 2007 F150
I have an aluminum one on my car that I got from Aliexpress, it cost under 30 bucks and is actually good quality. Just be careful when working around it if the engine is hot as the aluminum holds a lot of heat(way more than the plastic one) and will burn your arm, I know from experience.
2014 NCP131 5 Speed
2007 F150 4.2L 5 Speed
Old 05-06-2022, 10:26 PM   #4
xdarkxfirex
For me personally I would rather keep one extra so when I replace the coolant next it's there. The one I got from AliExpress was like $19 cad with shipping and 5 star reviews.
Hopefully I won't have to do the water pump on this car like the old yaris
I only ever recall seeing one break on a friend's 2010 RAV4. I believe the ones with the tiny hose outlets are easier to break
Old 05-19-2022, 11:07 PM   #5
xdarkxfirex
I got one with AliExpress. I noticed glue around where the overflow hose attached. Is yours like that? The listing pictures dont seen to have that on the one I ordered but all the others do. I hope that won't be a failure point for them in the future. I expected it to be on solid piece
T Montague's 2zr swap - '08 m/t sedan some extra info tmontague Performance Modifications 285 04-20-2021 11:56 AM
What is a (or the) coorect coolant & amount for a Yaris? RMcG DIY / Maintenance / Service 0 06-19-2019 05:36 PM
Removal of petrol filler neck and wheel arch welding SilverChariot DIY / Maintenance / Service 1 06-18-2017 07:44 AM
Coolant Level in filler neck? CB900F2 DIY / Maintenance / Service 26 05-18-2014 05:09 AM
toyota yaris sedan, missing flap just inside fuel filler neck 41magmag41 General Yaris / Vitz Discussion 3 10-17-2010 04:43 PM
Copyright ©2000 - 2022, vBulletin Solutions Inc.
