Old 02-24-2023, 11:19 AM   #1
Griffin6218
Drives: 2004 1.0 yaris
Wheel studs
Hi
2004 1.0 yaris
Can I replace front wheel studs without removing hub?
Thanks.
Griffin6218 is offline   Reply With Quote
Old 02-24-2023, 07:45 PM   #2
ex-x-fire
You should be able to, there should be a notch in the knuckle for the stud to pass through.
You'll have to take the caliper and rotor off.
Replace wheel studs on rear. CB900F2 DIY / Maintenance / Service 1 06-20-2022 06:19 PM
ARP Wheel Studs ArmstrongRacing Wheels, Tires and Suspension Forum sponsored by The Tire Rack 0 12-15-2018 11:08 PM
Wheel bearing / Outer TRE / Control Arm replacement howto shepd DIY / Maintenance / Service 3 09-14-2015 04:20 PM
Longer wheel studs for 5mm spacer? Captain Slow Wheels, Tires and Suspension Forum sponsored by The Tire Rack 7 02-09-2013 10:35 PM
