02-07-2021, 05:24 PM | #361 |
Drives: 5D YR 2012 Auto Join Date: Aug 2020
Hey all, I ended up finding super cheap stock 15x5.5" alloy wheels from the ZR model (i'm in Australia) which I painted black. Also I'm not sure what they ZR models are called in other places but basically the top model.
Now I'm not sure what tyre size to get. Someone suggested 185/55/15. Stock for these wheels are 175/65 but I'm not sure what to get. I just don't want anything to make the car feel sluggish. Any suggestions? |
02-07-2021, 07:57 PM | #362 |
^^^ In the US, OEM is 185/60/15.
02-09-2021, 05:04 AM | #363 |
Thanks, I may as well go with that then.
02-11-2021, 11:17 PM | #364 |
Drives: 2006 YRX 5D HB Join Date: Feb 2021
Hey guys
Does this offset guide apply to all model hatch back NCP10 to NCP130? Looking at 15x7 TE37sl in staggered offsets +34 front & +24 rear Last edited by Financial Mistake; 02-11-2021 at 11:27 PM. Reason: Left off wheel sizing |
03-24-2021, 10:14 AM | #365 |
Drives: 2010 Toyota Yaris 5Door Join Date: Mar 2021
I am just getting into autocross and getting close to replacing my old tires with something slightly better but still an All Season tire for now. Wish there were more options in All Season 15s. Right now looking at Kumho Ecsta PA31 195/55/15.
I think 195 should be the max width I could run on stock rims? Anyone run 195/55/15s on the stock 15X5.5 rims? |
03-24-2021, 11:33 AM | #366 | |
Drives: 06 2ZR Turbo Yaris RS Join Date: Aug 2017
03-24-2021, 08:36 PM | #367 |
3 Yaris and counting..
I run 205/50/15 on stock alloy rims and tein stech springs. Other than the tire guys complaining they were hard to get the beads seated, all is good
04-23-2021, 07:59 AM | #368 |
Drives: 2012 3 Door 5 speed Yaris L Join Date: Sep 2020
Max width on 15’s before needing to modify?
Hey all, I intend on doing some autocross in my 2012 Yaris. Next big purchase is rims/tires. What is the max width I can get away with on a set of 15’s before I have to start modifying to avoid rubbing?
05-23-2021, 04:13 AM | #369 |
Drives: Forester XT Join Date: May 2021
Hi all
New member from Australia looking to purchase a 3dr hatch as a daily driver. Will be keen to apply a few basic handling/suspension mods. I'll want to lower it modestly, perhaps an inch or so. I've trawled the wheel threads for some great inspiration. Looking at: ROTA GRID 16x7 +40 ROTA SLIPSTREAM 16x7 +38 With modest (1-2") lowering and sensible/standard diameter rubber would I run into rubbing issues with either of these? I note the +40 would be closer to OE offset. Any advice much appreciated! |
05-23-2021, 06:02 AM | #370 |
Drives: Starlet Join Date: Nov 2017
Assuming you'll be using a 205 tyre. You shouldn't rub with either a +38 or +40
05-23-2021, 06:09 AM | #371 |
05-23-2021, 06:33 AM | #372 |
At that size, 60kph would be showing as 58.3 on the speedo.
205/50 would read 60.3 on the speedo when doing 60kph. |
05-23-2021, 06:44 AM | #373 |
05-23-2021, 07:04 AM | #374 |
Sorry, my bad before. For 205/45, when the speedo reads 60, you'll be doing 58.3. Apologies.
05-23-2021, 10:14 AM | #375 |
05-23-2021, 03:54 PM | #376 |
Gen 3 > Gen 2
Drives: NCP131, F-150 Join Date: Jul 2019
I run 205/45/16 on 16x7 wheels with no issue. offset is +42mm if I remember right. 1.5" drop.
2014 NCP131 5 Speed 2007 F150 4.2L 5 Speed 2013 Rav4 LE AWD Autotragic - Wife's |
05-23-2021, 09:27 PM | #377 |
I can't say with certainty, but your speedo will likely still over read even with 205/50 16. Every Toyota I've owned has over read. My Yaris running 195/50 16 reads 60kph when in fact my 20hz gps module hooked up to my phone reads 53-54. And it's nearly 10kph out when I hit 110 :).
05-24-2021, 12:28 AM | #378 | |
Thread Tools | |
Display Modes | |
Similar Threads | ||||
Tamago's guide to ultimate yaris handling | Tamago | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 98 | 02-18-2024 05:45 AM |
NEWS: TOYOTA REVEALS ALL-NEW YARIS SEDAN AT 2006 LOS ANGELES AUTO SHOW | VitzBoy | General Yaris / Vitz Discussion | 7 | 09-20-2023 07:50 AM |
News : 2007 Toyota Yaris - the little Euro's official arrival | VitzBoy | General Yaris / Vitz Discussion | 9 | 06-06-2017 12:51 AM |
2007 Yaris Pricing Info ! | YarisBueller | New YARIS Purchase Forum | 104 | 06-24-2009 04:54 PM |
