Old 08-22-2020, 01:44 PM   #1
johnmick
Drives: Yaris 2014 Sept.
DIY AC system *important*
For those who buys this kind of gauge kit and whats to DIY
checking or DIY top off refrigerant ... BE CAREFUL !!!
Yaris has an small AC system, and this gauge kit came with
1.5 meter pipeline each, and 2 pipeline both blue and red is 3 meters.
So ... the refrigerant needs to fill up both blue & red pipeline to reach
the gauge meters... right? ... and also you wants to squize the air out ...
*** this will cost you around 1/5 to 1/4 system's refrigerant ***
If you are at very low refrigerant, after the checkings surely you will
run under low limit refrigerant level ...
Without the checkings, you're just at safe low refrigerant level.
After the checkings you runs under low safe limits, if you dosn't top off ..
then the problem will come up shortly...
After this , I buy the 0.9meter pipeline, but still will cost you around 1/5
of the systems refrigerant inside ...
Just to share you guys the info ....
johnmick is offline   Reply With Quote
Old 09-09-2020, 12:31 PM   #2
kd5oldx
Drives: 2010 yaris
yeah one of my yaris' used about 1/2 pound pf freon. it's not much
kd5oldx is offline   Reply With Quote
Yaris Sedan Deadening and Sound system upgrade derickveliz2 In Car Entertainment + Electronics (audio / video / alarm) 2992 11-18-2021 02:14 AM
ACRONYM thread Shroomster Off-topic / Other Cars / Everything else Discussions 44 08-23-2014 03:55 PM
Ohm's Law and Setting Amp Gain _S7V7N_ In Car Entertainment + Electronics (audio / video / alarm) 24 03-13-2012 09:34 PM
